Old 11-23-2020, 07:08 PM   #76
Brads49
Re: First truck build '49 3100
Originally Posted by gigamanx View Post
Looking great except for the clean garage. Are you sure you're working on an AD truck? I don't see random parts laying around, rusty dirt covering the floor, power cables from tools that are asking to be tripped over, broken off bolts, none of the things I had haha.
HAHAHA! well of course that pic was taken AFTER I cleaned up a bit. I have all the parts for the truck up in the rafters LOL......
Brads49 is offline   Reply With Quote
Old 11-23-2020, 07:12 PM   #77
Brads49
Thanks for the kind words guys! Honestly the transmission access panel and tunnel was alot easier to do than I anticipated it to be. I don't want to jinx myself because I still have to clearance the firewall. I am going to try a trick I saw on another build that used a steel valve cover cut in half and welded into the firewall to provide a nice stamped piece for clearance of the new engine's valve covers. We'll see how it goes.
Old 12-07-2020, 09:55 AM   #78
Brads49
This weekend I started working on the firewall clearance for the valve covers the new engine. I saw where someone on here used an old valve cover turned around to allow the clearance needed. I decided to go that route but when I started cutting I made the mistake of cutting the hole too tall so I had to use part of what I cut out as a filler. I think it turned out pretty good, gives me the clearance that I need to remove the valve covers even though I'll not be using the covers that are currently on the engine. My concern now is that I may have placed the motor mounts too far back and I may not have room for the distributor. So now I have to decide if I want to move the engine forward a few inches before I get too much further.
Old 12-07-2020, 08:52 PM   #79
Tempest67
Tempest67's Avatar
that is a neat idea using the valve cover like that, thanks for sharing.
It looks like that motor will need to move forward for the distributor, or another rework of the firewall ??
Tempest67 is offline   Reply With Quote
Old 12-08-2020, 04:50 AM   #80
MiraclePieCo
MiraclePieCo's Avatar
A couple of ideas for distributor clearance:
1) Couldn't you just recess the firewall behind the distributor like you did for the valve covers?
2) Would using an old-style small distributor give you enough clearance?
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 12-08-2020, 08:30 AM   #81
Mains52
Fire wall work is sweet looking keep it up!!
Mains52 is offline   Reply With Quote
Old 12-08-2020, 11:25 AM   #82
Brads49
I'll have to see once my distributor gets here just how much room I'll need. I don't really want to remove the motor mounts and shift the engine forward but I will if I have to. The wife gets mad at me for buying stuff for myself right before Christmas so I'll have to wait a few weeks to get the distributor. Oh well I have plenty of other things to do on the truck.
Old 12-08-2020, 01:23 PM   #83
Tempest67
Tempest67's Avatar
Here is my HEI dist, cap on a SBC.
Old 12-08-2020, 02:08 PM   #84
Mains52
I legitimately Laughing Out Loud . I just got my butt ripped the other day for buying " crap" for the truck before Christmas. I feel your pain. There is so much I want to order lol
Old 12-08-2020, 07:54 PM   #85
dsraven
you did a nice job on the valve cover insertion. if you need to make room for the dizzy maybe make a run to the wrecker and snip a firewall section from something with a dimple size you need. maybe even look at a ford aerostar for an idea, they had a removeable cover to access the engine from inside the truck. just an idea, you could incorporate something like that and keep the contour tight to the dizzy. us some lunchbox style clasps and some weatherstrip to keep the thing sealed up. the other idea, to keep the engine parts theme going, could be to use part of a tall truck air filter housing or part of an oil pan welded in or bolted on. maybe cut and section a couple of valve covers together to get the width you need. if you will be doing a carpet interior floor maybe try to keep weird contours to a minimum though. they get hard to get carpet to bend around.
Old 12-17-2020, 08:56 PM   #86
fisherman420
Great build! I ended up adding recess for the valve covers as well. There is always challenges with these builds you don't see coming until it hits you in the face you just have to adapt and overcome. My build has been in limbo for almost two years now and i plan on picking it back up in the new year. Keep up the progress!
My 1950 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=720858
fisherman420 is offline   Reply With Quote
Old 01-06-2025, 12:00 PM   #87
Brads49
Well all, after a *cough 4-year cough* hiatus, I'm finally back on the truck. We decided to move at the end of 2020 and the new house didn't have a shop so the truck went to a friends barn for over a year while I built my shop. Then once the shop was done I did a pretty good job of finding other things that needed to be done before I got back on the truck project so it just sat in the back corner while everyone I know kept asking me.... "When are you going to finish that truck?".
So the past couple of weekends I have spent working on it. I built the supports for my gas tank to relocate it to the rear of the frame. I ended up going with a '69 Camaro tank and it seems to fit pretty well. I have the fuel line to run now and then it's on to brakes. My hope is to have it driving this summer but we'll see, there always seems to be more than enough other things that get in the way.
Old 01-06-2025, 12:04 PM   #88
8man
Tank looks good. Good luck with moving forward, I know what you mean about "other things"!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 01-07-2025, 12:32 AM   #89
dsraven
if you are still thinking about the firewall clearance thing maybe consider a steel wheelbarrow tub. they would possble solve all your problems and be smooth on the inside so the carpet, or whatever you decide to use in there, would be more easily done and look smooth. just a thought.
nice work on the tank install.
Old 01-07-2025, 12:34 AM   #90
dsraven
did you use any insulator material between the straps and the tank? just curious. metal on metal seems to cause rust issues.
Old 01-07-2025, 12:22 PM   #91
Brads49
Thank you for the wheelbarrow tub idea, I may look into that.
I didn't use any insulator between the tank and straps but maybe a strip of rubber wouldn't hurt to throw in there.
Old 01-07-2025, 12:29 PM   #92
dsraven
Even a bicycle inner tube would work.
Old 01-07-2025, 01:07 PM   #93
Tempest67
Tempest67's Avatar
shrink tubing also works for an isolator
https://www.amazon.ca/uxcell-Heat-Sh...s%2C119&sr=8-5
Old 01-07-2025, 01:31 PM   #94
dsraven
Yup. Some more modern vehicles use it on the ac lines etc. Also comes in different sizes and with a type of hot glue on the inside or not. For wiring I like the hot glue type as it helps seal weather out of joints.
Old Yesterday, 06:44 PM   #95
Brads49
Well guys, I spent the weekend working on the engine. I had the TH350 re-built last week so it's all ready to go in with a warranty. I purchased this engine from an acquaintance a few years ago as he pulled it out of a square body to replace it with a BB. After pulling the valve covers and the intake and seeing how clean it is I don't believe there are very many hours on this engine so I'm gonna risk it and just replace a few items and run it and see what happens. After running the numbers on the heads, it appears to be a 1990+ GM Goodwrench 350 crate motor. I haven't tried running the block numbers to see if that will narrow it down to a production year. I put a new fuel pump / water pump / distributor on, cleaned and painted the rest. Nevermind the plastic water fitting or the crummy looking thermostat housing. I have new valve covers / t-stat housing and water fittings coming tomorrow so I can finish that up. Then it's on to the brake system to finish up the chassis before putting the body back on.
Old Yesterday, 11:45 PM   #96
dsraven
Nice.
Just cuz it's been sitting for awhile maybe do the front and rear main seals. Easy when it's out (one piece rear main I assume) so might be worth doing at least the rear one.
Nice pics, we all love when guys post pics as they move through. Appreciated.
