Old 12-02-2024, 11:23 AM   #701
6DoF
6DoF's Avatar
Re: Yet another GMC build
if nothing else, should look sick!
6DoF is offline   Reply With Quote
Old 12-08-2024, 01:15 PM   #702
OKGMC4
OKGMC4's Avatar
Since I cut a brace out to move the tank, making another brace above the tank. Sway bar and links in now. Look at the back of the notch and you’ll see that I bent some 3/4 emt and welded it in before I closed the notch. I can put wiring from the frame rail through rather than around the notch. Did that on both sides.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 12-08-2024, 06:43 PM   #703
dsraven
Loooks good.
Canadian hotrods frames have all the electrical, brake and fuel lines run inside their boxed frames. Good idea I guess, it keeps it clean looking. If there were a problem I guess the frame could be opened up or the problem circuit could be ran on the outside.
Old 12-16-2024, 05:07 AM   #704
OKGMC4
OKGMC4's Avatar
Bed is back on. Still need wiring and brake lines, and to build a bed cover to hide the ugly. Realizing now that I’ll likely be adding lots of weight which will likely offset any benefit of being a couple inches lower. The rear view already looks better. I have always hated how the gas tank hangs WAY below the roll pan. And I had a frame rail that drooped and required spacers, and I fixed that. Hopefully the sway bar helps. And the rear frame is definitely stiffer now. We’ll see how it turns out.
Old Yesterday, 07:21 PM   #705
OKGMC4
OKGMC4's Avatar
3/4” square frame, stainless strips, 18 gage sheet metal. Ordered a couple quarts of bed liner so I can match the bed. Should cover the hole and look like it was on purpose.
Old Yesterday, 09:09 PM   #706
dsraven
So when you open the gate you have a nice little storage spot for things, if you cover the fuel tank with something protective. Looks good.
