Old 02-08-2025, 06:59 PM   #1
IT Cowboy
IT Cowboy's Avatar
Two metal lines running up the back of the cab on passenger side?
I have two lines going from the top of the fuel tank on the passenger side and up the back the cab corner. What are these and where do they go. The lines are held in place with a small bolt clip on the corner of the cab right by the top of the seat. The line were rattling a but against the back of the cab pillar as there is a bit of play in them. I shoved a piece of closed cell foam up there so they cannot rattle.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 02-08-2025, 07:27 PM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: Two metal lines running up the back of the cab on passenger side?
They are vapor recovery lines for the evaporated fuel from the tank. There is a vapor separator in the tank and a canister that the vapors adsorb onto the activated charcoal inside. Those fumes are drawn off and combusted when the truck is running. The canister was installed below the battery. Is it still there? It's black, about 6" in diameter and about 9 inches tall. Can you show us a pic? If it's there, also show how the lines connect to the engine.
~Steven
Simi Valley, CA
Old 02-08-2025, 07:52 PM   #3
IT Cowboy
IT Cowboy's Avatar
I will need to look close tomorrow. I am curious if they run across the top of the cab or how they get to the canister. I see the two lines going up inside the back and that is it. I have a slight gas small in the cab but I suspect it is a poor vent on the fuel cap as the seal inside is all dried out.
Old 02-08-2025, 08:49 PM   #4
Steeveedee
Steeveedee's Avatar
There should be a hose from a nipple on the tank to one of those tubes, and a hose leading to the vapor canister. It has a metal line for part of the run from there to the canister, with hoses at each end.
~Steven
Simi Valley, CA
Old 02-08-2025, 09:02 PM   #5
IT Cowboy
IT Cowboy's Avatar
Yup, I see those. I see where the lines go up but I do not see that they come down so they must run down to the frame on the inside of the metal on the back of the B pilar
Old 02-08-2025, 10:10 PM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Looks like
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-08-2025, 10:17 PM   #7
IT Cowboy
IT Cowboy's Avatar
Originally Posted by 71CHEVYSHORTBED402 View Post
Looks like
OK that makes more sense now
Old 02-09-2025, 12:31 AM   #8
Classic Bowties
Always on the hunt...
IT Cowboy, if you are working on a 1972 EEC model with the under hood OE vapor canister setup, your fuel cap would not be a vented style fuel cap. All original 72 pickup truck, blazer and suburban models equipped with the EEC fuel tank systems used a pressure vacuum (non-vented) gas cap, by design the EEC fuel tank doesn't vent through the filler cap on 72 EEC equipped models. If working on a deserving build and want the correct style non-vented 72 fuel filler cap, we have both 72 specific GM NOS stainless or NOS painted/primed styles of the double ring "pressure vacuum" EEC gas caps available for purchase in the below linked long running parts board f/s thread. Have a look and let us know if interested, Mel
http://67-72chevytrucks.com/vboard/s...d.php?t=837726
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 02-09-2025, 02:19 AM   #9
Classic Bowties
p
^ ^ ^ IT Cowboy, here are a few id pictures from our old saved folder archives to go with Steeveedee's above reply, the below pictured pass side fender mounted EEC system fuel vapor canister and mounting bracket setup was removed from a 72 C/10 BBC 402 truck. Mel
Old 02-09-2025, 02:27 AM   #10
IT Cowboy
IT Cowboy's Avatar
Thank you! So I possibly have the wrong cap and it is supposed to seal. I will do some more checking tomorrow
Old 02-09-2025, 11:11 AM   #11
Steeveedee
Steeveedee's Avatar
Check if those pipes are blocked off. In your firewall graffiti thread, I don't see any lines from the canister to the engine. One line is for vacuum so that the valve on the canister opens when the engine is running. That's 3/16", I think. The hose for the vapors is 3/8" I think, and either went to the bottom of the air cleaner or into the PCV hose. Non-stock air cleaner and PCV hose going directly to the carburetor means it's likely that the system is disconnected. If so, you will need a vented cap.
~Steven
Simi Valley, CA
Old 02-12-2025, 09:50 AM   #12
IT Cowboy
IT Cowboy's Avatar
As a follow-up, if I no longer have a canister and these aren't used, could I remove the lines and block them off on the top of the tank? I doubt I will ever be in a car show where they check the originality to see if the canister is there.
Old 02-12-2025, 10:40 AM   #13
Steeveedee
Steeveedee's Avatar
Yup.
~Steven
Simi Valley, CA
Old 02-13-2025, 11:08 PM   #14
Classic Bowties
After reading several thread post topics here on the board from other members over the years and also listening to local customer feedback from those utilizing inside parking, i.e. attached home garages, there are other reasons besides originality or car shows for having and running the functioning EEC vapor canister system. Mel
