12-23-2024, 07:51 PM | #276 |
Re: "BUILD: 1970 C10 LWB--->SWB “Jumping Cholla”
I felt your pain brother, when I saw that first picture.... been there done that .....
now and WOW they look real good Merry Christmas to you and your Family
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
12-24-2024, 09:55 AM | #277 | |
Thanks! Merry Xmas to you and yours as well.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
12-29-2024, 05:36 PM | #278 |
We have a finished short bed I let all the painted pieces sit for a few days in the garage during the holidays to fully cure. I got to work getting them bolted together on Friday. Everything came together great. I did have to clearance some of the square holes in the floor with a square shaped file I got from Harbor freight, which worked perfect. Once I got the tailgate hung (All the letters will be a white sticker, I didn't even want to try and tape off and paint them in) I had to get this bed in the sun and check it out. It looks great in the sun. You can definitely see some waves from my rookie body filler work, but I don't care. I learned so much during that whole process and I'm sure it will come in handy for the next build.....
The next day I scuffed up all the panels on the inside of the bed to get ready for a few coats of Raptorliner. Once I got everything prep'd, cleaned up, and taped off, I went ahead and seam sealed all the joints. It took (3) cans of Raptor to get everything coated and (2) cans for the second final coat. The seam sealer really made it all come together in the end. Overall, I'm very happy how the whole bed came out. I was super temped to drop it on the frame now, but I still have a few things to finish up before the bed is covering access to it. For now, it got pushed back to the back patio to sit out of the way until I'm ready for it to meet the rest of the truck. Plus the wife gets her garage parking spot back, only been hogging that space since the beginning of November I think the next thing to tackle is bleeding the brakes and now that the drivers door is repainted, I can install the front fenders and start the painful process for setting gaps on the front clip. Thanks for following along so far.
12-29-2024, 05:40 PM | #279 |
Here are a few pics of the bed with the Raptor sprayed.
12-29-2024, 07:16 PM | #280 |
looking so good .......
12-29-2024, 10:32 PM | #281 |
Paint looks great! Nice work.
12-30-2024, 07:16 AM | #282 |
That looks great Scott! I think we have both learned a ton about body work during our restoration projects. I have waves in my bed panels as well, but it looks better than when I started. Someone once told me that the only way to perfect body work is with $100 bills....lot's of them.
I can't wait to see your truck all put together. Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
12-30-2024, 08:27 AM | #283 |
I think it looks great. Nice work, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
01-27-2025, 10:16 AM | #284 |
Bit of an update, I ordered an American Autowire wiring harness a few weeks and it supposed to ship on 1/30. The last few weeks have been busy with all things of everyday life. I've been doing a lot of organizing of old parts going back on the truck and making a "To Do" list and a "To Buy" list. I created the lists into phases (baby steps) to help me stay on task and finish smaller objectives/projects that add up to completing bigger milestones. It was a good holistic view of what is left to complete on the truck and helped me see the finish line.
I did get the brakes bleed a few weeks ago without issue. I'm not too happy with how the front rubber lines are so close to rubbing on the tires at full turn, so I'm going to have to fix that. I came across pjmoreland's thread on this same issue and will be doing something similar to get it corrected. The last pieces of painting I had left was re-painting the cowl since it had some major metallic runs on both sides and spraying the underside of the hood in black. Both came out great. This past weekend I was able to spend some time in the garage and get a couple of things done. I wrapped the exhaust pipe adjacent to the fuel pump/filter mounted on the inside of the frame for some heat protection. I also threw some heat shield on both mufflers since they're tucked up close to the bed floor. The last piece before the bed goes on is to install the rear shocks (which still need to be bought). I bolted up both fenders and called my Dad and brother over to help put the hood on. After a few hours of adjusting fenders, cab, core support, and hood hinge bolts, I finally got all my gaps and tightened everything down for what I hope is the last time. The truck is getting harder and harder to push around the garage on my dollies with all the weight/parts I'm bolting back on. I'm looking forward to spending some time with the wiring once the harness gets here. It will be nice to start with a clean canvas and a new harness.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed Last edited by loudchevy; 01-27-2025 at 10:32 AM. |
01-27-2025, 10:25 AM | #285 |
Your truck is looking fantastic. I'm interested to see what it's like to install the American Autowire kit.
01-27-2025, 11:55 AM | #286 |
You are making some really good progress Scott! I have been fiddling with my AAW harness as well. Here is a tip for the fuse block.....cut it from the firewall (engine) side. I used an air saw so that it wouldn't heat up the surrounding paint too much. I did order a dual crimp tool from CE auto electric out in Mesa, but it won't ship until February unfortunately. Also, did you get the AAW voltmeter? You won't be able to use your stock ammeter with any of the AAW kits.
Clay
01-27-2025, 12:03 PM | #287 |
chevy truck fan
Scott, the truck is looking great!! you are right with acknowledging the pride of doing it yourself... well deserved! also i like the bed work, question... did you inquire/check into at all about trying to color match the liner? I am looking into doing this on my '86...
again great job!! |
01-27-2025, 12:51 PM | #288 | |||
I was actually looking through your 86 build thread this morning checking out how you did your seats. How is the leg room with those pacifica buckets?
Yesterday, 04:23 PM | #289 |
AAW box showed up today. It looks great and organized very well in separate bags. Looking forward to start getting into it this weekend. Glad "Dry" January is almost over, gonna need a few beers in garage while working on this project
Yesterday, 04:34 PM | #290 |
The AAW kits are excellent quality!!
Clay
Yesterday, 07:05 PM | #291 |
Loving the color you are painting the Truck! looks great! and that kit does look like a couple beers would be a good idea to get through
-------------- 1970 C/10 LWB build thread: https://67-72chevytrucks.com/vboard/...d.php?t=847860 IG- Tip70 https://www.etsy.com/shop/Tip70Designs |
