Old 01-13-2025, 06:07 PM   #1
Father&son56project
Proportioning Valve Outlet Fitting
A possibly dumb question here, but here it goes: I’m putting in a disc/disc brake system and I need to know which fitting to use at the outlet (to the rear brakes) of the PV4 universal GM style proportioning valve. I plan to run 3/16 line out to the rear. The product info from MBM Brakes for the valve tells me that the outlet is a 9/16-18 fitting, but says nothing about line size. I can order a “9/16-18 Inverted Flare Nut; Line Size: 3/16" like this from Rockauto:
https://www.rockauto.com/en/moreinfo...1000606&jsn=67
Or I can get the “Proportioning Valve Adapter Fitting Kit - Set of 3” from CPP like this:
https://classicperform.com/cp2091
Are the fittings from both places in fact the exact same thing (other than getting 2 unneeded ones in the kit)? Sorry if this sounds dumb, but all my searching has turned up conflicting info and I have zero knowledge where fittings are concerned. Any input would be greatly appreciated.
Father&son56project is offline   Reply With Quote
Old 01-14-2025, 10:21 AM   #2
Willie Makeit
Willie Makeit's Avatar
Re: Proportioning Valve Outlet Fitting
search for 9/16-18 (thread size) and then sort by tube size. Tube nuts are made in various configuration.
The link to rock auto seems to be the one you want.
Willie Makeit is offline   Reply With Quote
Old 01-14-2025, 05:47 PM   #3
Father&son56project
Thanks Willie Makeit! I (erroneously) assumed that the outlet port in the proportioning valve was meant for a specific line size. This frees me up to get one of those inexpensive 9/16-18 fittings and hopefully start making some progress in the shop.
Old 01-14-2025, 09:26 PM   #4
cadillac_al
Why 3/16"? Most trucks use 1/4" to the rear drums. discs might need even more fluid.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 01-15-2025, 08:21 AM   #5
Father&son56project
Al, I did a ton of searching online, and the info was all over the map regarding 3/16 vs 1/4 rear line sizes. In the end I picked 3/16 as I will be running an Explorer disc rear end. The engineers at Ford picked 3/16 line for the entire rear system, so I figured I'd go with what they picked.
Old 01-16-2025, 12:38 AM   #6
chevyguyase
I agree with cadilac al, I use 1/4 inch from the master cylinder to the prop valve and from the prop valve to the t fitting at the rear differential and from the t fitting to the rear wheel cylinders I use 3/16. That 1/4 inch line to rear feeds two rear wheel cylinders.
chevyguyase is offline   Reply With Quote
Old 01-16-2025, 09:39 AM   #7
Willie Makeit
3/16" is fine for disc systems
Old 01-16-2025, 08:06 PM   #8
cadillac_al
I guess I would have to agree if ford uses 3/16 in their rear disc systems. I have never seen it in any vehicle that I have owned though.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 01-17-2025, 07:12 PM   #9
theastronaut
theastronaut's Avatar
Line size doesn't really matter, 3/16 isn't small enough to be restrictive. Newer trucks have 3/16 all around, even with rear drums.
theastronaut is offline   Reply With Quote
