Old 02-11-2025, 06:46 PM   #2
MikeB
MikeB's Avatar
Re: Irritating electrical problem
Originally Posted by Maddog53 View Post
ONLY the instrument panel's indicator lights (including the high beam indicator light) malfunction when the headlights are "ON," AND the turn signal switch is activated to either side (L or R).
A couple weeks ago I saw very similar symptoms on a hot rod Ford with aftermarket instrument panel and a wiring harness built by the previous owner. It only happened when the parking lights or headlights were on.
Turns out the ground side of the turn signal and high beam indicator lamps were all tied together, but weren't grounded to the panel itself, the body, or the frame. I never did figure out how they lit at all, but grounding the bulbs to the dash fixed the problem.
So, check those grounds! On my 69, I think there is a single ground trace that runs around the printed circuit. Make sure that trace is grounded well. There should be very little resistance (0.5 ohms or less) between that point and the battery negative terminal.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
