01-23-2025, 08:12 PM | #1 |
Active Member
Exhaust question
Getting close to doing the exhaust on my 72 k10. And wanting some advise
350 /th350 and wondering about headers . What’s the best fit so I order them right first time around. |
01-24-2025, 11:50 AM | #2 |
Re: Exhaust question
Are you tucking the exhaust up inside the frame rails? If so, order a set of headers for a 68-72 Chevelle. They are full length, but don't extend down below the frame rails like the truck headers do. If not tucking it up, the headers for your truck application should work. As far as tube diameter, that depends on the engine. If it's stock, 1 5/8 will work fine. If it's a little hotter, go with 1 3/4 or larger, depending on how hot it is.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
01-24-2025, 06:37 PM | #3 |
My personal taste is to add an "H" pipe for best blended sound and exit out the side or back, dumping underneath the truck will rattle your brains out, not to mention every time you get off the pavement or on dirty pavement you will look like a helicopter landing.
Just my .02 worth. |
01-25-2025, 03:09 PM | #4 |
Active Member
Thanks to you both for your time and information.
There’s so many ways to go it gets confusing on what to order. |
01-25-2025, 10:20 PM | #5 |
The 4 wheel drive truck headers don’t extend below the frame. The exhaust is routed over the transmission crossmember in the 4x4 unlike the 2 wheel drive that drops below. The two wheel drive headers will usually interfere with the front driveshaft if installed in a 4x4.
My own experience with headers and 4x4 was in my Jimmy. Headman was the 3rd set I tried and the only that would clear the OEM mechanical clutch linkage. No issues with the Headman’s, but I elected to go with the Corvette 2 1/2” manifolds and unless you are looking to make hot rod power versus truck power, would recommend the same to you.
Yesterday, 01:41 AM | #6 |
70+ ( Old Skool Club )
Curious as to why you want headers unless u have a 600HP motor ? The factory rams head manifolds flow 90 % as good as headers for most applications.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Yesterday, 12:57 PM | #7 |
^^^what he said
Yesterday, 03:22 PM | #8 |
Active Member
Just wanting to go the right direction to clear shift linkage and other issues that might come up. Seems like most guys went the heated direction so that got me thing that. But I’m thinking I’ll go like mike said and go the corvette 2 1/2.
The stock original ones are still on the motor I pulled. What are they compared to the 2 1/2. They dump straight down and not out the back like I’m seeing in some online |
Yesterday, 09:23 PM | #9 |
Active Member
Order some center dump 2 1/2 manifold s off summit
Yesterday, 11:52 PM | #10 |
The truck center dump manifolds are a 2”outlet. The Corvette manifolds are 2 1/2”. The 2 1/2” manifolds are only center dump. If you do the area of a circle using those numbers, the truck manifolds have 3.14 square inch opening while the ‘vette manifolds are 4.9 square inches. A significant increase in volume. Then run 2 1/2” exhaust all way out.
If you are concerned about linkages and clearances, best to avoid the complication of headers IMO.
Today, 12:35 AM | #11 |
Active Member
The ones I ordered are 21/2. Thanks for your help and insight mike
