Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 12-02-2024, 11:22 PM   #51
docrock
docrock's Avatar
Re: 1942 Chevrolet Flatbed that ate My Brain
I am trying to figure out the fuel lines. The fuel lines on the tank are the type that have a rubber seal. The TBI has the same. I will look at fuel line and adapters online and see if there is something that will work. Any ideas where to look?
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 12-03-2024, 10:46 AM   #52
Rickysnickers
I'd start here, https://www.russellperformance.com/s...b39jR5jiV3Mav8
Old 12-12-2024, 11:44 PM   #53
docrock
docrock's Avatar
Thank you for the link.
Old 12-12-2024, 11:56 PM   #54
docrock
docrock's Avatar
Tank done and lines
Old 12-12-2024, 11:58 PM   #55
Getter-Done
Getter-Done's Avatar
I don't know how I missed this Thread.
Great build.
I am Subbed now .
I like the Grill the most on these Trucks.
84 Chevy K-20
Old 12-13-2024, 12:02 AM   #56
docrock
docrock's Avatar
I started to work on the shifter. It is an American Shifter from the Hoffman Group. I now everyone says they are junk but I put it together and called tech support and it is working out so far
Old 12-13-2024, 12:10 AM   #57
docrock
docrock's Avatar
Thank you. I am really going to try to keep going on this and finish it to at least a driving point.
Old 12-15-2024, 12:11 PM   #58
docrock
docrock's Avatar
Fuel and return line are done. Not sure what to do with the vent lines. Started cleaning the transmission. I had a bunch of different products and Purple Power seemed to work well. I will post a pic when clean. I installed an energy transmission mount. Now the engine and trans are locked in. I really need to mount the cab in its finished location, so I started trying to figure that out. When this body was on this frame before I only had the radiator locked in. This next week I will measure the distance of the fender holes to the top of the running board. That should give me the correct cab height. I dont remember if the top of the radiator support is level with the cab at the hood mounting locations. I also dont remember what the space is between the cab rocker and the top of the running board. I will post more pics
Old 12-15-2024, 12:39 PM   #59
Getter-Done
You have been Busy.
They make some prety good One way vent valves.
Here is a Link below for one, They make some fancy ones also.
Link: https://www.amazon.com/dp/B0C4QW91QB
84 Chevy K-20
Old 12-15-2024, 05:11 PM   #60
docrock
docrock's Avatar
Thanks for the link. Thanks for following
Old 12-29-2024, 04:28 PM   #61
docrock
docrock's Avatar
Flipped
Old 12-29-2024, 04:30 PM   #62
docrock
docrock's Avatar
Used my lazer to set the cab up to make the mounts
Old 12-29-2024, 04:35 PM   #63
docrock
docrock's Avatar
This is the trans cleaned up a little better.
Also my wood spacers made out of Ash.
The rear pic shows my weld on bracket with another wood block.
Very close to factory style. At some point I may switch to rubber.
Old 12-29-2024, 04:40 PM   #64
docrock
docrock's Avatar
I removed the drive shaft. The one that was installed was for a th350. Now my trans is a th400. Trying to figure out how to separate the bearing from the shaft or cut the end off and weld on the th400 drive shaft end. Any thoughts?
Old 12-29-2024, 04:55 PM   #65
docrock
docrock's Avatar
Originally Posted by docrock View Post
Tank done and lines
I think I am going to install a ring of metal here to give a little more strength to the frame.
Old 01-03-2025, 11:45 PM   #66
docrock
docrock's Avatar
I think I am going to make a one piece drive shaft. Might be easier
Old Yesterday, 11:26 PM   #67
docrock
docrock's Avatar
Cut the drive shaft end off. Slid the th400 onto the other driveshaft
Old Yesterday, 11:28 PM   #68
docrock
docrock's Avatar
Ready to weld
Old Yesterday, 11:31 PM   #69
docrock
docrock's Avatar
Welded, ground and painted, Ready for install
