Old Yesterday, 07:37 PM   #1
chappys4life
Towing & Trans Cooler
Working on redoing the cooling system on my 70 c1500. New radiator and water pump but thinking of doing a transmission cooler as well. Currently it’s a 350/350 but hoping to do a 400/4l80e to be able to tow my 55 Chevy and boat.
Wondering what’s a good transmission cooler to install. Prefer stacked design as it seems like a better idea especially being in Texas
chappys4life is offline   Reply With Quote
Old Yesterday, 09:13 PM   #2
LS short box
Re: Towing & Trans Cooler
On my LS/4L60E swap combos I always use a B&M stacked plate trans coolers.
Pic of my current project 80 Camaro with a LS3/4L60E swap. I use -6 SS for cooler lines. The cooler has NPT inlets and outlets so I can adapt the -6 lines.
Old Yesterday, 10:00 PM   #3
chappys4life
Thanks for the info. By chance do you have a model number for the b&m?
Old Today, 03:11 PM   #4
adf5565
I used the Derale 40 Row stacked plate cooler (54006) with the -6an fittings on a k30 Squarebody with a built 700r4. 67,000 BTU rating, it was one of the biggest ones I could find.
Pricey but definitely worth it in my opinion, I originally had a Hayden 689 which when warm out and towing or climbing the hill to my house the transmission temps would get pretty high. After switching to the Derale I never remotely had an issue.
adf5565 is offline   Reply With Quote
Old Today, 05:29 PM   #5
LS short box
No part number but I just measured it. It's about 11" wide and about 10" tall
Old Today, 06:12 PM   #6
binford
Active Member
I use the B&M Hi-Tek cooler with a fan
They make 2 sizes.
I like the auto on at 170 degrees too.
They are not cheap, but way cheaper than a trans rebuild.
I see that others are making something similar.
This keeps my trans cool. If it starts to heat up, I just flip the switch from auto to on.
Jegs makes there own part number 555-60389
Summit racing makes one too.
I installed the smaller one due to space concerns.
binford is offline   Reply With Quote
Old Today, 07:11 PM   #7
Extended Power
Extended Power's Avatar
I always see two options offered up every time for the 4L80e:
1. Grab a transmission cooler from a Ford F-250/350 (They are HUGE)
2. Tru-Cool 40K transmission cooler.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
