Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 01-09-2024, 11:07 AM   #176
Rickysnickers
Re: project 39
Free tools! Always nice and they were going to toss it??? Looks fine to me
Old 01-09-2024, 01:13 PM   #177
CSHADES
CSHADES's Avatar
Re: project 39
it was brand new in the box. box was torn open on the end and other problems. everything was in the box, the way they packed it everything stayed in place.
CSHADES is offline   Reply With Quote
Old 01-10-2024, 04:02 PM   #178
daveshilling
daveshilling's Avatar
Re: project 39
This is looking really good!! Stay on it
daveshilling is offline   Reply With Quote
Old 01-10-2024, 04:03 PM   #179
daveshilling
Re: project 39
Man, the things people are willing to throw away!!
Old 01-31-2024, 03:43 PM   #180
CSHADES
CSHADES's Avatar
Re: project 39
nothing real exciting going on with the 39 at this time . been working on the finish welding inside, final paint removal on the rear of the cab and of course trying to get the rusty top back to clean metal. all i can say is i really want to go back in time and kick my self in the a$$ when i was 18 for stripping the paint off the top. i am using a combination of different paper, grinding wheels and of course wire wheels trying to get back where it started.
Old 02-01-2024, 10:24 AM   #181
Rickysnickers
Re: project 39
Don't we all wish we could go back and have a do over?? LOL
Old 03-18-2024, 09:47 AM   #182
CSHADES
CSHADES's Avatar
Re: project 39
long time no see guys. i have been working on project 39 but nothing real exciting. a lot of sanding and grinding trying to clean the rust off the roof. i also decided i had better get the rain gutters pieced together so after i get the epoxy primer and body work done on the roof i could weld the gutters on. i think it will look good when installed.
Old 03-18-2024, 09:54 AM   #183
CSHADES
CSHADES's Avatar
Re: project 39
after getting the rain gutters put together i went and primed the cab and some other parts epoxy primed. i then started the filler work. i started using a different filler than what i have used in the past. it is the 3m platinum plus filler.
it is the creamy smoothest filler i have ever used it lays down smooth and the lines from the spreader disappear by the time it hardens. it also seems to sand easier than the other fillers i have used
Old 03-18-2024, 10:06 AM   #184
CSHADES
CSHADES's Avatar
Re: project 39
as i am doing the body work on the rest of the cab i kept looking at the cab corner on the left side. it was damaged along the way and i have no idea on how to get it straight. the bent part is in a difficult part to hammer on, i looked at some of the parts and parts cabs that i have and no of them were good enough to consider taking the time to cut and weld into this cab. while standing in the shower the other night it dawned on me that i had seen some where that they were repoping the corners so when i got to work the next morning i looked it up. sure enough they do make them and they come in pairs. i ordered them and had them on friday last week. so this weekend i got busy installing them. they actually dont fit to bad. the front edge where it goes into the door jamb sucks but i knew that was going to be the case from the experiences i have had in the past. so i cut the panel about 1/2 inch from the edge and welded it in that way. i did both sides over the weekend but i just put the pics on for the drivers side. the other side was the same pretty much with a couple of small differences.
Old 03-19-2024, 09:41 AM   #185
Rickysnickers
Re: project 39
Nice update.
Old 03-20-2024, 11:58 PM   #186
3757chevy
3757chevy's Avatar
Re: project 39
Very nice.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 03-22-2024, 10:31 AM   #187
CSHADES
CSHADES's Avatar
Re: project 39
I bought a hagen fuel door kit for this truck a few years ago. as much as i like the things that stick out from the body usually the fuel filler is not one of them. the tank that is under it has the fill neck stub on the front left corner so the filler neck is going to come out on the left rear fender. the hagen door kit i bought was the curved version but i bent a piece of tin to match what they had for a curve and it really isnt close enough to the curve of the fender for my taste. so i decided to take it a step farther and cut the new kit apart and just use what i needed. so this is the start of that. the door opening was 3 5/8 inches so i had to buy a hole cutter in that size. i marked the inside of the fender with the complete box then used the outer tin that i removed from the box to mark where the door goes. found the center of the hole and drilled it. i used the hole cutter on the outside of the fender. the hole cutter was a bit to aggressive to cut the regular way so i ran the cutter in reverse and slowly cut open the hole. stay tuned for part 2
Old 04-17-2024, 06:08 PM   #188
CSHADES
CSHADES's Avatar
Re: project 39
decided to work on adding the door locks to the doors instead of in the handle.i am still not sure how i am going to hook up the drivers side but at least i can get the lock in the door and let the hook up simmer in my head.i made new metal pieces for mounting the door locks instead of cutting it out of another door. the reason was there were never any locks in the door on the drivers side so i decided to make new pieces that will match side to side. even if they dont look factory they at least look the same on both sides. i also have been working on welding the door in center and repairing the rust. the problem seems to be i keep finding more rust as i go and the welding is taking over the door. the more i weld the worse it looks. i do believe it is time for a change in plans as far as the doors go. stay tuned for the door update
Old 04-24-2024, 02:20 PM   #189
CSHADES
CSHADES's Avatar
Re: project 39
update on doors, as i said the last time i was here i have decided to do something different with the door because of the welding situation. so i decided i couldnt really make it look much worse if i made my own door skin. so i cut the old one off and proceeded to make my own. i started with a panel and bent 90s on 2 sides, used the shrinker to add some curve into it. then i rolled it around on the english wheel that i had never really used before. stay tuned to see if it works out.
Old 04-25-2024, 09:25 AM   #190
Rickysnickers
Re: project 39
Still doing some nice work!
Old 06-27-2024, 10:06 AM   #191
CSHADES
CSHADES's Avatar
Re: project 39
just thought i would update this a little. i have tinkered with the truck a little but not a lot. Like usual i have more projects than time, i did manage to go to the Back to the 50s weekend without breaking any bones this time, i even went in the pool against the wishes of my GF and my friends. as far as the truck cab goes i have decided that i am not happy with the way the roof is laying out so there are going to be some changes coming up with that so stay tuned.
Old 11-08-2024, 03:06 PM   #192
CSHADES
CSHADES's Avatar
Re: project 39
decided to get back on truck after doing a bunch of other projects around home this summer. The shop downtown replaced the pipe bender so i took the old one home, got the parts to repair it and got it usable again. so i bent a tail pipe for the right side and decided the new bender does a lot nicer job on bends. i took the pipe i bent at home and used it as a pattern for the new bender. i bend a lot of pipe at work but this one was interesting going from the installed mufflers, around the gas tank and then hitting the openings in the rear of the box.
Old 11-08-2024, 11:36 PM   #193
3757chevy
3757chevy's Avatar
Re: project 39
Very cool. Nice job.
MIKE
Old 11-22-2024, 05:15 PM   #194
CSHADES
CSHADES's Avatar
Re: project 39
i have not been happy with the roof on the 39 so i had planned on cutting some pieces out of another cab i had that was in storage. last week i spotted an ad on fbmp for a 46 chevy truck cab and i thought maybe it would be a better thing to cut up than the one i was going to use. so i talked to the guy and went to his place about 2 hours away from home saturday morning. i started looking around his shop and yard and found a lot more that i ended up buying. so this was the haul. After getting all of this home i was looking at the cab and decided the one i had in storage would be a better candidate for the roof pieces that i needed and this one would be better for the other project that i had in mind for latter. so i exchanged them and now i am ready to go.
Old 11-23-2024, 12:16 AM   #195
3757chevy
3757chevy's Avatar
Re: project 39
Dang, nice haul.
MIKE
Old 11-23-2024, 10:41 AM   #196
Rickysnickers
Re: project 39
Yes, nice score.
Old Yesterday, 11:41 PM   #197
docrock
docrock's Avatar
Re: project 39
Looking great. I just ordered cab corners. Yours look good
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old Today, 10:19 AM   #198
CSHADES
CSHADES's Avatar
Re: project 39
thanks, i have spent a lot of hours on this project.i have to tell you guys it seems like if i didnt have bad luck i would have none at all. a week before christmas my shop furnace decided to take a dump so that was the top priority i am not a hvac guy and my friend that was now lives in GA so between him and my brother we got it figured out. the major problem was finding parts for a 50 year old reznor. finaly got it handled the begining of this week. christmas day my gf was driving my Yukon and it quit running about 20miles away so i had to go get her and then get the truck home the next day. then the outside faucet that the gf uses to water the horses broke. My ice maker started acting up. then the dryer decided it was time to quit making heat to dry clothes and like i said my freind that used to fix that stuff moved to GA. He does help me diagnosis things over the phone. right now everything is fixed except the icemaker but i have fixed this one before so it is just a matter of time. i have worked on the truck and will down load some pics of what i have been doing soon. i have been working on repairing the rear fenders with some patches cut out of the ugly fenders i got in the last parts purchase. i also built a new roll pan for the rear of the box because i was not happy with the first version and thought i could make it a lot nicer. i am glad you guys look at this thread and i hope it helps in any of your projects.
