09-18-2024, 08:19 PM | #276 |
Re: '50 3600 re-do. Shortening things up!
Back at it again. Not optimistic about the condition of the 6.0 with the piston grenading so as a back up I bought a complete running 5.3 for $400 bones. I can sell the accessories and make that back. Not planning anything crazy, maybe. mild cam. Also thinking about sealing the Fitech and either using the stock intake or switching to a Holley Sniper carb for the old school look.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
10-06-2024, 02:25 PM | #277 |
Started tearing it down & it looks pretty decent, cleaned up the carbon build up from the pistons but the cylinders look good. I’ll scavenge the cam from the 6.0.
10-06-2024, 05:07 PM | #278 |
Good buy on the 5.3.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
10-07-2024, 09:42 AM | #279 |
interested to see how the parts look when the bottom end is apart, see how bad the piston skirts look etc.
10-13-2024, 08:11 AM | #280 |
Started tearing into the 6.0. The plot thickens! Don’t know what this cylinder is going to look like but sure it won’t be good.🥺
10-13-2024, 09:27 AM | #281 |
I guess they saved a few bucks on new valve springs, huh?
10-13-2024, 04:54 PM | #282 |
It gets worse the further I tear into it. The head is destroyed, deep gouges I the cylinder wall. $$$ down the drain.😡😡🤬
10-13-2024, 04:59 PM | #283 |
Wow! Not good.
10-13-2024, 05:04 PM | #284 |
and, no warranty.
got pics of the block? |
10-14-2024, 07:47 AM | #285 |
No. It is/was a new build still wrapped on the pallet, but since I wasn’t the original buyer, the warranty was non transferable. I’ll try to get a better pic of the cylinder. In the meantime, here’s the rest os the mess left in the tray.
10-14-2024, 07:51 AM | #286 |
At least, t was able to salvage th cam, lifters & pushrods. I was hesitant about the oil pump but the screen on the pickup tube kept fragments from getting into it so I reused that as well.
10-14-2024, 10:15 AM | #287 |
if it were me I would disassemble the oil pump and check for small metallic debris, clean it all up, imcluding the bypass, lube and assemble. cheap insurance.
10-14-2024, 10:23 PM | #288 |
10-14-2024, 10:25 PM | #289 |
Before and after. Hope to fire it this weekend!
10-18-2024, 08:39 AM | #290 |
the orange just looks proper, good luck!
10-18-2024, 08:37 PM | #291 |
Do you know the cause of the destruction? Is wasn't just a broken spring was it???
10-18-2024, 09:39 PM | #292 |
looks like a valve spring broke, then the valve dropped out, then the piston hit the valve, then the pocket book was hit hard.
10-18-2024, 10:26 PM | #293 |
Wow. Thats something tp think about!
10-19-2024, 08:06 AM | #294 |
That’s what I suspect, especially that last part!
10-19-2024, 10:20 AM | #295 |
More shoddy products???
Yesterday, 08:33 PM | #296 |
After several months of losing interest I decided it was time to bring the thunder! It runs!
Yesterday, 09:04 PM | #297 |
Nice!
