Old 01-11-2025, 12:25 AM   #351
pjmoreland
pjmoreland's Avatar
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Started installing the front brakes. Didn't make it very far though because the hoses are too short. It doesn't make sense though since I've got stock suspension. Got these hoses from LMC. Went to Napa and O'Reilly and their hoses are exactly the same. They need to be about 2" longer.
pjmoreland is online now   Reply With Quote
Old 01-11-2025, 12:29 AM   #352
'68OrangeSunshine
'68OrangeSunshine's Avatar
Was the rig lifted?
Old 01-11-2025, 12:31 AM   #353
pjmoreland
pjmoreland's Avatar
Originally Posted by '68OrangeSunshine View Post
Wa the rig lifted?
I think these are stock leaf springs, but I don't know for sure.
Old 01-11-2025, 12:59 AM   #354
pjmoreland
pjmoreland's Avatar
Dumb mistake. I just needed to rotate the caliper end 90 degrees so that the hose faces upward.
Old 01-11-2025, 08:41 AM   #355
CUSTOM/10
CUSTOM/10's Avatar
See what they look like once you get some weight on the springs, motor, Transmission & transfer case.
I'm having the same issue but with 2" lift , and 23" lines that are supposed to fit.
Just barely at full lock left & right.
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 01-11-2025, 12:04 PM   #356
pjmoreland
pjmoreland's Avatar
Good point. The weight of the drivetrain will help. I'm a little concerned about what the hose might look like at full lock during articulation on uneven ground, but it will probably be ok.
Old 01-11-2025, 12:17 PM   #357
CUSTOM/10
CUSTOM/10's Avatar
Yeah and at full droop will they pull tight. Thats my concern...
Gary
72 SWB 4x4
My 72 SWB Build
Old 01-11-2025, 10:13 PM   #358
pjmoreland
pjmoreland's Avatar
Installed front and rear brake hoses and new stainless brake and fuel lines today. I'm missing the bracket that secures the rear driver side hard line to one of the diff cover bolts. I'll either track one down or make one.
Old 01-11-2025, 10:18 PM   #359
pjmoreland
pjmoreland's Avatar
Also today one issue I ran into was that the banjo bolts that came with the new calipers were too short (7/8" long), and especially with the thick copper washers that came with the calipers. I couldn't find any longer banjo bolts for sale locally, so I cleaned up and used the originals (1" long) along with the thinner copper washers that came with the hoses..
Old Yesterday, 09:17 PM   #360
pjmoreland
pjmoreland's Avatar
Picked up some red oak from the local hardwood store for the bed floor.
Old Today, 01:59 AM   #361
pjmoreland
pjmoreland's Avatar
The original clutch pedal on this truck had an over-center helper spring since the pedal support has the upper mount for the spring. I will be going with a diaphragm clutch, so an over-center spring won't be needed. I replaced the pedal support with one that doesn't have the provision for the spring, and I added a clutch pedal to it. Disassembled and greased the bushings.
