Old Today, 03:28 PM   #1
chappys4life
Radiator - Champion or Champion American Eagle
Looking at putting a new radiator in my 70 gmc. I live in Texas and it is brutal on these old cars. I have already done a heavy duty fan clutch, flushed the cooling system, and new radiator hoses but I feel it still struggles at a drive thru or bank line.
Normally I go for a champion american eagle radiator with the 1" tubes as I was always told its better than a 4 core from them. I went to buy a american eagle but out of stock and wondering if I should consider a 4 core champion brand.
Curious if anyone has tried both and seen differences?
chappys4life is offline   Reply With Quote
Old Today, 05:07 PM   #2
LS short box
Re: Radiator - Champion or Champion American Eagle
Not apples to apples but I've used generic Afco alum radiators on my last few hot rod projects. Not bolt in but I fit the largest rad that will fit. Then trim the rad support opening for the most air flow thru the radiator.
Pic of my 68.
Old Today, 05:27 PM   #3
weq92f
weq92f's Avatar
Where's your sender mounted? How accurate is the gauge reading you're referencing? Don't be afraid of 200* coolant.
In Texas heat, idling with A/C on my temp gauge can creep up to an indicated 225* F and will fluctuate between indicated 215* - 225* F as the fans cycle.
My gauge gets its reading near the head and my EFI gets its feed from the thermostat housing...the two are roughly 10 to 15 degrees apart...EFI being lower. Whether either sending unit/gauge combination is exactly accurate or not is unknown but I feel confident in the EFI reading being the one that really matters as far as knowing whether it's running at safe temperatures.
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old Today, 05:36 PM   #4
Sheepdip
Sheepdip's Avatar
I currently run 3 Champions with puller fans and never a problem with any of them, one is going on 20 years old now. Just my experience with Champion.
Sheepdip is offline   Reply With Quote
Old Today, 05:59 PM   #5
chappys4life
-Kevin
Using a autometer gauge with the sender on the intake (have a edlebrock eps) Its sits at 180 when im cruising but have seen 220.
I called champion and they recommended the american eagle as its slimmer allowing electric fans. He said both should be fine but the extra clearance would be ideal combined with its thinner so the electric fans should be able to pull air through quicker. I am trying to stay with a mechanical fan for now. In 2 other cars I have american eagle radiator with 2 spal fans. They work great but are so loud it can be annoying. Will see how the american eagle rad works with just a mechanical fan.
Old Today, 07:39 PM   #6
leddzepp
Moderator
leddzepp's Avatar
I’ve used Champion radiators in two of my trucks, no issues, still have the 68
for over 10 years now.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old Today, 07:52 PM   #7
Rickysnickers
Rickysnickers's Avatar
Another plug Champion. My first one, in the same truck, had a crack. I was in San Diego at that time. They had a facility up in Lake Elsinor. I carted it up there and was given an exchange, with no issues. This replacement has been great.
Old Today, 08:05 PM   #8
weq92f
weq92f's Avatar
...<snip>...
Ima guess you're running a 180 thermostat. Try a hotter one...maybe 195.
-Kevin
Old Today, 08:30 PM   #9
chappys4life
-Kevin
I think it has a 180. I cannot remember if I did a 180 or 195 when I changed it. I do know it was a Robert Shaw unit. Had it in the shelf new and dropped it in when I did new radiator hoses and the flush.
Old Today, 08:54 PM   #10
TxGary
TxGary's Avatar
Running the champion in my 71 with no issues.
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is online now   Reply With Quote
