12-18-2024, 11:13 PM | #101 | |
Re: Bucketlist Blazer -Restomod build 6.6liter L8T
12-19-2024, 09:07 AM | #102 |
that is the worst feeling!
12-19-2024, 11:20 PM | #103 |
Well, I am done rebuilding the NP205 and I can honestly say that I would rather have someone kick me in the nuts than to have to rebuild another one of these. I have sealant all over the place and it took a bazillion years for me to get the stupid shift pin thingies lined up correctly. My beautiful painting has become scuffed and I will probably just spray it a single color once I have it in the vehicle.
The worst part is that I rebuilt it in my basement because the garage is cold and does not have a suitable table. I have to carry this big F-ing thing up the stairs and into the garage. Not looking forward to that! At least I was finally able to use the speedo fitting thingy that I bought two years ago. I am definitely looking forward to not seeing that leak anymore. Oh!!!!! And apparently the ols freeze plugs do not fit the new case. I gotta get that figured out. |
12-20-2024, 09:45 AM | #104 |
carrying a 205 up stairs ... you and the 2 other ppl better wear steel toe boots!
good thing about the 205 is it'll never need rebuild again. i shaved my shift rails so i could run a true twin-stick in my '93 Ram tow rig. ground too much and had to weld it back, got pretty good at getting those rails in and out. |
12-21-2024, 10:04 PM | #105 |
Good news is, My motor is in and has clearance all around. I have space to move the motor up to two and a half inches forward if I want or need to. In the snow and at temps around 20 degrees F I managed to"embrace the suck" and dealt with the cold to get this thing in here. I will be going with 1.5 to 2 degree down tilt on the motor to clear my oil dipstick on the back of the motor. it is in a weird location but works. It is the one that came with the motor. The motor sits about a quarter inch more toward the passenger side. That is less than my LS swap Regal had so I am good with it. I still have to take the mounts back out and paint them. Other than that, the motor is mounted.
Now the bad news- The factory dual alternator setup will not work out. There is not enough space between the drivers side frame rail and the second alternator. I can deal with that though. I am going to warm up a bit and then head out to my icebox of a garage to test fit the down pipes and start planning the pipe path. I can't really make it official until the trans and transfer case are installed. I I am dreading carrying the 140 pound transfer case out of the basement. I was supposed to do it today but I just could not. I will soon but for now I am not touching that thing. I will upload pics in a minute. Right after a hot coffee or cup of tea. I am very pleased today!!! Last edited by NDM; 12-21-2024 at 10:10 PM. |
12-31-2024, 11:48 AM | #106 |
Active Member
Looks awesome in place. Great work
Restoring a 1972 K5 CST Highlander, White on Parchment w/ Black Top Restoration Diary ------ Current WTB Thread https://67-72chevytrucks.com/vboard/...d.php?t=856079 |
01-02-2025, 12:50 AM | #107 |
This forum is much harder to post pictures. I have been working diligently, posting on my car audio forum with easy pic uploads and want to get this forum up to speed on my progress so there will be a bunch of info coming. Here I go.
In a stunning reversal of my post about the dual alternators, I am pleased to announce that I am 95% sure that bu trimming the fender liner, the second alternator should fit after all! Damn..... now I have decisions to make. I did say that I was 95% sure. That 5% is a real pain. Notch the frame slightly or forget having dual alternators? To make matters worse, the factory VIN stamp is right where the notch would be. I could cut right up to the vin stamp to avoid it. Is it really worth it though? I could modify the alternator and just solder directly to the pins (delete the connector). That would not be too bad. I am going to cut into the connector on the alternator and solder directly to the pins. Technically I only need one of the two pins but since it is a pwm alternator I will just do both pins. That should give me over a half inch or so for engine movement. audionow said: What about taking the alternator apart and turning the rear half 90 degrees? Omg! I never even thought of that! I will investigate that in the morning! Thank you! My ADHD was never going to let me wait until tomorrow to try this. It took an hour to figure out how to do it but my 2nd alternator is successfully installed because of your suggestion. I have about 3/4 inch clearance to the frame too! Thank you so much for that suggestion. I never would have seen the solution without your comment. |
01-02-2025, 12:58 AM | #108 |
Motor is in. I decided to move it rearward about 1.25 inches. This allows me to clear the front driveshaft betterand I will be less likely to hit the hood with this tall a$$ hi ram intake. Trans is sitting on the spacer that I fabricated allowing me to use the factory trans crossmember. I am pleased with the 4.1 degree angle that I have as result (pic shows 94.1 degrees on the transfer case flat). I had to cut and weld my transfercase shifter to clear the hole after moving everything. I will need to move my amps to get it to shift into 4wd lo. I may just move them forward about a half inch.
I still need to add spacers and drill new holes for the transfercase support bracket. I am definitely ready to get this project moving. The great weather that I have enjoyed will not be around forever. The garage has been very comfortable as I lay for hours on the cold floor. I am making steady progress though. I finally made my decision on the Holley wiring entry location. I drilled a big ole 3.25 inch hole and placed two thirds of my aluminum grommet to allow the gasket maker to cure. The ecu will go either under the console or under the drivers seat. Both locations will protect from the elements when the top is off. Oh, and a random picture of the sexy beast getting ready for exhaust fabrication! Wiring has been run and I am now fitting the exhaust. The path over the transfer case was worrying me alot but ended up fitting perfect with a single square cut and one of the S bends that came in the kit with no modifications. The driver side did not fit without removing the trans shifter bracketry. I may modify it to match the passenger side and put the mufflers in the exact same spot and position on both sides. For now I am done for the night. Tired from New Year with family. And now this forum is up to speed. |
01-05-2025, 06:49 PM | #109 |
Core support is back in with the radiator and fan. It fits extremely well. I installed the fuel line to the e85 sensor thingy and installed the refreshed heater box. I also started fitting the air intake and figured out how I will be running the power steering lines. I need to hurry up and get the drivers side fender back on because my wife is tired of it being in our dining room. I moved as much of my parts indoors as possible because of the cold and snow dusting that we got.
01-05-2025, 06:52 PM | #110 |
Spent the better part of another day under the Blazer. Got the H-pipe mostly worked out. I may clamp the actual cross pipe because it could contact the driveshaft should I ever decide to lower it. I might want to retain the ability to remake that part. For now there is plenty of clearance.
I threw the mufflers on to test fit them. So far so good! Tomorrow I would like to finalize the exhaust and move on to the next thing. |
01-06-2025, 01:29 AM | #111 |
Another good bunch of accomplishments today.
Radiator hoses are done!!! I was able to use adapters to adapt the hoses from the donor motor to the larger sized pipes on the radiator. A trim here and a trim there and they worked like a charm. That is a huge win because hunting for correct hoses can eat some serious time on a motor swap. Exhaust is 90% complete. It is complete enough that once I get some hangers in there and the clamps that will be coming tomorrow, I could throw on some turn downs and call it a day. I will likely do that just to expedite the process. My Regal has been in this state since 2020! LOL! I am officially on the v-band bandwagon. These things are so easy to install and weld. They are way more secure than band clamps and simply look great! I have learned that it is better and easier to weld the inside seam vs welding the outer lip. I also do not have to back purge or use solar flux when welding the inner seam. I did two of them on the outside seam and quickly decided to do all other ones in the inside. As an added benefit, if they failed, it would be at the heat affected zone. in the unlikely event that the weld failed, they are still held with about a quarter inch lip. I also kind of decided how I want the intake to be and unfortunately I have to deal with either weld seam which will destroy the powder coating or I will have to have a coupler. I am going to go with a coupler for now and maybe refinish it with a weld in the summer so I can cera-koat the pipes in the summer heat. It is definitely getting closer to that glorious moment where I can drive for the first time!! |
01-11-2025, 08:53 PM | #112 |
The last mile in always the hardest!
A few things have taken me forever. One is being that I am back to work after the holidays. The exhaust routing has hurt my brain. I finally got hangers in a good spot. I re did the H pipe to add more driveshaft clearance. I plan to drop the Blazer about 4 inches to get a more trackhawk/trophy truck look. The driveshaft would never have made it. I re-did the harness wiring and ecu location. The plan is to elevate the console up front sub enclosure and add a cover over the ecu. This will keep any elements off of the Ecu. I abosolutely hate the grommet that I chose to use so I rebuilt it with my own silicone gasket. I cut it out of some super stretchy silicone rubber that is made for kitchen counter protection. Silicone Mat https://a.co/d/eGBGAQx I installed the OBD2 port under the dash but I think it is going to be relocated to near the driver door under the dash near my wideband gauge. I also installed my brand new heater controls. That sucked to do with my amps still installed. The new stuff looks way better! I am getting there but sincerely want to be done with this and get to the enjoyment phase. |
01-16-2025, 07:02 PM | #113 |
This article is more supporting documentation of why I chose this motor. I think I may just keep it naturally aspirated after all. 723 hp with only a few mods and no turbo or supercharger. Wow that makes me happy. I am glad that testing is finally getting going on GEN V gm motors!
For the record, a trackhawk weighs about 5356 pounds with 707 hp. My K5 blazer weighs about 4300 pounds. A 700hp K5 would be the same power to weight ratio as a 871 hp trackhawk. (Yes, a trackhawk has more magic to it than that) https://www.lsxmag.com/tech-stories/l8t-to-the-party-cnc-ported-heads-for-max-effort/ https://www.lsxmag.com/tech-stories/...or-max-effort/ |
01-21-2025, 09:50 PM | #114 |
Wiring is about 90% complete. I have to connect a couple grounds to the chassis and wire the fuel pump once installed. I use 12 chord (waxy twine) secure everything vs cable ties. I learned how to lace cable in 1998. I used to do it for entire workdays plus overtime. I am not a cable lacing artist anymore but I find it to be a great alternative to cable ties and the twine rolls last forever it seems. Although I call it 12 chord it is actually 9-ply lacing chord.
I ran out of argon for my tig welder on friday. I will replace my two small bottles with fresh stuff and get back on my 304 stainless fuel tank today. That is the biggest remaining project. It was going to be a 31 gallon tank but I am going to give up a gallon in order to make 4 inch channels for exhaust pipes to clear the axle. It should be pretty slick. I may wrap the pipes or just do an aluminum heat shield between the exhaust and tank. I am not quite decided on the final exhaust layout yet though. Fabricated a quick adapter bracket for the drive by wire pedal. Just needs paint. |
01-21-2025, 09:51 PM | #115 |
Hell yeah. I had a rough day at work but came home to two packages. The first was the fitting for my power steering return line. This makes only one more part that I am waiting for to finish the power steering setup.
The other part was a Lokar ACA-1809. I finally found a part that just fits! It fit, and works exactly as it should with no modifications. I was worried that it would be a BS part like some others but it is worth the $$. There is JUST ENOUGH space in park to the trans cooler fitting. |
01-23-2025, 12:19 PM | #116 |
What is the obd2 port for?
01-23-2025, 12:20 PM | #117 |
01-23-2025, 03:26 PM | #118 |
01-23-2025, 04:37 PM | #119 |
The Tcm is inside the trans. The trans controller talks to the holley and the trans like a translator. You can also change trans parameters and tuning from the device. Its just like a diablo or superchips type of device.
