#26 | |
![]() Join Date: Apr 2016
Re: Comp Cams
#27 |
![]() Join Date: Jul 2000
Re: Comp Cams
Jones Cam Designs uses only the best of the best cores, and sells American made lifters. I can't think of anyone else I would trust. A flat tappet cam I bought from Mike Jones many years ago was a work of art compared to the mass market one-size-fits-all guys. Everything from lobe lift to event timing measured spot-on, not +/- a few thousands or a few degrees like a Comp cam I had in the shop. http://jonescams.com/
And these days even roller cams may not be the answer. Did you guys see the Roadkill Garage episode where a brand new Comp roller lifter essentially fell apart after the engine had been run for only a few minutes? Comp apologized, said it was a known problem(!), and sent them a higher quality set. Nice to know they sell some roller lifters that work and some that fall apart, huh?
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 02-11-2025 at 06:50 PM. |
#28 |
Re: Comp Cams
#29 |
Re: Comp Cams
Thanks for the option.
"gotta love something that works without a computer" |
#30 |
Re: Comp Cams
#31 |
Re: Comp Cams
I live next door to Alaska in the Yukon, it's a real challenge to get quality machined parts here. On top of it we pay twice the price, not America's fault, our greedy government. So it's a one shot deal after replacing crank, bearings and a full rebuild.
#32 |
Re: Comp Cams
#33 |
Re: Comp Cams
Cam walk is a new term for me, could you explain that?
#34 |
![]() Join Date: Sep 2014
Re: Comp Cams
#35 |
Re: Comp Cams
That's exactly what I'm looking to avoid. No second chance with an inferior cam set-up as it's the most crucial element of break in. I'll look into the "Jones" company.
#36 |
Re: Comp Cams
#37 |
Re: Comp Cams
In a flat tappet cam there needs to be cam walk, unless your referring to a roller cam.
#38 | |||
Re: Comp Cams
#39 |
Re: Comp Cams
I'm in the roller camp. I didn't want to have issues so I went retro fit with all COMP. This was back in 2018/19. The lifters I purchased with the roller setup were absolute trash. I ran them until early 2020 before swapping them out with Howards. No problems since and I run it around quite a bit. COMP 11-422-8 COMP 854-16 (replaced)$$ Howards 61161 Hth, -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#40 |
Re: Comp Cams
#41 |
Re: Comp Cams
wrong thread...
#42 |
Re: Comp Cams
Started with i believe with a precision power flat tappet cam, stock cam, lost oil pressure after 100 miles, tore down, went with a Howards cam Slight upgrade from stock, well that one didnt make it through break in, collapsed lifter, Howards cam,s come with warranty, called them right away with motor still cooling down, They're were Great , Customer service was very good, they warrantied the cam and set me up with a roller cam and lifters, never looked back, almost 4000 miles on build and still Great, i also have a Very Good Machine Shop where im at, the Shop covered the Difference in Price and sent the cam back both times, so i wouldnt have to wait on the refund, I agree with Most Here, if you go Flat Tappet, look for something old stock, Ebay, Facebook, but i wouldnt hesitate to go with another roller cam in any build
Good Luck with your Build
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
#43 | |
Re: Comp Cams
As somebody else posted I never had any issues with Crane Cams. It would be tough to find a new old stock cam but I bet they're out there. This was probably 15 years ago. With all the flat tappet issues I will only be going with roller cams from now on. The last flat tappet build I did was a mild 350 and I found a barely used Manley cam and lifters on Ebay.......that one is still running strong! I also have my son's Lincoln 462 sitting in my shop. We bought brand new Rhoades lifters and sent the original cam to Schneider in Cali for a regrind........we felt that was a safer bet than new garbage. |
#44 | |
Re: Comp Cams
#45 | ||
Re: Comp Cams
#46 | |
Re: Comp Cams
Had a buddy order a custom grind from Straub. Before he even installed the cam, he decided he wanted one with less duration. Straub ground him a new one and let him return the old one for a full refund.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#47 | |
Re: Comp Cams
You can buy this kit or the parts individually. It's a good way to go, but not inexpensive. Complete kit minus cam retainer plate: https://www.gmperformancemotor.com/parts/12371056.html On another note, you will not beat a GM cam for reliability. There are several available, from stock L31 Vortec truck engine to cams used in SP350 and SP383 crate engines. https://www.gmperformancemotor.com/category/SB169.html
#48 |
Re: Comp Cams
Great service.
#49 |
Re: Comp Cams
Crane went out of business apparently in 2009.
#50 |
![]() Join Date: Dec 2009
Re: Comp Cams
Seems like I remember this.
I just forgot. I will remember this now. ![]() Well at least for a few more months.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
| Bookmarks |
