Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-25-2024, 04:01 PM   #51
hevy_chevy67
hevy_chevy67's Avatar
Re: 1970 Blazer Build
The 6.2/6L80E combo will make it move! 400hp and good gearing with relatively low weight is a recipe for performance.
I'm hoping! I'll be running 3.73 gears in it.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e
1970 Chevrolet K5 Blazer - Project
1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4
1969 GMC Suburban - 5.3 LS, 4L60e
hevy_chevy67 is offline   Reply With Quote
Old 11-29-2024, 08:13 PM   #52
Ricky Rodder
Ricky Rodder's Avatar
Coming along nicely
Ricky Rodder is offline   Reply With Quote
Old 12-01-2024, 02:30 PM   #53
hevy_chevy67
Getting things mocked up. Need to do some hinge work on the slots to get the doors dialed in yet
Old 12-14-2024, 09:49 PM   #54
hevy_chevy67
Getting a little further along in getting sheet meal hung. Also had to put on tires for some extra motivation.
Old 01-07-2025, 04:59 AM   #55
dec010974
dec010974's Avatar
Hello hevy_chevy67. Happy new year. Is that a true, K5 Blazer, 4WD frame? If so, how did you locate the hole for the Trailing arm cross member? Do you have measurements or a guide? I want to use your blue print. Thanks in advance, Clark.
dec010974 is offline   Reply With Quote
Old 01-07-2025, 11:02 AM   #56
hevy_chevy67
Yes, my frame is an original 4WD frame.
It was a while ago since I placed the crossmember, but I'm 99.9% sure there was an existing hole on each side I used. I then had to drill the remaining ones. Here are a couple pics I have saved of my front and rear crossmember, the bolts in each picture used an existing hole to get the proper placement and then I drilled new ones for the remaining.
Old Yesterday, 03:03 PM   #57
hevy_chevy67
Started putting the front end together. I had a set of control arms and crossmember powder coated, so I put those together along with 2" drop springs and drop spindles.
Ripped out the engine & trans from the Yukon donor. I was planning to part it out but the FB Marketplace idiots and messages were in full force. Not worth the headache and effort so I sold the whole thing as is and re-couped a bit of my cost. He picked it up on Sunday so at least its gone and down the road.
