01-13-2025, 06:07 PM | #1 |
Proportioning Valve Outlet Fitting
A possibly dumb question here, but here it goes: I’m putting in a disc/disc brake system and I need to know which fitting to use at the outlet (to the rear brakes) of the PV4 universal GM style proportioning valve. I plan to run 3/16 line out to the rear. The product info from MBM Brakes for the valve tells me that the outlet is a 9/16-18 fitting, but says nothing about line size. I can order a “9/16-18 Inverted Flare Nut; Line Size: 3/16" like this from Rockauto:
https://www.rockauto.com/en/moreinfo...1000606&jsn=67 Or I can get the “Proportioning Valve Adapter Fitting Kit - Set of 3” from CPP like this: https://classicperform.com/cp2091 Are the fittings from both places in fact the exact same thing (other than getting 2 unneeded ones in the kit)? Sorry if this sounds dumb, but all my searching has turned up conflicting info and I have zero knowledge where fittings are concerned. Any input would be greatly appreciated. |
01-14-2025, 10:21 AM | #2 |
Re: Proportioning Valve Outlet Fitting
search for 9/16-18 (thread size) and then sort by tube size. Tube nuts are made in various configuration.
The link to rock auto seems to be the one you want. |
01-14-2025, 05:47 PM | #3 |
Thanks Willie Makeit! I (erroneously) assumed that the outlet port in the proportioning valve was meant for a specific line size. This frees me up to get one of those inexpensive 9/16-18 fittings and hopefully start making some progress in the shop.
01-14-2025, 09:26 PM | #4 |
Why 3/16"? Most trucks use 1/4" to the rear drums. discs might need even more fluid.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Yesterday, 08:21 AM | #5 |
Al, I did a ton of searching online, and the info was all over the map regarding 3/16 vs 1/4 rear line sizes. In the end I picked 3/16 as I will be running an Explorer disc rear end. The engineers at Ford picked 3/16 line for the entire rear system, so I figured I'd go with what they picked.
Today, 12:38 AM | #6 |
I agree with cadilac al, I use 1/4 inch from the master cylinder to the prop valve and from the prop valve to the t fitting at the rear differential and from the t fitting to the rear wheel cylinders I use 3/16. That 1/4 inch line to rear feeds two rear wheel cylinders.
