Old 01-10-2025, 08:15 PM   #1
KyFarm
KyFarm's Avatar
Fuel pressure sensor leak
Put a HT383 in my 69 K10 and after running a bit installed a ProFlo4 on it. After driving a bit I’ve developed at small drip fuel leak from the threads of the fuel pressure sensor, tried to tighten the sensor and that didn’t fix it. Removed the sensor and checked threads on sensor and fitting, all look good.
the sensor isn’t built like it should take a bunch of torque and doesn’t have an o-ring.
It’s an edelbrock 3546 sensor with 1/8 -27 npt threads.
Does anyone know of a trick to get this sealed?
Tighten it until it seals or cracks? This seems like a good way to develop a crack later and burn your truck down.
Thanks for any help.
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 01-11-2025, 12:21 AM   #2
Willshook
Re: Fuel pressure sensor leak
NPT needs sealant; it won’t fully seal dry.
Willshook is offline   Reply With Quote
Old 01-11-2025, 09:32 AM   #3
KyFarm
KyFarm's Avatar
Can you suggest a sealant that works on fuel lines?
Old 01-11-2025, 12:08 PM   #4
Willshook
This is my go-to:
https://www.permatex.com/products/ga...-liquid-16-oz/
It’s fuel-safe; the key is not to apply it a bit higher on the thread and not on the tip of the fitting.
Old 01-11-2025, 12:20 PM   #5
Dead Parrot
2nd on the need for sealant. Plumbers use sealant on nat gas NPT threaded plumbing and that is less then 1psi for most residential uses.
Dead Parrot is offline   Reply With Quote
Old 01-11-2025, 12:24 PM   #6
KyFarm
KyFarm's Avatar
This is my go-to:
above you say NOT higher on the thread and NOT on the tip of the fitting.
I've always applies sealants higher on the thread and NOT on the tip, is that what you meant?
Old 01-11-2025, 12:58 PM   #7
Willshook
Bad wording on my part - "higher" to me on a fitting means closest to the hex.
You're right - bottom line is we don't want that junk in the fuel system.
Old 01-12-2025, 01:37 PM   #8
Orange Crate
Orange Crate's Avatar
I can't see the electrical connector pins in any of the pics online so one issue to look at is if the sensor grounds through the case/body. Sealant could prevent good grounding. If the connector is two wire you don't need to be concerned as it will most likely be grounded at the FI ECU. If it is a one wire connector you might see some pressure discrepancies at the display, or calculations could be inaccurate.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 01-12-2025, 02:12 PM   #9
Willshook
Typically, if it was grounded through the mechanical connection it would have NPT*F* thread, which does not require sealant.
Old Yesterday, 11:50 AM   #10
KyFarm
KyFarm's Avatar
Well, I have a bottle of Permatex 80019, it's less than a year old and I've tried to seal this stupid sensor twice now and same result each time.
Maybe my 80019 is a bad batch, it you drop a bit on a paper towel and let it sit out for a few days or more its still gummy and a drop of gas will make it real thin. No way this stuff is gonna seal this fitting that has gasoline under pressure against it.
Does anyone have another product they recommend for gas line sealant?
Old Yesterday, 01:13 PM   #11
Willshook
The stuff separates such that you have to stir or knead the tube before using.
It never really "sets" completely. I don't know of anything else that's fuel safe, and everyone I know - car and aircraft - uses it.
Maybe take a hard look at the fitting and sensor to see if it's got a hairline crack? What kind of fuel pressure are we talking about?
Old Yesterday, 01:23 PM   #12
KyFarm
KyFarm's Avatar
Thanks for that, good to know that it isn't supposed to completely "set". I definitely did stir the product before using it, stirred it a bunch, doesn't look separated or bad at all.
Only running 40PSI +/-
really starting to think there is an imperfection in the threads somewhere, although I can't see or feel it.
Old Yesterday, 01:38 PM   #13
Getter-Done
Getter-Done's Avatar
I have used this with great success on my Tractor fuel system.
Here is a Link below if you are interested.
Link: https://www.homedepot.com/p/GASOILA-...SS04/300281345
They even make thread tape which I have not tried.
Link: https://www.oreillyauto.com/detail/c...ufacturer=true
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old Yesterday, 01:41 PM   #14
KyFarm
KyFarm's Avatar
thank you, I have this question on another forum and this is the second recommendation for that product. I'm gonna try and pick some up today before I order a new sensor.
