Old 01-27-2025, 12:54 PM   #1
Cemack
Manual to auto swap
Hey everyone, I'm swapping from a manual transmission to auto transmission in a 1972 C10 and am wondering about the brake pedal. From what I can tell on LMC the pedal size is the same between a manual and auto. I'm curious about the spacing between the gas and brake. Is it the same between the two? Also any other tid bits of info on the swap would be appreciated. Switching from 3 on the tree to a turbo 350(i have a turbo 350 on hand already). Putting an auto tilt column out of a van into it. No idea what i will need for linkages. Need a new transmission crossmember, the old one was on the manual bell housing. Not sure what crossmember will fit, one out of a squarebody maybe? There aren't any older c10s around me to get parts from
Cemack is offline   Reply With Quote
Old 01-27-2025, 04:59 PM   #2
Smitty
Smitty's Avatar
Re: Manual to auto swap
You can use the same pedal assembly. Just remove the clutch pedal.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 01-27-2025, 06:06 PM   #3
Racer2172
Pretty straight forward swap, if you want to sell the clutch linakge parts from the firewall to clutch arm id be interested
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 01-28-2025, 02:05 AM   #4
pjmoreland
pjmoreland's Avatar
OER makes a reproduction of the original automatic transmission. I have no personal experience with it.
https://www.jegs.com/i/OER/691/T6772...BoCg0kQAvD_BwE
pjmoreland is offline   Reply With Quote
Old Yesterday, 03:36 PM   #5
HO455
HO455's Avatar
This thread has some good photos of the shift linkage that should help. The linkage connection at the transmission is a bit convoluted.
http://67-72chevytrucks.com/vboard/s...d.php?t=532323
RIP Bob Parks.
Old Yesterday, 05:16 PM   #6
crazyjeenyus
crazyjeenyus's Avatar
I'm in the process of doing this in my '67 except I'm going from a 4-speed to TH350.
I used a tilt column from a '79 van, and it actually bolted right in. The van column seems slightly longer because now there is less space between the steering wheel and the seat (good thing I'm slim).
I found a used auto trans cross member online and had it sandbalsted and painted.
That jegs one in the link that was provided above is a good deal. I paid more all in for mine. One thing to consider is what you want to do with the exhaust pipes.
There are aftermarket options for cross members that work better with custom dual exhaust setups.
I see you're in the Edmonton area. Not sure if you need more parts and how far you're willing to venture out, but theres a fellow in the Millarville, AB area that has several parts trucks on his farm and he is quite reasonable with pricing. Let me know if you'd like his contact info.
Cheers.
'67 c10
'65 c10
crazyjeenyus is offline   Reply With Quote
Old Today, 03:11 PM   #7
External
External's Avatar
How did you guys get the reverse lights to work after switching over to automatic?
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning!
External is offline   Reply With Quote
Old Today, 04:31 PM   #8
Rust_never_sleeps
Rust_never_sleeps's Avatar
Just barely related, but this thread reminded me of these guys struggling to swap an AT in a manual F100. You can skip to 39m in for the good part ;-)
https://youtu.be/-g--BPoFgT4?si=0jx_Q1GotGuyejYj
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is online now   Reply With Quote
Old Today, 05:42 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Neutral safety switch
