Old 02-02-2025, 12:46 PM   #1
jumpsoffrock
Do we really even need "fuel socks"?
After reading the current thread by IT Cowboy but don't wanna hijack his thread, I have wondered what other folks think about this.
I've watched countless youtube "will it run" videos that have struggled with fuel sock blockages and asked myself.
Do we even need them?
Wouldn't running a $3 inline filter before the pump solve the whole problem?
All of my old vehicles have two filters, one before and after the pump.
I am almost tempted to tear socks off the brand new fuel pickup right out of the box and simply run two filters.
What are your thoughts?
jumpsoffrock is offline   Reply With Quote
Old 02-02-2025, 01:39 PM   #2
truckster
truckster's Avatar
Re: Do we really even need "fuel socks"?
I've run many vehicles without them just fine.
I wouldn't run without one on a vehicle with fuel injection - those fuel pumps are less forgiving.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 02-02-2025, 04:16 PM   #3
dmjlambert
dmjlambert's Avatar
Well, are the will-it-run video makers trying to use the 50 year old sock, or did they put a fresh made-in-China sock on there dip in the fuel and watch it fall apart? I'm wondering if a new fuel sender and sock should be good to go for 10 or more years.
Old 02-02-2025, 06:54 PM   #4
Lee H
Lee H's Avatar
I removed the sock in my 72 when I did a frame off restoration. I did put on an inline filter. 30K miles and no issues.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-02-2025, 07:58 PM   #5
Rust_never_sleeps
Rust_never_sleeps's Avatar
The "will it run and drive" folks are usually sucking degraded, sludgy gas. The sock actually does its job by keeping sludge out of the fuel line, but
...if they're committed to driving on crappy gas, it's more convenient to replace the inevitable clogged filters in the engine bay.
Why you'd insist on getting on the road with a tank full of sludge, I'll never understand
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 02-02-2025, 08:01 PM   #6
IT Cowboy
IT Cowboy's Avatar
Following and hi-jack away if it will get views and replies
How about an inline filter on the underside from the tank to the pump and no sock?
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 02-02-2025, 08:08 PM   #7
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
The sock would still be factory even if the filter you mention was installed. It was a factory option. But I think it would be OK to lose the sock, personally. I had a Buick I drove for years with no sock, just a filter between the pump and carburetor. But I drove it a lot, so there was no way it was going to get sludgy.
~Steven
Simi Valley, CA
Old 02-02-2025, 08:22 PM   #8
IT Cowboy
IT Cowboy's Avatar
Does quality of modern fuel have anything to do with it? I would think that most fuel these days is filtered at the refinery and pump or at least filtered better. I cannot say I have heard of a filter issue due to fuel for a long time. The modern in tank filters in the 90s would give issues occasionally and so would diesels.
Old 02-02-2025, 10:59 PM   #9
jumpsoffrock
From what I can tell clogged fuel systems are typically due to neglect and long time sitting. The fuel collects moisture, it causes rust and crust, that builds up and clogs socks and lines and filters.
It doesn't matter how poor quality modern gas is: if you are burning through the gas you buy in the span of a couple weeks, and you repeat that consistently, you're not gonna have a problem.
I think "low fuel quality" from modern fuels is really only a problem for folks who let vehicles sit unused for months or years.
I know this is a hot debate, but I drive a stock original 1956 F100 as my daily driver, 7 days per week, and it does fine, i don't need to replace filters regularly because of buildup, my accelerator pumps last years, fuel lines last years.
People say modern California gas is like poison to cars and ruins everything.
In my experience I disagree.
Not daily driving their classic cars are what ruins them.
But you can't talk a cowboy, or a city slicker into trading their $110k lifted 4x4 Denali King Ranch with 943 ft/lbs of torque for some piece of junk Chevy K20 that has a SBC with 240hp and a 3spd transmission.
So people park their classics in a garage and drive modern veihcles, then they blame modern oils and gas and chinese parts for their classic cars (that they don't use) breaking.
Drive your classics every day. (I know)It's not practical and it'll never happen, but I bet people would see even with chinese parts and "modern low quality fuel", they'd run a very long time.
Old 02-02-2025, 11:07 PM   #10
Steeveedee
Steeveedee's Avatar
Truth.
~Steven
Simi Valley, CA
Old 02-02-2025, 11:29 PM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
We have ethanol free gas at essentially every station here. And a lot of corn.
Old 02-02-2025, 11:45 PM   #12
IT Cowboy
IT Cowboy's Avatar
We have Maverick stations here that have ethonal free branded as blue gas.
Old 02-03-2025, 02:12 AM   #13
Rust_never_sleeps
Either there or on the hose coming up to the pump, the rest is all hard lines:
https://www.lmctruck.com/fuel-system...-and-clip-sets
Old 02-03-2025, 11:02 AM   #14
Sheepdip
Sheepdip's Avatar
Every one of these trucks that I have owned/fixed/restored never got a sock put in, or back into it. I always run a quality in-line-ez-accessible filter.
I just replaced a couple of years ago Otis's fuel sender and pickup tube, the new one came with a sock, I removed it after testing the sender to make sure it was good, but before installation in the tank.
If you're having debris problems in your fuel, it's not coming from the gas station.
Sheepdip is online now   Reply With Quote
