Old Yesterday, 01:51 PM   #1
IT Cowboy
Active Member
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
Side trim with 3m tape the entire length ?
I have a couple of pieces of the wide lower body trim that are pulling away in a couple of spots. It looks like they used the stick-on clips but I haven't investigated it.
Are there trim kits that use 3M tape for the entire length of the trim piece so that it molds to the body and are they worth a damn or just problems?
I have used a hood deflector and side window shades on my Tundra and the 3M tape is crazy good for those applications and it hasn't let go.
'72 C10 / 402
___________________________________________
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is online now   Reply With Quote
Old Yesterday, 03:38 PM   #2
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Side trim with 3m tape the entire length ?
They used a specific type of clip, and the trim kits I've seen are built to use the same kind.
On my 21st Century cars, things just get stuck on with 3M tape, and maybe that's not a bad thing. It certainly is less prone to retaining moisture behind the trim
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old Yesterday, 05:21 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Aren't some of the fasteners inaccessible when the truck is assembled? I think that's true, so since it's a repaint that could be why they went with double-sided tape?
~Steven
Simi Valley, CA
Old Yesterday, 05:43 PM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Each molding should be installed with no more than 1/3 of the clips the stick-on type, IMO, or face separation. The short pieces get none, nor do the upper fender and tail moldings, or is it mouldings?. If you pull any, fit them without clips, the bottoms especially bend easily.
From my experience the clips from reputable do the trick BTW. Even OEM stick-on clips need to be sanded a pinch. Replace the adhesive tape with new. NOS is too old, and the reproductions are trash. Use a promoter for sure, though I probably wouldn't apply that on nice paint, not sure it's safe.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old Yesterday, 05:54 PM   #5
MikeB
MikeB's Avatar
I remember seeing a lot of Square body trucks back in the 80s with wavy side trim because the factory used adhesive tape. Probably looked OK for a few years, but 8-10 years later...
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old Yesterday, 06:02 PM   #6
71CHEVYSHORTBED402
Aint that the truth, props anyone able to install the bottom front door clip with the door on. Think I tried, nah....
I think accessible side moldings are limited to the bed, rear cab, upper door (W interior panel off), and lower fender.
Tony
Old Yesterday, 06:05 PM   #7
IT Cowboy
Active Member
IT Cowboy's Avatar
The adhesive pads on the clips in my problem area where it is away from the body look like the foam adhesive pad is swollen and pushing away. I washed it yesterday so it is possible the water got in there and messed it up after several years and broke the sticky.
I wonder if gorilla glue or RTV would adhere it lol
'72 C10 / 402
Old Yesterday, 06:09 PM   #8
71CHEVYSHORTBED402
Square<67-72. Only improvement was HEI distributors and SI alternators....Okay, perhaps electric chokes, that are no-where as cool. Almost forgot mini-starters, but that's all
Sort of kidding, some square bodies are beautiful.
Tony
Old Yesterday, 09:59 PM   #9
IT Cowboy
Active Member
IT Cowboy's Avatar
This evening I took the passenger door lower side trim off to see what was going on. It was 2 bolt clips one front and one back and three sick on clips. The stick on clips were the main offenders and causing it to stick out in the middle. I put it back on using just the front and rear bolt clips and it fit much better and is almost tight against the door panel except one place. I just ordered some more of the bolt on clips and I plan to install that in the one place on the passenger door and then eventually do the other trim pieces that don't fit great I hate to drill into the truck but I think it is a better system.
'72 C10 / 402
Old Today, 05:09 AM   #10
58 Special
Active Member
Taking the inside door panels off might help. You might find the holes already there just filled with bondo.
58 Special is offline   Reply With Quote
Old Today, 08:10 AM   #11
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Side trim with 3m tape the entire length ?
I would stick with what GM used back when the truck was assembled. They used a mixture of screws, nutted clips, push on clips, and 3M adhesive back plastic retainers, depending on the year.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old Today, 08:33 AM   #12
IT Cowboy
Active Member
IT Cowboy's Avatar
For whatever reason on mine the stick on clips make it stick out too much but maybe it is the old ones not put on right or swelling. I did order a couple new ones to try and see.
I wonder if gluing the push pin type ones onto the inside of the trim would work too. I might try to find some double sided 3m tape that is thicker and just use it on the inside of the trim to hold it against the door.
'72 C10 / 402
Old Today, 09:33 AM   #13
IT Cowboy
Active Member
IT Cowboy's Avatar
As a side note, I was able to get to the front bolt on the passenger door trim by just taking off the lower carpeted panel on the inside of the door. Someone has cut two holes inside the lower door behind that panel. Maybe they did it during painting or restoration IDK but it allowed me to reach that bolt. I guess it was also nice that I could see the inside of the door and the bottom of it looked like new with a rough textured coating (not black) and it seemed similar to the coating they put on the underside of the truck. I guess if I want to put some deadening matt in that door I will be able to.
'72 C10 / 402
Old Today, 10:11 AM   #14
1970cstblazer
GM used thick body schutz on the underbody, inner fender wells, and inside doors. This was primarily a method of noise reduction, not corrosion protection. 3M has a expensive, but good product to apply to replacement panels.
