"Junkyard Dog"
![]() Join Date: Jan 2008
Does a 4L80E clear a low hump floor?
Change of plans (well maybe) on my 72 C10 build. I was going to use a 700R4 behind my 427 BB. The 4L80E would be a much better choice BUT will it clear the low hump floor?
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
![]() Join Date: Mar 2003
Re: Does a 4L80E clear a low hump floor?
Depends on where the engine is, but yeah it should. It'll be tight but it will fit. I don't think the bell area is an larger than a T400. My 69 GMC has a low hump floor, T400 with a big block in front of it mounted in the factory holes. I can get my hand between the lip of the floor pan and the top of the trans. I've actually thought about doing the conversion myself and getting rid of the 400/ gear vendor set up
#3 | |
"Junkyard Dog"
![]() Join Date: Mar 2000
I've never done it but I know that the pinch weld is sometimes trimmed when stuffing a bigger trans into the low hump.
Saskatoon, Saskatchewan Canada |
I put a 4L80E in my low hump 68 behind a 454. It is tight, and I had to raise the tail end as high as I could and shim the rear axle to get the driveshaft angle corrected. But my truck is also lowered 4 inches in the rear. Ended up about 5/8 to 3/4 inch clearance between the trans and the floor. The biggest problem is getting the tail of the trans high enough. The rest clears ok. I couldn't remember so I just went out and looked, and I did bend the pinch weld to give more clearance. I had already bought a high hump to install, but I had fitted a two cup cupholder to the front of the bench seat, and I didn't want to give up the cupholder, so I did it with the low hump.
1968 SWB Step Side, Big Block, 4L80E , Running! Last edited by ZEKE68; 01-30-2025 at 09:03 PM. |
Ls and 4l80e here and i did grind on the pinch weld for added clearance. Gave zero clearance issues and as far back as ls swap mounts go
![]() Join Date: Dec 2014
Although I do not doubt them, these answers really surprise me.
I am going to eventually do the same swap and so I have been looking for a high hump.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
5.3 4l80, no issues at all.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
