Old 01-27-2025, 01:18 PM   #1
Michael D
Active Member
Replacement steering columns
Ok here is the stupid question of the day regrading tilt steering columns.
First off the issues:
Just like the other post regarding the gear shift handle fitment, the feature on my column is worn, my tilt is worn and wobbly, the internal horn and turn signal wiring is worn, the turn signal cam assembly is cracked and needs to be replaced.
Ok you get the point.
I can buy just about everything and repair it but aside from the turn signal cam assembly and wiring I believe I’d have to pull the column to replace said wiring along with the rubber grommet at the gauge cluster where it mounts to the dash.
Even doing so I would still have the issues with the column length, a couple inches shorter would be nice albeit not needed.
My questions:
With so many different columns available, varying in price from $250-$1000 WHAT TILT COLUMNS ARE THE BEST BANG FOR THE BUCK AND WHICH SHOULD I AVOID?
Every reproduction seller, LMC, Classic, Holley, IDIDIT, Flaming River, etc. has them, heck even Amazon even sells them.
They’re all wired with neutral safety wiring, new turn signal cams etc. I’ve replaced just about everything on this K10 to keep it looking stock, so repro parts are ok by me. I just need a good steering column that isn’t sloppy and will last until I decide to build a K5.
Michael D is offline   Reply With Quote
Old 01-27-2025, 06:32 PM   #2
LS short box
Re: Replacement steering columns
I didn't use a column shift but I've used Ididt tilt steering columns and have worked well on my hot rod projects.
Couple of pics.
Old 01-27-2025, 07:46 PM   #3
58 Special
Rebuild your original. Relocate neutral safety switch. Shorten intermediate shaft and repin it no problems. Just my two bits.
58 Special is offline   Reply With Quote
Old 01-28-2025, 09:45 PM   #4
StingRay
StingRay's Avatar
Van and RV columns are a dime a dozen. RV columns are generally like new on the shift lever and tilt mechanism. Use those parts as donors to renew yours. Can't beat a genuine GM column.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 01-29-2025, 12:21 AM   #5
dmjlambert
dmjlambert's Avatar
I don't have a tilt steering column but I sent my non-tilt column to a fellow forum member to have him rebuild and shorten it and that was the best deal for me.
Old 01-29-2025, 08:19 AM   #6
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Replacement steering columns
There are a few guys on the board that refurbish the orig. tilt columns, whether it be for floor shift or column shift auto.
Member Don D did my floor shift tilt for my 1970 Blazer and it is a work of art, and functions perfectly.
The aftermarket columns are typically cheaply constructed, and will cost you more in the long run.
Old 01-29-2025, 01:28 PM   #7
KMC3420
KMC3420's Avatar
@70shortfleet is another member who does excellent work restoring original GM columns.
Thread
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 01-29-2025, 01:40 PM   #8
MikeB
MikeB's Avatar
Back in the early 2000s, I bought a 55 Chevy car with an Ididit floor-shift column that had originally been installed in another car of some kind. I wanted to get it shortened, so I called Ididit. They charged me $50 to shorten it, and then they replaced virtually every internal part for no-charge. It came back looking brand new! They even paid for return shipping. Probably the best customer service I've ever experienced.
Later I installed a column shift version in a 66 Chevy pickup, and it worked perfectly. My only complaint was the stick-on gear indicator. Gotta be a better way, and maybe they've come up with something since then.
On another note, a few years ago I shortened my 69's non-tilt, auto trans column by a little over 1". Maybe it was just me, but it was a real PITA, and I couldn't go another inch. Wish I could remember why. The upside was that even 1" helped, and I replaced or refurbished several internal parts and got rid of at least 50% of the slop. It may be something to re-tackle in the future. Finished product below.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-29-2025, 08:23 PM   #9
Sheepdip
Sheepdip's Avatar
Go GM original if you can...I had a horrible experience with Ididit in my 49 Chevy pickup, finally had enough tears in my beer, pulled it out and junked it. Swapped it out for a GM, the GMs are so good I run a shortened one in my 40 Ford Coup.
They are pretty convenient with the back-up lamps and NSS all right there on the column.
Sheepdip is offline   Reply With Quote
Old 01-29-2025, 08:30 PM   #10
dagnabbitt
dagnabbitt's Avatar
And buy off the board if you can. I just got one from 70shortfleet and it is beautiful. If you have a factory tilt, it would be worthwhile asking if someone would rebuild it for you.
If dead set on buying aftermarket, I'd try Flaming River. Avoid anything made in China, a poorly made steering column can kill you.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-30-2025, 02:45 PM   #11
dooguy
had never heard of flaming river. are they american made? price wise,they appear less expensive than the Brothers(Holley) brand
dooguy is offline   Reply With Quote
Old 01-30-2025, 03:24 PM   #12
MikeB
MikeB's Avatar
There's an comprehensive article somewhere on the web about Chinese columns and how they can literally kill you. It was written by an organization in New Zealand that inspects and approves aftermarket parts. Their approved columns were Ididit, Flaming River, and a couple other USA manufacturers.
Found it: https://www.lvvta.org.nz/documents/i...ng_Columns.pdf
As I recall, several well-known US companies were importing and selling the Chinese columns, along with other defective steering parts. Scary.
Mike
Old 01-30-2025, 03:38 PM   #13
dagnabbitt
dagnabbitt's Avatar
I've generally heard only good things about Flaming River. Ididit, good and bad.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-31-2025, 03:50 PM   #14
Michael D
Active Member
Thanks guys, lots of great comments and recommendations. I was hoping to put out another $1k for a column so I may get lucky. It also appears my column may actually be a tilt column from an RV. Im not sure but that said I replaced the turn signal cam and got the gear shift indicator to align but still having problems with the left turn signal cancelling. TBD...
Old 01-31-2025, 04:20 PM   #15
HO455
HO455's Avatar
It's been my experience that when once side won't cancel it's because that spring isn't a factory spring. Aftermarket springs seen to be slightly undersized and won't hit the cancel cam correctly.
RIP Bob Parks.
Old 01-31-2025, 04:23 PM   #16
oneshotkyle
Thread
Just got mine done by 70shortfleet. Best money ive spent. Hard to tell its not new as everthing is perfectly rebuilt.
oneshotkyle is offline   Reply With Quote
Old 01-31-2025, 04:29 PM   #17
KMC3420
KMC3420's Avatar
Originally Posted by oneshotkyle View Post
Just got mine done by 70shortfleet. Best money ive spent. Hard to tell its not new as everything is perfectly rebuilt.
Mine showed up Tuesday this week. They are beautiful. A person would be hard pressed to find one better than the ones Les kicks out.
Keagan
Old 02-01-2025, 12:04 AM   #18
PowerdbyChevy79
PowerdbyChevy79's Avatar
I need to get with this guy...
1966 C10 "Mary"
1967 C10 Custom "Ole Blue"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 02-01-2025, 12:22 AM   #19
Orefactory4x4 swb
Member DonD did me a tilt and it was a excellent job
Orefactory4x4 swb is offline   Reply With Quote
Old 02-01-2025, 02:45 PM   #20
MikeB
MikeB's Avatar
Just got mine done by 70shortfleet. Best money I've spent. Hard to tell its not new as everything is perfectly rebuilt.
That's awesome. I should have let him do mine.
Mike
Old 02-02-2025, 10:10 AM   #21
Joyridin
They are made in Ohio and are junk. Plastic bushings that start to rattle in a year or less. You would be better off buying some Chinese version and immediately tearing it apart to fix the issues than spending $1000 on a FL and having to do the same 6 months later.
As stated, unless there is some reason you cannot use a factory version, go that route every time.
Joyridin is offline   Reply With Quote
Old 02-04-2025, 03:29 PM   #22
chappys4life
I need to do the same! I have some crappy aftermarket in mine now (came in the truck already)
chappys4life is offline   Reply With Quote
Old 02-04-2025, 03:44 PM   #23
dagnabbitt
dagnabbitt's Avatar
Here's mine from 70shortfleet. It's a tilt automatic that has been shortened 2 inches.
We can argue the merits of Ididit and Flaming River all day, but you can't go wrong buying an (almost) original GM part off of a board member.
I am years away from installing it, probably, but I wanted to buy one while I had the chance.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 02-04-2025, 03:59 PM   #24
Michael D
Active Member
actually, I just sent him a check yesterday for the same thing he built you.
Old 02-04-2025, 04:02 PM   #25
chappys4life
That looks amazing. Yes I need one for sure. Why did you have yours shortened? I am still learning the tricks on these trucks
