Old 12-11-2024, 09:35 PM   #26
WorldsCrappiestTruck
Active Member
Re: 1967 GMC - SWB, great patina
I spent 90mins with a grinder & wire wheel on the frame, getting a first pass on the exterior. It’s not as clean as my ‘68 (which was beautifully coated in a TON of old oil, grease, grime etc which perfectly protected the frame), but this was a nice surprise. No pitting, no significant scale. Just dry surface rust that came off in a big red cloud.
Some frame stampings were exposed, and I realized the leaf spring frame has bulged ribs by each leaf spring shackle, where my coil spring ‘68 frame was just straight flat frame rail. I assume for strength.
Parts continue to slowly roll in….
WorldsCrappiestTruck is offline   Reply With Quote
Old 12-26-2024, 03:37 PM   #27
Active Member
After a week and 6 unreturned asks to buy a used engine lift on Marketplace, I slunk to Harbor Freight and bought their $99 cheapie - will hold the 6.0. I searched Craigslist but that place has officially died. Searching “engine stand” get you used cars, mixers, hiking boots, anything but an engine stand.
The dipstick had broken / rusted off flush with the block, and I picked up a 302-1 oil pan kit. The truck pan hangs below the crossmember in my ‘68 so I wanted to change that this time around. From the underside the cylinder walls still have some crosshatch showing, and nothing looks awful. Used a brass punch to pound the dipstick back up/out. The Dorman 917-303 tube I bought would NOT fit. It measured 0.010” larger diameter than the original tube. I’d already dinged it up attempting to install, so used a flap wheel on a die grinder to turn the OD down a sniff. Covered it in never-sieze and sent it home.
Waiting on a timing cover alignment kit to arrive from the Bezos to continue work…
Old 12-27-2024, 11:33 PM   #28
Active Member
Removed as much rust and scale from the LQ4 as possible with an a needle scaler then various wire wheels before hitting the block with POR15 engine enamel.
Took apart the rear axles to get measurements for an order to Dutchman. I had to cut off the retainer, and bearing for measurements but the new axles will come with bearings & retainers installed.
Specs
- 29-5/16” & 31-5/16” length
- 30 spline
- 5x5 bolt pattern
- Pilot hub turned to 3-1/16” to fit most standard rotors EX: Wilwood
- Outer flange turned to 6-1/8” OD for fitment in most - GM applicable rotors if I go that route
- 1/2-20 screw in studs 3” long. Press-in were only available in 1-3/4 and 2” long….and I want more length, not knowing what wheels, spacers etc might be needed later in the game.
Last edited by WorldsCrappiestTruck; 12-30-2024 at 06:35 PM. Reason: Added more axle detail
Old 12-28-2024, 08:43 AM   #29
Active Member
The Dutchman model of axles for an early GMC Dana 44.
By changing the pilot and outer diameter, I deviated from a “stock replacement” with only a pattern change and was moved to “full custom order”.
$499 shipped for the pair.
Old 12-28-2024, 10:20 PM   #30
Active Member
Documenting for anyone in the future needing the info.
I used a large pipe wrench on the yoke and breaker bar on the pinion nut after making a reference mark with a die grinder for reassembly. With no crush sleeve, I’ll tighten the nut to where the marks line up again.
Ordered some rebuild parts today for the Dana 44
Pinion seal
DANA 44895
Axle Seal
CENTRIC 41766015
Old 12-30-2024, 04:31 PM   #31
Active Member
52* today so hauled the crossmember to the driveway for some cleanup. I’d love to go with a different crossmember, or even to rack & pinion….but maybe another day. Things cleaned up nicely with just a wire wheel on an angle grinder.
I’ll leave it bare and covered in the garage until spring when I can spray the whole chassis in Eastwood stuff. Gives me time to drill & tap for brake line retainers, fuel line clips, electrical stuff etc before paint is laid down.
Old 12-30-2024, 04:46 PM   #32
68Gold/white
Job well done!!!
68Gold/white is offline   Reply With Quote
Old 01-02-2025, 09:47 AM   #33
raggedjim
raggedjim's Avatar
Nice work. Facebook Marketplace drives me crazy...
raggedjim is offline   Reply With Quote
Old 01-02-2025, 08:56 PM   #34
Active Member
Thank you. Unfortunately it’s infinitely better than CL….so you get what you get I suppose ��
Diff parts are due shortly - looking down the axle tubes, the upper section of the tube (not where oil was sitting) has some rust, scale, debris etc.
I didn’t want any of these bits to fall / wash off in oil once on the road, so I rigged up a wire wheel on a couple drill bit extenders, dunked it in bucket of carb cleaner and honed the insides to get rid of as much as possible. It turned out ok after hosing things down with brake cleaner and running nice clean rags through a handful of times.
First 2 before, second two after.
Old 01-02-2025, 08:57 PM   #35
Active Member
Also spent a sniff of time on the engine. Installed the 302-1 pan, the freshly stripped & painted timing cover, valve covers, valley cover and coil brackets.
Old 01-04-2025, 07:06 PM   #36
Active Member
My ‘68 with a 5.3 has the rear steam tube locations plugged, and the standard truck front steam pipe. That pipe is tied into a nipple I threaded into the water pump. I wanted a 4-corner steam pipe for this 6.0, and looked at all options….finally settling on a standard issue LS1 pipe. I’ll do the same thing when I decide which water pump / accessory spacing I’ll go with - drill & tap for a barb to aid in air bubble venting.
Also picked up an inch-pound torque wrench for setting pinion bearing preload on the 12-bolt in the ‘68.
Any excuse to buy a tool….
Old 01-12-2025, 05:47 PM   #37
Active Member
Finally received some goods, so got after the rear diff reassembly with a new pinion seal, pinion nut and axle seals. On just about everything I assemble, it gets a LIGHT tough of Loctite 518, including a small line around the splines of the pinion and yoke.
I cleaned the heck out of the original bearings and coated them in 90w before reinstalling, tightening the pinion nut to a rotational torque of 15inchLb for the pinion. Used a big pipe wrench to hold the yoke.
Old 01-13-2025, 07:54 PM   #38
Active Member
New toys!
Old 01-13-2025, 09:47 PM   #39
chewychevy67
Were the original drums from the six lug axles any good yet or were yours bad?
chewychevy67 is offline   Reply With Quote
Old Yesterday, 01:53 PM   #40
Active Member
They were probably usable….but I had no intention to stay 6-lug let alone drum, so they went to scrap metal.
Old Yesterday, 02:46 PM   #41
chewychevy67
Ah. I would have bought those.... oh well.
Old Yesterday, 05:57 PM   #42
Active Member
RockAuto has Raybestos for $31/ea and GM Delco for $40/ea. I’d recommend that route vs used drums but just my $0.02.
Old Yesterday, 06:01 PM   #43
chewychevy67
Are they for the dana 44? I've never seen a new drum that fits the dana 44. They are different than the chevy 12 bolts
Old Yesterday, 10:17 PM   #44
Active Member
Now that you mention it and I dig deeper….the PN listed for the drums I speak of matches the PN for a 1968 Chevrolet C10.
I figured that by adding the vehicle as a GMC it would basically default to a Dana 44…..doesn’t seem that’s the case. The axle wasn’t mentioned in the product details either.
They have to be new out there somewhere…..but mine are gone, sorry. Had I known a board member needed the I would have loved to see them used.
Old Today, 12:01 AM   #45
chewychevy67
Oh no worries. I was just inquiring incase you still had them. I've been looking for new drums for a long time with no success. I may have to switch to discs back there someday. I always enjoy following 67 gmc builds. I'll be following
