01-11-2025, 06:57 PM | #5176 |
Re: What did you do to your truck today.The 3rd chapter
finally got him inside today
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
01-12-2025, 11:44 PM | #5177 |
Well; it wasn't today but a couple of days ago I got my freshly painted hood and cowl cover back on Otis and all adjusted up... so back to normal again.
01-19-2025, 05:01 PM | #5178 |
static drop: 2" front/3" back
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
01-19-2025, 11:59 PM | #5179 |
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
01-20-2025, 04:08 AM | #5180 |
No pix, but today, a friend and I attacked my Starter problem on a '71 GMC Jimmy: 350 SBC/SM465/NP205/D44 Front, 12-Bolt rear, 3.73 w/Auburn posi.
[No-Start Gripe.] We had to pull the Header on the passenger side to get to the Starter. Since I want to paint the Hedders white, anyway, we'll have to pull both. We got the passenger side off. Took the Starter into O'Reilly's for test and check. Flunked the Solenoid test. No surprize since it was installed 4/2008. [Lifetime Checker Auto warranty.] I had used an aftermarket Accel solenoid. That was shot -- the cap was loose, Solenoid is trapped behind the header so it got a lot of vibration and heat cycles in 16 years. I have a NIB bendix-type solenoid on the shelf. Gonna hook that on and go back for another test tomorrow or Tuesday. Meanwhile to get the drivers side header free, I'll have to disassemble the whole Z-Bar and Clutch Pushrods and Clutch Fork business. We ran out of daylight today.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 01-20-2025 at 07:18 PM. Reason: white, |
01-20-2025, 06:53 PM | #5181 |
The only thing I completed today was achieving excessive levels of frustration, lol. Craftec Tonneau is nigh impossible to get into the groove once any two sections are in. Gave up for the evening. Can't use any screwdrivers or tools because if you slip, cover gasket will be toast. Heat only makes it worse. Heckuva way to close out another wise successful day in regards to rust repair and stake pocket filling.
01-22-2025, 11:53 PM | #5182 |
It was a nice day today, so I took Otis and got the oil changed, then took him to the handwash and got all the barnacles off.
01-23-2025, 12:39 AM | #5183 |
Got a rebuilt Starter from O'Reilly's today. Rolled over to Harbor Freight to get a new creeper. If I like the weather, I could reinstall the Starter tomorrow.
01-23-2025, 10:13 AM | #5184 |
Installed the rechromed/restored T handle and nice original control assembly on the Blazer's liftgate. With all new correct bolts and screws, new strikers, NOS latches, and misc parts the total was around a grand to make it like OEM new.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Yesterday, 06:17 AM | #5185 |
I got the front end of my K/1500 '71 Jimmy up on jackstands, so I'd have more ''noseroom'' when pulling the underworld from my rig.
Got the replacement Srarter from O'RAP. Pure China Black. Swapped out a shelf goodie, a Mexican bendix-type solenoid for the Asiatic one that came with the device. Better quality. The USA-made Accel solenoid was burned out after 16 years. The ''spare'' Hedder gaskets I thought I had were also used. So, tomorrow, I'm picking up a fresh set of Hedman Hedder gaskets from Don's Hotrod Shop, which, sadly, may be folding.
Yesterday, 12:16 PM | #5186 |
Sweet do you have build thread ?
Yesterday, 12:19 PM | #5187 |
Unfortunately, no.
Today, 05:00 PM | #5188 |
3 out of 4 cab supports repaired! Luckily there was enough good metal on them to patch by cutting up new sets.
Today, 07:05 PM | #5189 |
At the body shop.
Replace bearings and brake pads in the oriellys parking lot on my kids C10 count.
About welded them together, had to use a puller to get the rotor off. Moments from disaster i think.
" That didnt make it any newer " " Dont antique the equipment " |
Today, 08:21 PM | #5190 |
Who Changed This?
^ I bet there's another 30 feet in that bearing...
