Old 01-20-2025, 07:02 PM   #376
pjmoreland
pjmoreland's Avatar
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
As much as I detest Inl**e T**e, they seem to carry the right parking brake cables for these trucks.
I was tempted to order their intermediate cable, but they don't publish the length. I'll send them a message to see if they will share that information with me.
pjmoreland is offline   Reply With Quote
Old 01-21-2025, 12:29 PM   #377
pjmoreland
pjmoreland's Avatar
They said the length of their IN4434 intermediate parking brake cable is about 64", which is what I need for my truck. I will order one if the Raybestos/Ford one I ordered doesn't work out.
Old 01-21-2025, 12:35 PM   #378
1970cstblazer
1970cstblazer's Avatar
Arrow Re: 1971 K10 Stepside - Getting a Roller Roadworthy
The cables I purchased from them were very good.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 01-21-2025, 09:34 PM   #379
'68OrangeSunshine
'68OrangeSunshine's Avatar
I had to rebuild the Toggle Release Box. It wouldn't retract smartly.
[A Symptom that presented prior to the cable parting.]
Degreased, blasted old paint and rust off. Replaced the inside springs. LockDoc had the little Spring inside the box, and Mel at Classic Heartbeat had the Spring-with-hook that pulls tension on the underside threaded rod. Firewall Grommet fell apart, got a new one from LMC.
Sprayed the box satin black, lubed wear points, and reassembled it.
Old 01-23-2025, 01:09 AM   #380
pjmoreland
pjmoreland's Avatar
Cleaned up and painted the engine crossmember this evening. Removed some nuts that were booger welded to the engine perches. Also painted some other little parts.
Old 01-24-2025, 11:18 PM   #381
pjmoreland
pjmoreland's Avatar
Received the F-250 parking brake cable this evening. It came with some hooks attached to the ends that came off with a little tapping. This cable is supposed to be 64-7/8" long, but it's actually 65-1/4". It went on alright, although the adjuster has only about an inch of adjustment left now. The parking brake is functional and firm now, so I'm content. The Inline Tube cable at 64" would be just right.
Old 01-24-2025, 11:19 PM   #382
pjmoreland
pjmoreland's Avatar
And here's the parking brake pedal with the brake engaged.
Old 01-27-2025, 10:20 AM   #383
loudchevy
loudchevy's Avatar
I love your steady progress! Great work.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 01-27-2025, 11:36 AM   #384
pjmoreland
pjmoreland's Avatar
I've been traveling for work lately, so progress has slowed. I'm anxious to get back to it.
Old 01-27-2025, 12:26 PM   #385
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks nice, great job.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-27-2025, 04:29 PM   #386
pjmoreland
pjmoreland's Avatar
Thank you
Old 01-31-2025, 02:20 AM   #387
pjmoreland
pjmoreland's Avatar
Got the truck down on all four wheels for the first time in a while. My wife and daughter helped me push it into the garage. Rain is in the forecast for the next several days, so it will be much easier to work on the truck having it inside.
Old 01-31-2025, 09:17 AM   #388
1970cstblazer
Thumbs up Re: 1971 K10 Stepside - Getting a Roller Roadworthy
That truck is looking tall and proud once again.
Old 01-31-2025, 11:20 AM   #389
pjmoreland
pjmoreland's Avatar
Yep. It looks pretty good in the dark
Old 01-31-2025, 05:35 PM   #390
Ol Blue K20
It looks a lot better than when you brought it home.
Dale
Old 01-31-2025, 05:58 PM   #391
CUSTOM/10
CUSTOM/10's Avatar
That's going to be a Great, Fun, Driver when your done with it !!!!
You'll get to enjoy the crap out of it, more than any damn show truck ...
Just drive it, use it and enjoy !!! And you saved it ....
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 01-31-2025, 06:16 PM   #392
pjmoreland
pjmoreland's Avatar
Thanks, guys. I do plan on driving it a lot. I'm really looking forward to it
Old 02-01-2025, 09:50 PM   #393
pjmoreland
pjmoreland's Avatar
It's been raining all day, but since my truck is inside now, I've been able to work on it.
This truck was riddled with little holes drilled in it in all kinds of places. I welded up two holes in the firewall that I hadn't noticed previously. I also welded up six holes in the passenger kick panel.
Old 02-01-2025, 09:53 PM   #394
pjmoreland
pjmoreland's Avatar
I also sanded the dash, wire wheeled the cab floor, and taped it all off in preparation for paint. I sprayed the dash the correct shade of green. While I had the green paint out, I cleaned up and sprayed the portion of the glovebox door that's under the hinge. It was all rusty there.
Old 02-01-2025, 09:56 PM   #395
pjmoreland
pjmoreland's Avatar
I also removed the high hump in preparation for installing the NV4500 transmission. Used a windshield removal tool to cut the seam sealer.
The last task for the day will be to spray the rest of the floor black once the primer dries.
Old 02-01-2025, 11:16 PM   #396
'68OrangeSunshine
Don't let the Raccoon get jealous. Sometimes fussing over one will get the other to throw a gripe just for attention...
Old 02-02-2025, 12:34 AM   #397
pjmoreland
pjmoreland's Avatar
Definitely a possibility
Old 02-02-2025, 08:17 AM   #398
1970cstblazer
Dash /kick panels came out great
Old 02-02-2025, 10:10 AM   #399
pjmoreland
pjmoreland's Avatar
Thank you
Old 02-02-2025, 08:49 PM   #400
pjmoreland
pjmoreland's Avatar
I made a bracket for a brake light switch that I will use as a clutch safety switch that will require the clutch to be pressed when cranking the engine. I did this same thing on my other truck.
