#1026 |
low n' slo
![]() Join Date: Mar 2009
Re: Project 67 DRGNWGN - 67 Burban!!
so here's the deal. pulled it off and took it back to the shop who made it. I showed him the picture of it installed and he said it's fine, there is a lot more of the shaft still in. so I slid it out until it almost came out. so, with it installed there is about 2 1/4" of slip showing, leaving 4" of slip still in the tube. when I slide it almost all the way out, you can see the slip splines are almost 7" long.. I hope I am making sense.
1st picture is completely collapsed, 2nd is all the way open (I think, didn't want it to slide out). and from the pic a few posts up you can see how much is showing with it installed
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#1027 |
low n' slo
and this is the trans side yoke. you can see from the clean part how much is in the trans. he said this is also fine because there is still about 1.5 - 2" left of slide room
#1028 |
One thing to consider when making decisions on the transmission yoke spline engagement is how far are the splines recessed inside the tailshaft of the transmission as well as are the splines full length inside the yoke or are the recessed or not machined completely to the bottom of the bore?
Here's a link to more information on spline engagement from a 4x4 shop. They built my driveline. https://4xshaft.com/blogs/faq/how-mu...uld-be-showing
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#1029 |
low n' slo
not a whole lot done lately, just driving it here and there. I threw some kilmat on the kick panels and put some carpeted kick panels on with some velcro. I like them! ordered some carpet hold down sills and the 3 door door rubber to quiet it down some. will need them to get the doors right when doing body work anyways.
also pulled the kick panel vents off to clean them up, re gasket, and paint
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by LockDoc; 09-03-2023 at 08:35 PM. Reason: rotate pictures |
#1030 |
![]() Join Date: Sep 2018
Lookin good Kev !!!!!!!!
#1031 |
The Older Generation
I like the carpeted kick panels. Gives it a finished look. LockDoc
#1032 |
low n' slo
thanks, they are made by ACC just like the carpet I used...pretty good quality. I rebuilt the vents and put new home made gaskets in and got them back in. just don't be a moron like me and use a drill bit to make the hole for the handle bracket...I ripped a straight line all the way down
#1033 | |
Yeah, you need to use a small soldering iron or hobby wood burner tool to make the holes in loop carpet. That's too bad that happened. LockDoc
#1034 |
low n' slo
ya I should've known. oh well, I can always order another down the line, they weren't too expensive.
#1035 |
low n' slo
been a hot minute on an update lol. just been driving it here and there but havent done much. started on repairing the upper hatch but i threw it in the towel and started looking for a replacement. once i find it i can get back to work on it!
#1036 | |
Well, maybe a couple of hot minutes... Glad to see you post anyway..
#1037 |
I remembered that you were looking for a hatch. I saw this on Facebook. Not sure condition or if he will separate or ship but might be worth a shot.
https://www.facebook.com/groups/1254...ibextid=wwXIfr |
#1038 | |
low n' slo
#1039 |
There is no contact info at all so I’m assuming he just needs to be contacted through Facebook. I just got it a few days ago so I’m not sure how marketplace works.
#1040 |
I just sent him a message to see if he is willing to sell it separate and condition. If he is I’ll see about getting his contact info for you.
#1041 |
low n' slo
sounds good, i appreciate it!
| Bookmarks |
