Old 01-08-2025, 12:08 AM   #1
eric8
Spectra CU730 big block radiator (73-80)
I finally decided to swap my small radiator in my 77C 10 for the big block radiator. I have the new metal top plate and the wider mount cushions, as well as the BB fan shroud.
My questions are about the mounting of the shroud. The bottom of my original small block shroud lid into some U-shaped metal clips on the bottom core support, and then the top of it bolted to the radiator top plate. As you can see in the photo of the big block shroud, it has several mounting holes along the bottom of it, and I don’t know what they are used for? The factory illustrated parts book seems to be no help.
eric8 is offline   Reply With Quote
Old 01-08-2025, 07:26 PM   #2
eric8
Re: Big Block/4 row shroud (73-80)
Mockup photos from today with the lower shroud tabs sitting in the factory SB shroud clips. Seems to have a gap between the shroud and radiator. Is this normal? Also, there’s a middle mount tab on the upper portion of the shroud with nothing to bolt to. Thoughts?
I can find nothing that shows the factory 4 core would use any different lower mount clips than the SB shroud used. I have the 4 core top support, shroud, and wider cushions. The fan shroud is a reproduction.
Old 01-08-2025, 11:16 PM   #3
eric8
Well I *think* I have part of the problem resolved. The original big block shroud p/n for square bodies was 06262163. That shroud was flat along the bottom and did not have the lower two tabs with bolt holes sticking down. That shroud got superseded to p/n 14021289 (direct replacement according to GM) which has the two tabs along the bottom along with the middle top (unused?) mount tab.
As you can see in the first photo of a 6262163 (still with the clips it rides in intact) the flush bottom would allow it to sit lower and ride flush with the core support top plate. I could trim those bottom ears off of my reproduction 14021289 and mimic the earlier p/n. I still don’t know what would fix the gap along the sides though.
Old Yesterday, 12:32 AM   #4
RustyPile
RustyPile's Avatar
Something like this might work..
https://www.oreillyauto.com/detail/c...ersal%29&pos=2
RustyPile is online now   Reply With Quote
Old Yesterday, 02:04 AM   #5
eric8
Well I hacked off the bottom ears of the fan shroud which made it sit perfectly flush with the radiator top plate. Found a pic of a 76 factory big block on a Bring A Trailer auction and apparently the side gap is normal (see below).
Now my only issue is the factory 350 clutch fan doesnt extend into the shroud as it should. I guess the spacing of the big block water pump is different, or maybe they used a longer shaft going to the fan?
Old Yesterday, 01:53 PM   #6
eric8
Completed job. Note fan placement is outside of the shroud. This may be a non-issue, but this is a good reference for those doing this mod to their small block equipped C10
Old Yesterday, 03:06 PM   #7
Dead Parrot
Compare the depth/length of the round part of your shroud to the round part of the one in the BaT pic and that is your difference.
Wouldn't worry too much about it unless it doesn't cool.
Dead Parrot is offline   Reply With Quote
Old Yesterday, 04:02 PM   #8
eric8
Yes the one on BAT extends into the shroud. Ideally, I need to get a small block shroud that shares the same top plate and radiator as the 454. Looks like 75-77 Blazer with a 400 or 78-up C series with auto and AC.
I may run it as is and see how it does.
Old Yesterday, 07:39 PM   #9
eric8
Today’s SNAFU: went to button things up and my old top radiator hose is way too big for the new radiator inlet. Old radiator had the standard 1.5” upper fitting; this one is 1.25.”. Did some digging on rock auto and apparently some time in the mid 80’s the p/n for the upper hose switches for our trucks. 😑
