Old 01-07-2025, 06:16 PM   #1
MikeB
MikeB's Avatar
Shorter column shift lever
My 69 truck has a 15" steering wheel and really needs a 2" shorter shift lever than stock. Auto trans, non-tilt.
Suggestions?
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-07-2025, 06:39 PM   #2
Classic Bowties
Always on the hunt...
Re: Shorter column shift lever
Suggestions?
Hi Mike, we have the short style shift lever on hand/available in new repro for the tilt steering columns, but to my knowledge the short style lever has not been reproe'd yet for any of the non-tilt columns. The column end of the shift levers are different between the tilt and non-tilts (see below pics) so you may be able to try the shorter earlier style 67/68 shift lever or put in a little work and do something custom on your 69/70 lever. For any other needed column related parts and or request, check out the below linked steering column parts board f/s thread. We have a large group of original steering columns for parts pulled and stored along with several shelved bins of OE used, GM NOS and new repro replacement column parts on hand ready to ship out. Mel
http://67-72chevytrucks.com/vboard/s...d.php?t=838093
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 01-07-2025, 06:40 PM   #3
dagnabbitt
dagnabbitt's Avatar
Isn't the shifter for a three-on-the tree two inches shorter?
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-08-2025, 10:18 AM   #4
Rich69shortfleet
I used a shifter handle out of a 64/65 Chevelle automatic column. I had to thin the pivot hole section just a bit to fit into the truck column other than that it dropped right in. BTW, the metal the OEM handles are made from are ridiculously hard so even taking a few thousandths off of it took a while. Even the knob on the handle matches the turnsignal knob better than the original did. Been working fine now for nearly a decade.
And like the OP, I wanted/needed a shorter handle due to having put in a smaller steering wheel.
Rich69shortfleet is online now   Reply With Quote
Old 01-08-2025, 11:15 AM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
I bought a 60-66 style shift knob to match the turn signal lever as well. I also have a 15" wheel, the longer lever doesn't bother me, but the mismatched knob did, lol.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-08-2025, 11:17 AM   #6
70STOVEBOLT
I have a '67 column in my '70 and I had to remove a little meat to get it to fit into the column opening as well. I think the difference is in the shape in that area. If you look at the pics Mel posted, it looks like the 67-68 is somewhat rounded and the 69-70 has sharp 90 degree corners in that area.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 01-08-2025, 11:42 AM   #7
MikeB
MikeB's Avatar
Please elaborate on having to "thin the pivot hole section just a bit." Does that mean you had to decrease the diameter (or thickness) of the lever in the area of the hole?
Also, is the 64/65 Malibu column for tilt or non-tilt, if that even makes a difference.
Thanks.
Mike
Old 01-08-2025, 12:06 PM   #8
70STOVEBOLT
MikeB see post #6 above.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 01-08-2025, 12:23 PM   #9
MikeB
MikeB's Avatar
Originally Posted by Classic Bowties View Post
...you may be able to try the shorter earlier style 67/68 shift lever...
I see where the 67-68 lever has a sharper bend rearwards toward the steering wheel. My 69 lever is 2" from the steering wheel at the knob, but moves back 1" when I pull it back to take it out of Park. So it looks like the 67-68 lever might hit the wheel. Can you lay the 67-68 lever on top of the 69-70, lining up the column ends? That way I can see how much farther back the 67/68 is on the knob end. Whew!
Mike
Old Yesterday, 10:41 PM   #10
Rich69shortfleet
Thanks.
I had to reduce the thickness of the lever.
64/65 Chevelle tilt columns are super rare and very expensive so I'd never part one out. The lever I used came from a standard auto shift column.
Old Today, 10:33 AM   #11
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Shorter column shift lever
For 1970-72 truck tilt columns, the mid '70's - 1982 van tilt column gear shift lever is shorter than the original.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
Old Today, 04:45 PM   #12
pjmoreland
pjmoreland's Avatar
I have a rusty old 67-68 style shift lever I'd be happy to give you if you want to test it for fitment.
pjmoreland is online now   Reply With Quote
Old Today, 05:09 PM   #13
MikeB
MikeB's Avatar
So it looks like the top one in this photo?
Mike
Old Today, 05:26 PM   #14
pjmoreland
pjmoreland's Avatar
I just went and dug it out of my basement, and I was wrong about which style it is. It's a 71-72 with the thicker portion where it fits into the column. Here are some side-by-side photos of it next to an actual 67-68 shift lever. The 67-68 lever doesn't seem to bend any closer to the steering wheel.
Old Today, 05:27 PM   #15
pjmoreland
pjmoreland's Avatar
One more photo
Old Today, 05:33 PM   #16
MikeB
MikeB's Avatar
Thanks for the photos!
Looks like the 67-68 lever might work. Is the square column end a little larger than a 69? Same size dowel pin?
Mike
Old Today, 05:41 PM   #17
pjmoreland
pjmoreland's Avatar
I don't have a 69-70 lever to measure, but here are some measurements from the 67-68 and 71-72 levers I have:
67-68 Thickness = .385"
71-72 Thickness = .465"
Dowel Pin Hole (both levers) = .224"
You could measure your 69 lever thickness for comparison.
Old Today, 05:49 PM   #18
pjmoreland
pjmoreland's Avatar
I have this other 67-68 lever that has some pitting on the chrome that I'd be happy to send to you if you want to give it a try.
