01-22-2025, 10:19 AM | #626 |
Re: norms 55 chevy pu build
looks great. keep plugging away and you"ll be driving in no time.
I was looking at the front bumper mounts and wonder if a bolt-on cross brace might be in order so that the flat sheet used won't be able to vibrate or shift around too easily. somebody leans on it with a foot while taking a pic while youre not there, for example. wouldn't want to scratch that nice paint. |
01-23-2025, 12:17 AM | #627 |
I have stood and jumped on that front end countless times and it's never moved. It's 3/16 inch plate and the 1 1/4 tube that joins them is welded all around and it's welded all around to the frame. I suppose it is possible it could move tho and you have a good idea.
01-23-2025, 10:23 AM | #628 |
will your bumpers be close to the sheet metal?
you could do a quick test by having someone dry steer from lock to lock, hold at the end when turned hard each way, just for a second so as not to strain the system, and see if the frame moves around. I have seen truck frames jack one rail up when the steering hits the end limit. wouldn't wanna have a bumper scratch a fender or something. besides, a bolt on cross brace would be a quick thing to make and not burn any paint off. your truck looks really good and starting to look like a truck again. gotta feel good. |
01-24-2025, 03:56 PM | #629 |
Looking good.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
01-30-2025, 10:17 PM | #630 |
Been putting a few things together. Of course the chrome grill did not fit, lol.
I should have installed it before paint to check I suppose. Took it apart and got it to fit. Turned the wheels full turn from right to left to check tire clearences and they are good. |
01-30-2025, 10:24 PM | #631 |
Put the PSI wiring harness through the hole I made in the firewall. Got the plugs plugged in, kinda neat installation, can barely see wires.
Got the AC stuff installed on the front end, condenser, dryer and front lines. O rings oiled and tightened down. |
01-30-2025, 10:44 PM | #632 |
Spent hours trying to figgure out how to install the knock sensors. Checked the internet and there can be one by the starter and one by the oil filter. Can also be 2 under the intake. Finially after jacking it up and searching underneath I saw a plugin on a wire I did not recognize. I could not pull it down so assuming it was stuck I pushed it back up.
After getting the thing down off the jacks I could see that plugin at the back of the engine, so I traced it and it went under the intake. Weeellll, the PSI harness with it's 2 knock sensors was laying next to it, I couldn't help but see the plug in extension next to the engine plugin. I unplugged the extension and plugged them in together and done. My excuse was I could not see that wire coming out from under the intake and I'm sticking to it, lol. The picture is of the extension I unplugged, finally, should have stayed in bed yesterday. Also spent a ton of time trying to find the oil pressure plug only to learn on the PSI website they do not provide one as it is not nessesary for engine function |
01-30-2025, 10:58 PM | #633 |
My job today was to run the wires to the starter and the sensor located behind it. There is an open hole at the back of the block,probably for a locating pin. I ran the wires through that.
Had to take the plug off the sensor wires to fit through the hole so I had to make a tool to take the plug apart. I used some .035 welding wire flattened on the end for my tool. The wires can never get too close to the exhaust this way. |
01-31-2025, 09:56 AM | #634 |
Making Great progress!! Looking nice and neat. I remember when I fit my aftermarket grille there was a lot of massaging the holes for it. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
01-31-2025, 10:03 AM | #635 |
Looking good!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
01-31-2025, 10:21 AM | #636 |
the LS engine has 2 knock sensors under the intake in little "wells". the wells are prone to filling with water because the rubber sealing grommet for the wire gets hard etc and allows water to sit in the wells. this cause rusting of the metal knock sensor housing and eventual failure of the sensors. too bad they engineered it like that but it's too late now. anyway, when or if they go bad the intake manifold will need to come off for access. some I have replaced were rusted so badly they were hard to get out as they broke apart. the little harness also needs to be replaced in order to get soft grommets that have a chance to seal. I usually use a little "the right struff" RTV on the grommet sealing surfaces against the engine and then build a dam of RTV around the grommets to direct any water past instead of into the area. on a stock engine there was a thick piece of foam at the front and rear of the intake to try to stop the flow of water into the area i guess. it is usually hard and deteriorated as well so I usually live without that.
anyway, it sounds like you got it figured out so carry on doing great work |
01-31-2025, 11:12 AM | #637 |
Thanks guys, DS, I had a new cam installed by a local performance shop (Excessive Autosports) because I am not a mechanic and am not familiar with the LS. They told me when they take an engine apart they always replace the 2 sensors and foam under the intake since it's apart it just makes sense to do it then.
I'm an air head and forgot about that and the plugin hanging off the back,lol. |
01-31-2025, 11:44 AM | #638 |
Well, you had lots of other stuff going on so ghats acceptable, I guess. Lol.
01-31-2025, 02:58 PM | #639 | |
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
Today, 01:30 AM | #640 |
Got the steering column in and the double D shaft between the column and gearbox. Of course I had it clocked wrong so I got to take it apart and turn the shaft 90 degrees. That's following the Ididit instructions.
Today, 01:35 AM | #641 |
Nice. Moving right along then.
Today, 01:36 AM | #642 |
Got the brake master cyl. in today. Before I did that I double checked the steering and tightened all the set screws and bolts. I also made sure the gas line and exhaust sensor were in good spots. I also tripple checked the shifter linkage to the transmission from the column. I hooked up the vacuum line to the brake booster too.
Today, 09:26 AM | #643 |
I too refuse to do something just once!
Glad it's moving forward.
Today, 11:07 AM | #644 |
Lol, seems I have to check everything over a couple times before I cross it off my list.
to do list. Every time I think of something I stop what I'm doing and immediately write it down. Even very small stuff. |
Today, 12:46 PM | #645 |
Too funny.
I am out of country right now but going through my mind every night engineering home made panels and wiring work around etc.....when I should be sleeping. Haha There are lists in my memory but then I gotta remember the password. Lol Your project is coming along great. |
