Old 01-20-2025, 10:40 PM   #1
Mendo70C20
Mendo70C20's Avatar
Engine troubles (carb)
I have a 70' K20 with a Blueprint 383 stroker and Holley 750 carb. Truck was running fine, and then recently, i can't keep it running. I pump the gas pedal twice, crank it over and she fires right up, i then keep the RPM's at 1500 or 2000 to let it warm up. If i let the RPMs drop below 1500 she'll start to stall out and i can't catch it, or stop it by giving more throttle. Then once she's stalled, she won't start again. Just cranks. I've tried keeping it floored, pumping the gas, you name it, won't start back up. First thought was a plugged needle thing thats below the float bowl adjustment screw, so i pulled that, blew it out and reinstalled. No luck. Then i thought maybe a vacuum leak, so i checked all my vacuum hoses, and they all look good. If the truck would stay running i'd try spraying starter fluid around the base of the carb or near vacuum lines to double confirm no leaks, but i can't keep her running. Fuel filter is full of fuel. Both sight windows for the front and rear float bowls have fuel. I'm kinda baffled. Thoughts?
Mendo70C20 is offline   Reply With Quote
Old 01-20-2025, 11:09 PM   #2
HO455
HO455's Avatar
Re: Engine troubles (carb)
What is the choke doing?
There is a test that can be done but it has a dangerous element to it. Put some good leather gloves on and when truck is running hold your hands over the carburetor. Your trying to slowly choke the air off to the engine. If you can block air off and get the engine to run better then the engine is running lean or getting too much air. Could be a vacuum leak or a bad gasket in the carburetor or other internal carburetor issue.
If the problem gets worse then the engine is getting too much fuel. Could be stuck/sunken float, bad gasket in the carburetor, too much fuel pressure or several other things.
If this only makes the engine mildly worse then I would dive into the ignition system. As they say 90% of all carburetor problems are electrical.
DO THIS AT YOUR OWN RISK!
Carburetor backfires can cause burns.
Good luck and keep us posted.
RIP Bob Parks.
Old 01-20-2025, 11:28 PM   #3
Mendo70C20
Mendo70C20's Avatar
It's just odd that it was running great then now this.
Old 01-20-2025, 11:54 PM   #4
Rust_never_sleeps
Rust_never_sleeps's Avatar
Cliff's "tip-in" test is a less flame-worthy version of the above procedure
I'm not sure from your description whether that's where the problem lies, but it might help to rule some things out.
Mine(which isn't a Holley) runs as you describe on a cold day because I currently have no choke, BUT it will restart
You can use our “tip in” procedure to help verify the primary part-throttle calibration. With the engine completely warmed up, set the speed via the fast-idle or idle-speed screw to 2,000 to 2,200 rpm. Gently “tip in” the choke flap or partially cover the choke housing if the choke is not used. Don’t close the flap enough to choke out the engine, but just enough to richen up the mixtures a bit. You should see an engine speed increase of about 50 to 100 rpm. This tells you that your primary settings are just on the edge of lean. If there is no engine-speed increase or RPM fall off some, pull a small-manifold vacuum hose from the carburetor. If the engine speed increases due to the additional amount of incoming air, the mixtures are a bit rich. If you are using an APT carburetor, set the metering rods to provide a very slight RPM increase during the “tip-in” procedure. Verify the settings by pulling off a small manifold vacuum hose; the engine RPM should stay about the same or the engine should slow very slightly. This procedure provides a good starting point. You can now place the carburetor in service and do some real-world testing. Future metering changes may be needed, as some vehicles prefer slightly rich or slightly lean settings for best overall efficiency.
Ruggles, Cliff. How to Rebuild & Modify Rochester Quadrajet Carburetors (S-a Design) (p. 100). CarTech Inc.. Kindle Edition.
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 01-20-2025, 11:56 PM   #5
Rust_never_sleeps
Maybe get a mirror over the carb and see if your accelerator pump is doing its thing
Code:
            __
     ______|__]\____
Old 01-21-2025, 09:58 AM   #6
First thing I normally do with something like you describe is check/change the fuel filter. If it is a see thru one, see if any trash is in your filter that may indicate something got thru and clogged something.. I also spray carb cleaner down breather to see if it clears up everything. IF it starts and still sounds bad I look and spray carb cleaner to check for vacuum leaks. If that didn't clear me up I start going deeper into carb and/or ignition.
Old 01-21-2025, 11:23 AM   #7
1967GMCC20
1967GMCC20's Avatar
Choke settings or Vacuum Leaks, most common. Did UT occur, when Temps drop.
1967GMCC20 is offline   Reply With Quote
Old 01-21-2025, 11:51 AM   #8
LockDoc
The Older Generation
LockDoc's Avatar
If you have never replaced the sock filter on the fuel pickup tube, in the tank, That would be one of my first suspected problems. They do disintegrate and plug up the tube or filter.
https://americanclassic.com/1967-87-...3-8-sku-23-598
They just slip on the end of the fuel pickup tube in the tank. Any parts vendor should have them.
If you think it might be flooding hold the accelerator pedal all theway to the floor when you are trying to re-start it.
Leon
Old 01-21-2025, 01:15 PM   #9
RichardJ
If it's a Holley and running rich, did you check the power valve. Power valve could be blown, loose or bad gasket.
A power valve problem can happen without warning.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 01-22-2025, 11:15 PM   #10
Rich69shortfleet
Yep, blown power valve would be the first thing I'd be checking.
Rich69shortfleet is offline   Reply With Quote
Old Yesterday, 05:11 PM   #11
Mendo70C20
Mendo70C20's Avatar
I am carb stupid and really don’t know anything about carbs, but i will look into the power valve. Unrelated new issue, i just noticed that my distributor is touching the fire wall. I have never noticed my distributor touching my firewall before and I even recently adjusted my timing, and i would have surely noticed it being that tight then. Also recently put a new Tremec 4050 Trans in, and would have noticed my dist. touching after we buttoned it all back up. So now thats my new issue. I checked motor mounts, trans mounts, bolts that bolt the trans to the bell housing, and the bell housing to the engine, all look fine. I’m really baffled as to while i’m tight at the rear of the engine there now…?!?!!?! FML.
Old Yesterday, 09:29 PM   #12
HO455
HO455's Avatar
I would do a complete inspection of the motor mounts and the transmission mount. Some of the motor mounts that are available new are junk! See photos at the bottom of the link.
If the engine shifted and forced the distributor cap into the firewall it may have forced out of position on the distributor causing the rotor to hit the cap which may explain your issues.
Pull the distributor cap and inspect it too.
http://67-72chevytrucks.com/vboard/s...d.php?t=773824
RIP Bob Parks.
Old Yesterday, 09:37 PM   #13
Mendo70C20
Mendo70C20's Avatar
From what i can tell they look fine, but if the engines mount were bad wouldn’t it show somehow at the trans mount? Today i spaced the trans mount up 1/4 in. with washers. that helped get the dist. off the firewall a tiny bit. The boot to one of the spark plugs is still slightly touching but not as bad as before. I’ll pull the dist. cap and inspect next weekend. Time is something that seem to have zero of. And with it getting dark early, i really feel like i have no time. After i was done spacing the trans some, i tried starting it, same thing, fires right up, and as long as i hold the rpms at 1500 it runs fine, but as soon as i let the rpms slip, there’s no catching it and it stalls, then i can’t get it to start again. All of this is frustrating as heck. It’ll have to sit until next weekend.
Old Yesterday, 09:38 PM   #14
Mendo70C20
Mendo70C20's Avatar
oh and the trans mounts are brand new. My brother and i put a new tremec 4050 in just last Nov., and those mounts all are new and looked fine.
Old Yesterday, 09:41 PM   #15
Mendo70C20
Mendo70C20's Avatar
Maybe next weekend i’ll try pulling the motor mounts out to give them a look. They seem fine from what i’m able to see….?
