Old 01-23-2025, 08:12 PM   #1
Orefactory4x4 swb
Active Member
Exhaust question
Getting close to doing the exhaust on my 72 k10. And wanting some advise
350 /th350 and wondering about headers . What’s the best fit so I order them right first time around.
Orefactory4x4 swb is offline   Reply With Quote
Old 01-24-2025, 11:50 AM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Exhaust question
Are you tucking the exhaust up inside the frame rails? If so, order a set of headers for a 68-72 Chevelle. They are full length, but don't extend down below the frame rails like the truck headers do. If not tucking it up, the headers for your truck application should work. As far as tube diameter, that depends on the engine. If it's stock, 1 5/8 will work fine. If it's a little hotter, go with 1 3/4 or larger, depending on how hot it is.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-24-2025, 06:37 PM   #3
Sheepdip
Sheepdip's Avatar
My personal taste is to add an "H" pipe for best blended sound and exit out the side or back, dumping underneath the truck will rattle your brains out, not to mention every time you get off the pavement or on dirty pavement you will look like a helicopter landing.
Just my .02 worth.
Sheepdip is offline   Reply With Quote
Old Yesterday, 03:09 PM   #4
Orefactory4x4 swb
Active Member
Thanks to you both for your time and information.
There’s so many ways to go it gets confusing on what to order.
Old Yesterday, 10:20 PM   #5
Mike C
Mike C's Avatar
The 4 wheel drive truck headers don’t extend below the frame. The exhaust is routed over the transmission crossmember in the 4x4 unlike the 2 wheel drive that drops below. The two wheel drive headers will usually interfere with the front driveshaft if installed in a 4x4.
My own experience with headers and 4x4 was in my Jimmy. Headman was the 3rd set I tried and the only that would clear the OEM mechanical clutch linkage.
No issues with the Headman’s, but I elected to go with the Corvette 2 1/2” manifolds and unless you are looking to make hot rod power versus truck power, would recommend the same to you.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old Today, 01:41 AM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Curious as to why you want headers unless u have a 600HP motor ? The factory rams head manifolds flow 90 % as good as headers for most applications.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old Today, 12:57 PM   #7
kwmech
^^^what he said
Old Today, 03:22 PM   #8
Orefactory4x4 swb
Active Member
Just wanting to go the right direction to clear shift linkage and other issues that might come up. Seems like most guys went the heated direction so that got me thing that. But I’m thinking I’ll go like mike said and go the corvette 2 1/2.
The stock original ones are still on the motor I pulled. What are they compared to the 2 1/2. They dump straight down and not out the back like I’m seeing in some online
Old Today, 09:23 PM   #9
Orefactory4x4 swb
Active Member
Order some center dump 2 1/2 manifold s off summit
