08-27-2004, 07:38 AM | #1 |
Tilt steering wheel swap
I am advised that the power steering pump and gearbox from a 1984 GMC will "bolt on" into my 1970 C-10. Will the tilt steering wheel from the '84 also fit the '70 C-10?
Thanks |
08-27-2004, 08:33 AM | #2 |
Cause the Chicks DIG IT!!
somebody can jump in here and correct me if I"m wrong but I'm pretty sure the tilt column won't work, just for the simple fact that the ignition switch is located on the column. Can't tell you anything about the gearbox.
08-27-2004, 10:12 AM | #3 |
its all about the +6 inches
Gear box will work, however it has metric fittings so you'll need adapters/custom hoses.
Column can be made to work, but it is by no means a nut and bolt procedure, the column is larger around, so you need to trim the dash where it goes under the int panel, you'll have to do some wiring for the ignition switch and the wipers. |
08-27-2004, 10:14 AM | #4 |
More Cowbell....
Oh, and also....Welcome to the board from Central Mississippi.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
08-27-2004, 10:27 AM | #5 |
Good call putter...I didn't even notice that.
Welcome to the board from central Ohio. |
08-27-2004, 10:46 AM | #6 |
Left Foot Functioning
Welcome aboard, Philip, from SW Oklahoma! Hope you find this place as helpful as I have.
Here's a thread that discusses the pump swap, including a neat trick from Tx_Firefighter to avoid custom hoses, in case you come up agains the 0-ring seal or metric problem. Power Steering Pump If you've got access to a digital camera, we'd like to see some pics of your truck. SSOW
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
08-28-2004, 09:35 AM | #7 |
Thanks for the tips! I think I'm going to give this a try. Nothing to loose except a little time and effort.
08-28-2004, 10:15 AM | #8 |
I installed a 83 Tilt column into my 70 Blazer.
Requires a new steering sector shaft, dash wiring harness and a bit of fab work to get the column to fit the dash. Nothing a welder and plasma cutter couldn't fix... |
08-28-2004, 12:44 PM | #9 |
Welcome to the board Phillip!!
08-28-2004, 01:11 PM | #10 |
Designated A-hole!
Welcome to the board from South Mississippi!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
