Old 01-30-2025, 07:38 PM   #1
karlbenz
counterpart doors?
How are the new counter part door shells? They a bit pricey.
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 02-04-2025, 11:56 AM   #2
jweb
jweb's Avatar
Re: counterpart doors?
I bought new doors from Jegs when they had a sale, I don't remember the brand.
They fit good, I had to do a little cutting on the pass side door. first 2 pics are driver's door, no mods necessary. Last photo shows the cuts I made on pass door.
I'm not building a show truck so the gaps aren't perfect.
1951 Truck, LS1/4L60
1964 Suburban, current project
jweb is offline   Reply With Quote
Old 02-05-2025, 12:06 PM   #3
karlbenz
Thanks. them shells are kinda spendy. not sure what route I'm gonna go. both doors have the kinks where they hit the fenders. I have a set with no kink. I may end up cutting that section out and using that to repair
1965 Chevy C60
Old 02-05-2025, 06:10 PM   #4
jweb
jweb's Avatar
I did pay around $1000 for both doors, not cheap.
A kink in the door at the front may also mean damage to the hinge are of the door. Sometimes these were caused by the door getting pushed too far open.
The driver's door that came on my Suburban had exactly that type of damage. If the hinge area is good, you might just consider a new outer skin. https://www.summitracing.com/parts/a...yABEgIT4fD_BwE
Then all of the welds would be hidden on the inside door edge.
I wasn't happy with the doors I patched myself. I had replaced the inner door bottoms and it was obvious where they had been cut and welded across the factory stamped shape of the inner door. You wouldn't have that issue with a full outer skin.
Old 02-06-2025, 08:06 PM   #5
karlbenz
I think they are bout $800 per door now at car and truck shop.
yeah, when the door check fails is when they typically get that kink in them.
I did inner door bottoms on my 64 and had to do a lot of modifying to make them work
1965 Chevy C60
Old 02-09-2025, 07:12 PM   #6
twoskies
twoskies's Avatar
Had a Buddy of Mine wanting a Challenge, was going to fix and repair mine on my 1966, Called one day, was going to take alot of work to make them look right, Asked if i could buy Skins, Had them ordered and on the way before i got off Phone , LOl, Couple Weeks later he dropped them off, Very Nice Work and the Skins went on very well,
only issue we had was on the inners, the lines didnt match up, we got close, but ill get a Plate to cover that
Good Luck on Your Build
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 02-10-2025, 11:55 AM   #7
karlbenz
my inner was terrible too. had to narrow the bottoms and blend the lines in due to not matching
1965 Chevy C60
Old 02-10-2025, 08:53 PM   #8
twoskies
twoskies's Avatar
agree with the inners not lining up very well, luckily ive got a fabricator friend that said he could make some plates with a pattern or something, maybe a Chevy Bowtie, lol
Old 02-11-2025, 07:45 PM   #9
jweb
jweb's Avatar
I think I paid $1200-$1300 for the pair of doors. It's a lot of money but they fit good and zero rust.
I never finished the inner patches on my old doors, I just wasn't happy with the lines.
Now I just need to decide whether to fix my good or get a new one. It's $200 to chemical strip the hood and I'm concerned what I might find that I don't see now. I know for sure that one rear side has rust through.
Old 02-12-2025, 04:22 AM   #10
Braunschweiger
Back then I rebuilt both doors on the '62 with new floors and outer door panels.
Yes, it's a lot of work, but it's worth it.
Greetings, Harald
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 11-06-2025, 07:03 PM   #11
twoskies
twoskies's Avatar
Hey, what did you decide to do, after fitting the drivers door, its about 3/4 of an inch out on the bottom, it doesnt follow the body line,might try to cut it and form it better, pretty sure i can cut the inner part of the door, i did buy another driver door and im in the process of lower inners and outers, but i dont like the way theyre going together, although it does follow the body line good,might just get a new driver door
