01-11-2025, 07:10 PM | #26 |
Re: 1969 C10 Project “Nosejob”
Front discs at least are definately going in with the lowering kit!
67 SFBD C10 (sold) 69 C10 "Nosejob" 23 Raptor |
01-11-2025, 08:23 PM | #27 |
LOL, I just re-read your post 1...
If that 5 lug rear is as greasy as it sounds, it's likely a 71 or 72 rear end. Not knowing your Chevy pickup knowledge...The 71/72 rears are wider than your 68 (69?) is.. There's a boat load of other 5 lug swap facts. Let us know if you need any more... I have 67 and 68 C-10's I plan to use all factory parts to convert mine to disc, 5 lug... |
01-11-2025, 09:30 PM | #28 | |
Im really considering just buying the 6 lug front disk kit to save myself some hassle for the time being and not go down the rabbit hole of trying to piece the rest of what I have together then having to buy new wheels on top of it. Down the road most likely but right now Im not sure I want to swing it. Curious if i can use my the brake master i have now though if i was to just install the 6 lug disk fronts for the this year.
01-12-2025, 06:40 PM | #29 |
I will make a list, put it here, for you. Maybe others will chime in. THere's one guy here, that knows, a lot (not me).
In the area of converting to 6 lug disc. You need to make sure that what ever wheel you have will work with the disc calipers. many drum brake wheels will not work... Posting a picture of the inside of the wheel here, will help. Disc brakes require a specific master cylinder. I've seen some folks use a drum M/Cyl, but I would not for safety's sake!!! Last edited by 68Gold/white; 01-12-2025 at 06:42 PM. Reason: bla |
01-20-2025, 10:46 PM | #30 |
Pretty stoked on this.. found a guy that had a TMI buddy console he didn’t end up using so I was able to get it from him for a decent price. I’ve been trying to find a “easy” solution on how to fit three people on those warm summer cruise nights or ice cream runs with my young son and lady however the floor shifter was mounted in a terrible location and without changing up the whole layout a bench seat just will not fit unfortunately. The leather doesn’t exactly match but with alittle conditioner I believe I can get the new console to match these old buckets alittle better.
I have a guy locally that is going to work up some custom brackets and after alittle finessing I think it’ll work out perfectly for what I’m looking for.
