Old 01-13-2025, 04:58 PM   #1
PbFut
BatteryCablesUSA.com good stuff
Couple years ago I was having difficulty with hot starts. Swapping to 2awg fixed the problem. Fast forward to this past fall and a bad engine fire from a faulty fuel rail. Things got so hot that the battery began to melt. The battery wire i purchase from BatteryCableUSA.com show no damage. That's good stuff.
PbFut is offline   Reply With Quote
Old 01-13-2025, 08:32 PM   #2
54blackhornet
54blackhornet's Avatar
Re: BatteryCablesUSA.com good stuff
Thanks for the heads up !
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 01-14-2025, 02:33 AM   #3
jumpsoffrock
Wow that's impressive, is your truck ok?
jumpsoffrock is offline   Reply With Quote
Old 01-14-2025, 11:17 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
That's awesome to know. I just redid my battery cables in my '70 with 2AWG wire and all the terminal ends and solder supplies from https://batterycablesusa.com Great stuff, fast shipping, and made in USA!
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 01-14-2025, 11:22 AM   #5
PbFut
Thanks for asking. It sustained major damage. I am retired so I just decided to make it my new full time job. Easily been on it 40 hours a week since early October. Hagerty insurance has been fantastic to work with. They allow self repair. I had 30k stated value. They ended up covering me with 21k. I was good with documentation, they were generous on everything I requested and they reimbursed me for my time as well. I did not bill all the hours I spent simply because I work very slow and also did things outside of damage. Initially I was sad as I spent 18 months getting it just how I wanted it. 3 weeks after completion, a fuel rail/injector connection sprayed the engine bay down and ignited. I lost most everything from the dash in cab to the radiator. It was a very hot fire.
Old 01-14-2025, 12:36 PM   #6
SCOTI
SCOTI's Avatar
Dang.... Sux that happened to you after all the effort but a solid *WIN* on the insurance company doing their part.
I just re-worked all the cables (power & ground) under the hood of my '99 OBS CCSWB after buying my own tools (hydraulic crimper w/dies). I looked into & considered buying from @batterycablesusa but ultimately decided to purchase things local (2AWG & 4AWG cables) JIC I needed more or make in the moment adjustments. I'll def consider them for the next project.
Best of luck on the 're'-rebuild.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-14-2025, 01:18 PM   #7
kwmech
Part of my business is making custom winch and battery cables. I can even make side post stuff now. Battery Cables USA has some nice stuff.
Old 01-14-2025, 01:38 PM   #8
PbFut
Having the need to purchase so many parts recently exposed me to some surprises relative to aftermarket parts. Some eye opening disappointments but also nice to see there are still some stand up suppliers out there.
Old 01-14-2025, 05:30 PM   #9
SCOTI
SCOTI's Avatar
This is what I was worried about.
Everything online is advertised as 'great' but we all know in many instances it's a 'not-so-much' reality. I had stuff bookmarked @batterycablesusa but decided to see what I could find local. The local purchase let me know exactly what I would be working with since my window of opportunity was very limited & provided a consistent materials source should I miscalculate (which I did). A quick trip back to my cable source (I used welding cable from Tractor Supply) got the final length of 4AWG I needed for an additional ground the truck never had.
BatteyCablesUSA.com definitely would have been cheaper on the cables but I never went so far as to calculate totals including shipping. With your post, I'll probably give them a try when the next opportunity presents itself.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-14-2025, 06:46 PM   #10
weq92f
weq92f's Avatar
Thanks for the shout out to batterycablesusa as I had considered them in the past and chose against. I'll use them next time then!
Hagerty is indeed very accommodating. I had a claim back in 2019 for no-fault-of-mine collision. 6k claim only but they were fantastic. I understand they'll allow used parts for rebuilding classics after a loss such as yours.
I'm with grundy now though...premiums went up slowly and steadily after my claim so had to bail this last renewal period. It wasn't crazy but it was there and pushed me away. YMMV of course...
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
