Old 11-04-2024, 05:15 PM   #51
Classic Bowties
Always on the hunt...
Re: F/S GM NOS & New Repro Steering Column Replacement Parts
We recently pulled this inner main steering shaft out for another member that didn't end up following thru, the pictured shaft was just removed from a 72 non-tilt column and is in good OE used condition with great splines and threads, the steering wheel retaining nut spins on and off of upper threaded shaft end without effort. This part is list item #9 in the top post of thread.
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 11-18-2024, 06:17 PM   #52
ramiral6
Looking to purchase the bulb the cap and green filter for the steering column indicator shift light.
The one pictured in post 23.
65 C10 SWB BBW
ramiral6 is offline   Reply With Quote
Old 11-18-2024, 06:45 PM   #53
Classic Bowties
ramiral6, we got'ya down for Qty. 1 OE used tilt column shift indicator lamp steel cap and plastic filter setup and Qty. 1 New replacement shift indicator lamp/bulb, your combined total due with shipment and the info for sending of funds via Zelle has been forwarded on Mon. 11/18, please confirm your full shipping address and we'll get the parts ready for shipment. Thanks, Mel
Old 11-18-2024, 11:46 PM   #54
Classic Bowties
ramiral, the OE used tilt column shift indicator lamp steel cap with green plastic filter setup and the new replacement shift indicator lamp/bulb have been shipped off, your package went out via USPS ground advantage on Mon. 11/18 and the expected delivery day is this Fri. 11/22. Thanks again for your order and let me know if we can help with any other 67-72 parts needs. Mel
Old 12-01-2024, 10:21 PM   #55
Tim Christian
Tim Christian's Avatar
Looking for wire cover for a 1971 Chevy Truck tilt. Would you happen to have one? I would actually buy two if available? Thanks
Tim Christian is offline   Reply With Quote
Old 12-16-2024, 11:13 AM   #56
shorty6969
Do you have any more of the retainers and clips available?
https://67-72chevytrucks.com/vboard/...d.php?t=841451
shorty6969 is offline   Reply With Quote
Old 12-16-2024, 02:05 PM   #57
Classic Bowties
Yes, we can supply an OE used 2 pc. tilt column style lower bearing retainer and retainer clip set for $30. + $8. for CONUS shipment, our payment options are listed in the top post of thread. Let us know, Mel
Old 12-17-2024, 08:35 PM   #58
ajgriffin
ajgriffin's Avatar
Mel, you know what I'm here for. Let's see the column shifter goods. 69, non-tilt column.
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old Today, 03:02 AM   #59
Classic Bowties
We are adding the below pictured GM NOS parts for member BanjoDude and his 1969 3 speed manual steering column overhaul, am giving him first option/right of refusal on these items. We can ship parts #1 thru #4 combined for $15. in the CONUS or if you decide on only taking the #2, #3 and #4 bushings then shipping will be $8. for the three parts combined. Thanks, Mel
#1 } GM NOS 67-70 3 speed manual shift lever control housing. $100.
#2 } GM NOS shift lever control lower plastic wear bushing. $20. ea.
#3 } GM NOS shift lever control upper rubber washer bushing. $18. ea.
#4 } GM NOS shift lever control upper plastic thrust washer bushing. $20. ea.
Old Today, 03:06 AM   #60
Classic Bowties
Here are pics of the GM NOS 67-70 3 speed manual shift lever control housing...
Old Today, 03:13 AM   #61
Classic Bowties
Bringing this group of steering column parts back up ttt, we have several OE used steering columns for parts pulled along with a bunch of shelved bins of GM NOS, OE used and new repro steering column replacement parts available ready to ship out, if something else column related is needed just ask and if on hand we'll get it pictured/listed. Thanks, Mel
