Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old Yesterday, 01:53 PM   #26
HO455
HO455's Avatar
Re: Stink Ten Two. The second Blazer.
When removing and installing the wires I keep light tension on the slack line so if I detect any resistance on the line I'm pulling on I stop and reverse direction to hopefully prevent the wires from getting stuck in the middle of the column. The first photo shows the string all set up and ready to pull the new switch wires down the column.
Once the wires were pulled down the column I reassembled the column stopping before I reinstalled the lock plate. Getting the high beam linkage correctly installed and working smoothly took a couple tries. I made sure the moving pieces were all freshly greased.
At that point reconnected the battery and tested the high beam switch function as well as the turn signal function. Once I was satisfied with the operation of the mechanical linkages I reinstalled the pins into the wiper connector and plugged the two halves of the wiper connector back together and tested the wiper functions.
Now that everything had tested good I finished reassembling the column. At 3 & 1/2 hours I might of made flat rate. Much better than I did on the blower motor replacement.
As a side note I'll add that until several years ago I never knew there was a special tool to remove and install the lock plate. I've always used a clamp and two picks to remove ithe spring clip that holds the plate in place and a large washer with two small pry bars and the two picks again for installation.
The old switch was driving me crazy! Half the time when I touched the control arm the wipers would swipe. If I hit a harsh bump the wipers would swipe. It's so nice not to have that happening anymore. Plus with everything freshly lubricated the switch is so smooth and easy to use I want to change lines more just so I can use the switch more.
RIP Bob Parks.
