Old 01-21-2025, 10:24 PM   #1
Bodied67
Bodied67's Avatar
Where to find 15 inch 6 lug wheels for front disc conversion
As i gather all the parts and info needed to convert my truck to 6 lug front disc, id like to retain the current steelie style wheel and my tires to try and save some coin.
Anybody have input on where to source new 15 inch 6 lug front wheels that will fit 10.5 dog dishes and clear the new discs? I read on a old post that you could run spacers on original 3 nub drum specific wheels but i only saw that mentioned once so I'm not sure how much truth there is to it. Anybody?
67 SFBD C10 (sold)
69 C10 "Nosejob"
23 Raptor
Bodied67 is offline   Reply With Quote
Old 01-22-2025, 12:05 AM   #2
oneshotkyle
Re: Where to find 15 inch 6 lug wheels for front disc conversion
I currently have 15” drum 3 nubs on mine with cpp disc front. I am running a 1.5” spacer on all 4 corners at the moment. In the near future i am looking to update to the correct offset white steel wheels to keep hubcaps. Absolutely no rubbing issues with a 5.5/7 drop
oneshotkyle is offline   Reply With Quote
Old 01-22-2025, 02:09 AM   #3
Rust_never_sleeps
Rust_never_sleeps's Avatar
I have the original 15" 3 nub wheels, and I used spacers
Baer 3/8" spacers:
https://www.summitracing.com/parts/bae-2000040
I used this brake kit:
https://www.summitracing.com/parts/c...ckup/year/1970
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 01-22-2025, 10:05 AM   #4
Bodied67
Bodied67's Avatar
There we go. I guess I don’t have to buy new wheels right away after all. Drop spindles and spring up front? Notched rear?
Truck has a killer stance man!
67 SFBD C10 (sold)
69 C10 "Nosejob"
23 Raptor
Old 01-22-2025, 10:06 AM   #5
Bodied67
Bodied67's Avatar
Baer 3/8" spacers:
Spacers it is. Thanks for the info!
67 SFBD C10 (sold)
69 C10 "Nosejob"
23 Raptor
Old 01-22-2025, 01:18 PM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
I think any stock wheel from a 4x4 from 71 and up will work.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-22-2025, 03:38 PM   #7
Rust_never_sleeps
I spent about a year looking for 4 nub steelies, and really didn't find much. Those things were everywhere for a while I guess.
I might have gone with trailer wheels if'n I had heard of the things at the time I was looking. ~$60-70 a corner for straight wheels with fresh finish doesn't suck, assuming they'd take my P01 covers
Code:
            __
     ______|__]\____
Old 01-22-2025, 04:28 PM   #8
typerr
I'm running these from Wheel Vintiques with no spacers required. Hub caps fit great. https://wheelvintiques.com/all-wheel...backspace.html
typerr is offline   Reply With Quote
Old 01-22-2025, 06:11 PM   #9
WorldsCrappiestTruck
Active Member
I have a similar setup, using wheel Vintique steelies from Summit. They cleared the discs fine. They hit on the portion of the spindle that the tie rod mounts to, at full turn/lock.
I really dislike it.
WorldsCrappiestTruck is online now   Reply With Quote
Old 01-22-2025, 07:21 PM   #10
Active Member
I have a similar setup, using wheel Vintique steelies from Summit. They cleared the discs fine. They hit on the portion of the spindle that the tie rod mounts to, at full turn/lock. 15x8” wheels
Old 01-22-2025, 09:59 PM   #11
Rust_never_sleeps
WV wheels take hubcaps fine, but the wheel covers are a nope
Code:
            __
     ______|__]\____
Old 01-22-2025, 10:02 PM   #12
Bodied67
Bodied67's Avatar
I looked into the wheel vintiques but was kinda on the fence about the width in the front for this reason. Im strongly considering the spacers as a cheap solution for the time being
67 SFBD C10 (sold)
69 C10 "Nosejob"
23 Raptor
Old 01-23-2025, 12:01 AM   #13
oneshotkyle
Yes 3/5 springs and 2.5 spindle 2” block setup. I have eyed these wheels by wheelsmith manufacturering and they have 17 and 18s that fit our caps. 7,8 and 9” wide and anything over is a custom price. I have the fronts figured out with offset and all so i need to buy a couple and figure out what i can get in the rear Anybody use these on the forum im all ears……
Old 01-23-2025, 01:12 PM   #14
68Gold/white
Cooper Restorations has stock 15 inch wheels, several widths........
68Gold/white is offline   Reply With Quote
Old 01-23-2025, 06:09 PM   #15
Active Member
That’s a great find right there. Curious to see what backspacing options there are, and the price. That’s exactly what I was after - larger but still simple / basic looking. Thanks for sharing.
I’ll try to give a ring tomorrow to see pricing and other options.
Old 01-24-2025, 01:36 AM   #16
oneshotkyle
Let us know what you find out
Old 01-24-2025, 04:48 PM   #17
Active Member
I spoke with a fella today who was very polite and helpful. I specifically asked about the 18x9 and 18x8 wheels….not the 15”. Sorry.
The 18’s have backspacing options in the 3.5-7.5 range, in 1/4” increments. They gave me exact numbers but I didn’t have a pen to write them down.
18x8 wheels are approx ~$300/ea. 18x9 are ~$310
They come BARE steel, no primer but can be powder coated many different colors for $75/ea.
For a set of 18’s….it’ll kill $2k by the time you buy, powder coat, ship and sales tax them to your door.
Old 01-24-2025, 09:03 PM   #18
oneshotkyle
Expensive none the less but cool that we have some oem look a like steelie options. Im on the fence with 17 over 18 but know i meed more thean 15s since my rear shocks sit lower than bottom on 15 wheel
Old Yesterday, 02:37 PM   #19
michael bustamante
michael bustamante's Avatar
Piano avoid the spacers just find 73 on up square body 15 in Wheels you will know them as they will have four nubs instead of three and we'll clear disc brakes just fine
1967custom
michael bustamante is offline   Reply With Quote
Old Yesterday, 04:12 PM   #20
Bodied67
Bodied67's Avatar
Ive been on the hunt lately, no luck locally but i hope i can source a pair in the future before spring time, until then I'm gonna run the spacers
67 SFBD C10 (sold)
69 C10 "Nosejob"
23 Raptor
