Old 01-08-2025, 06:07 PM   #1
jabborabbo
jabborabbo's Avatar
Continuing rear brake woes
Okay… I’m including a picture showing the “nail” for the spring that holds the rear shoe on…as you can see, it’s not coming straight through the shoe and won’t straighten up once the S-A arm is put on it cuz the e-brake piece is not allowing it to happen…what am I doing wrong? I’ve been fighting with it for several hours - taking everything off and putting it back together.
Also, what length should the nail be?
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is offline   Reply With Quote
Old 01-08-2025, 07:20 PM   #2
slikside
slikside's Avatar
Re: Continuing rear brake woes
To state the obvious...something ain't lining up!
Here's a link to a really good, step-by-step process with pictures on how to assemble drum brake assemblies. You might find that your method is somehow misaligning things?
Anyhow, here ya go:
https://www.pbase.com/nufsed/drumbrake
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 01-08-2025, 08:16 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
We fought with ours last week.
Park brake cable seized and created a ton of headaches
Old 01-08-2025, 08:28 PM   #4
jabborabbo
jabborabbo's Avatar
Anyhow, here ya go:
Thanks. That’s what I’ve been using…I’m screwing something up - I don’t know what yet…
Old 01-08-2025, 08:30 PM   #5
jabborabbo
jabborabbo's Avatar
I’ll check that out. Thanks!
Old 01-08-2025, 08:48 PM   #6
Jason Banks
Jason Banks's Avatar
It would be helpful you you could send a picture of the whole setup so we can see how everything is lining up.
Sometimes it seems like quite a bit of juggling to get everything lined up right...
Jason Banks is offline   Reply With Quote
Old 01-08-2025, 09:52 PM   #7
jabborabbo
jabborabbo's Avatar
I’ll send a pic later this evening!
Old 01-09-2025, 11:03 AM   #8
MARKDTN
Are you sure you have the shoes in the correct place-not the front on the back and vice versa?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-11-2025, 09:17 AM   #9
cbeerman
The front shoe (primary) should have the shorter lining
cbeerman is offline   Reply With Quote
Old 01-12-2025, 02:01 AM   #10
Kalums
This^ plus a few other things was exactly what happened to me and I just got mine back to working Tuesday. Someone butchered mine up completely so I had to figure out and find most of the missing pieces. Keep at it it will work out in the end. In all seriousness/sincerity Good luck. ��
As a side thought when mine didn't want to line up I installed the adjuster and spring on the bottom and adjusted mine "out" till the pins/holes did match up on both sides. That helped me. *shrugs*
Kalums is offline   Reply With Quote
Old 01-12-2025, 12:30 PM   #11
jayoldschool
Moderator
Anyhow, here ya go:
I used this exact resource when rebuilding my rear brakes on my 65. It was essential, I was missing all the park brake hardware.
jayoldschool is offline   Reply With Quote
Old Yesterday, 08:59 AM   #12
don t. - 72gmc
When I did the brakes on my 70 drums, I used a squeeze clamp or a c-clamp to kinda hold things in place while I got the 2nd side in place. Wasn't perfect but was easier since I now had 3 hands(smile).
HTH...Don
don t. - 72gmc is offline   Reply With Quote
Old Yesterday, 01:03 PM   #13
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Some illustrations
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old Yesterday, 04:33 PM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
C20 and a c10 I've had apart lately
Old Yesterday, 04:35 PM   #15
MySons68C20
MySons68C20's Avatar
Nice pics KQQl very helpful....I do so little drum brake work that pictures really do speak a thousand words!
MySons68C20 is offline   Reply With Quote
Old Yesterday, 05:38 PM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
Same here. Why I have pics
I bet rube goldberg would approve
My 68 c20 frustrated me enough that I bought a disc brake swap last time I was in there.
