12-04-2024, 06:03 PM | #176 |
Re: Ol' Blue
Raven, this is where I am.
The cab holes are filled in and I've modified the dash in some previous pictures. I think it is ready to sit on the frame and see how it all fits together. So, I started with putting the metal part of the bed on the frame. The doors you see have been body worked and primed and are ready for paint. The fenders, bedsides and other black parts are primed with epoxy waiting for body work. A mechanic I know is planning to come over 12/14 and hopefully we will button up the 5.3 and it will be ready to do the motor mounts on the frame, as soon as I get a tranny to go with it. I need the cab on the frame to set the engine/tranny combo and then that cardboard box under the frame will be taped to the frame to get an idea of how big I can make the gas tank. The tank will be filled through the original filler tube behind the seat, it'll run down through the floor into the tank, once I get it located and have it built.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
12-05-2024, 11:34 AM | #177 |
Re: Ol' Blue
nice cab stand/dolly
did you fit the doors to the cab already and get the gaps like you want them? are you sure you are working in that shop? pretty clean, lol my shop is full of metal cutoffs, grindings and shavings from carbide burrs, been doing a bunch of fitting, welding, smoothing, contouring. |
12-05-2024, 01:02 PM | #178 |
Re: Ol' Blue
Raven, thanks for that. I made that stand for the 48, it's adjustable and of heavy enough material so that I could add in the extensions I made and fit a car body on it. I'm kind of proud of it.
The doors were fit to the cab before they were removed. The gaps were good. Then the edges were welded and finished smooth. The PO just ground the edges down and put a little Bondo on them. They are smooth now. However, I think I want to take the hinges apart to be painted, but that worries me for the fitment of the doors. The hinges are TIGHT right now, and they don't need to be rebuilt. I know some guys just paint them all together, so I'm in a dilemma on what to do with them. Yes, the shop was just cleaned, usually on Sunday after I've been grinding or sanding, or when I need to think about what my next step will be cleaning gives me time to think out there with the project where I can go look at it then go back to cleaning. I haven't made a dump run in months, so there is a lot of old steel to be recycled, and that will give me some more room.
12-06-2024, 12:23 AM | #179 |
Re: Ol' Blue
i find taking pics from different angles helps. leave for awhile then open up the pics and look at them. lots of times I find a flaw or a different way to get something done by looking at the pics. last time it cost me a day cuz i had to move a body lne........lol
12-06-2024, 08:43 AM | #180 |
Re: Ol' Blue
Thanks, I'll give that a try.
12-24-2024, 06:05 PM | #181 |
Re: Ol' Blue
I don't like the factory fit and finish where the A and B pillars hit the inside roof panel. Here are pics of the rider's side. The driver's side is worse, but I didn't have time to move stuff around so I could get over there and take pics.
My thought is to weld and finish as much as possible and then use All Metal or Metal to metal to finish it off. Is that crazy? What do you do with those seams?
12-25-2024, 11:05 AM | #182 |
Re: Ol' Blue
I've seen them welded and smoothed over for the seamless look and I've seen them left factory. smooth definately looks nice but it is a whole lot of work. the gaps can be large and actually fairly deep down in there for welding. I've had the roof skin off several of these cabs and can tell you there are lots of spot welds holding things together. if you were to weld it I suppose it could be stitched every few inches instead of being fully welded. if doing any welding just be carefull of the heat affected zone as this could cause a lot of distortion and there is no way to hammer on dolly there. make sure to do short welds and allow to cool fully before adding more heat in the area.
01-05-2025, 01:31 PM | #183 |
Re: Ol' Blue
Ok, trying to test fit the window and I don't remember what the 2 screws are that held the window glass channel to the window lower seal channel. Anyone?
01-07-2025, 05:57 PM | #184 |
Re: Ol' Blue
Looking good 8man. Going to tag along with your build. Are you going to do anything different with the stock door handles and door locks.
01-07-2025, 06:26 PM | #185 |
Re: Ol' Blue
SDR, I've thought about the latches a bunch. I have 2 friends with the same latches, and they work fine. If I go to the Altman's, I understand it will cause some issues with the single pane side window, and I really want to do it, in fact I've already modified the doors for them. So, I'm going with the stock latches. That allows me to key lock both doors and hand lock them from the inside.
01-16-2025, 02:02 PM | #186 |
Re: Ol' Blue
I finally got the parts to complete the parking brake.
Since I am going to update the braking system with a hydro boost, and the steering column with an Ididit column, I had to have a new way to do the parking brake. Well, 2 actuators, some wiring, a switch and a control board and it'll work. If you are wondering what that cardboard box it, it is a mockup of the gas tank. It will fill through the original position and go through a tube down into the tank under the truck. Frees up some back of seat room, looks original, and gets the gas out of the cab.
01-21-2025, 10:05 AM | #187 |
Re: Ol' Blue
are you able to ise a fuel tank from a newer truck possibly? astro van? something else with a torpedo style tank bolted inside the frame?
01-21-2025, 11:52 AM | #188 |
Re: Ol' Blue
Raven, I don't know. I know a guy in Florida who used this tank design, and he gave me his design drawings, thank you Bob, and it fits so well I'm just using it.
01-21-2025, 11:43 PM | #189 | |
Re: Ol' Blue
01-22-2025, 09:17 AM | #190 |
Re: Ol' Blue
NWA58, that is a beautiful finish out! That is just what I was looking for. I think I'm going to have to try.
01-22-2025, 10:30 AM | #191 |
Re: Ol' Blue
if welding the seam i suggest to really clean the crack well first so it is nice shiny steel. maybe one of those nylon bristle rotary brushes similar to a wire wheel would strip off any foreign material? I have used them inside 4x4 front axle tubes to clean out mud, debris and rust when rebuilding. I found thy will scratch down to shiny steel pretty quickly. maybe just a regualr wire wheel first and finish with a sander would also work. blow the crack out and clean with some acetone, then weld.
01-22-2025, 10:33 AM | #192 |
Re: Ol' Blue
Thanks Raven, that is a good idea. I have some of those wheels to try that with.
I don't think I'll try all the seams, but those where the factory welded them and did a poor job.
01-22-2025, 11:11 AM | #193 |
Re: Ol' Blue
I plan to upholster the headliner in my project. Hopefully keep some heat out, or in depending on the weather, and also help with sound insulating.
Yesterday, 11:31 AM | #194 |
Re: Ol' Blue
I think I have the original door latches and strikers for the 55-59 truck, but I see some differences and wanted to ask for some help in figuring them out. Pictures to come.
Thanks.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 Last edited by 8man; Yesterday at 01:05 PM. |
Yesterday, 01:22 PM | #195 |
Re: Ol' Blue
The second photo shows the two strikers, they are different. Is there a reason for this? Has anyone seen this before?
The first picture shows the latch, without the metal strip/shield, the 3rd photo shows the latch with the metal strip covering the striker. Thanks.
Yesterday, 01:50 PM | #196 |
Re: Ol' Blue
Possibly the difference between a GM part and an aftermarket part.
Mine were from a farm truck and totally worn-out. I had to build up the strikers for the latch to clear the groove worn in. |
Yesterday, 01:51 PM | #197 |
Re: Ol' Blue
I plan to use latches and strikers from a modern vehicle. Like the besrclaw style but a GM part.
Yesterday, 01:53 PM | #198 |
Re: Ol' Blue
Thanks Raven. I thought about Bear Claws, and used them on the 48, but wanted to stay stock looking on this one.
You don't know which is re-pop and which is original do you?
Yesterday, 01:57 PM | #199 |
Re: Ol' Blue
Sorry I don't. All the doors I have had really well worn latches.
Today, 02:00 PM | #200 |
Re: Ol' Blue
I think the top one with an actual thick plate is OEM, and the bottom is a cheaper stamped aftermarket... usually whichever part looks like it was better made was OEM.
The little metal cover on the latch was like a easy-fix-it option to repair a worn out part instead of replacing the whole thing. Often a groove would wear into it from that OEM striker and that little plate covers the groove and restores the alignment.
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
