#26 |
Re: 72 C10 Build
I think it does for several areas, and if you don’t have a rotisserie (which we didn’t at this time) not having to work overhead is a win.
Wasted no time starting to cut, the Sawzall makes short work finding good metal. ![]()
Brett ![]() 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 Last edited by 7dee2; 12-23-2024 at 11:50 AM. |
#27 |
Re: 72 C10 Build
Same for the other side.
Brett ![]() 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 |
#28 |
The Older Generation
Re: 72 C10 Build
Looks like you are making some good progress. Keep on it and keep us up to date....
#29 |
Re: 72 C10 Build
Thanks Leon! Yeah, we wasted no time getting into the metalwork on this one.
We hit the top of the cab (both inner & outer) with a DA sander. Then we got the cab upright and placed it on a raised diy cab dolly similar to one built for the bed. It’s high enough to make working on the lower part of the cab comfortable. I love stuff on wheels, especially when space is limited.
#30 |
![]() Join Date: Jun 2002
Re: 72 C10 Build
Being able to move things around helps a lot!
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#31 |
Re: 72 C10 Build
Ain’t that the truth, it seems like every weekend we were moving stuff around to make room for workspace or parts or something.
![]() The bed is in great shape overall, just needs the front panel replaced and minor floor attention. Our doors are fairly nice also, the left one is better than the right. The right door has a spot of rust and some damage to the lower back side of the inner shell. It also looks like it may require a new skin we’ll see.
#32 |
Re: 72 C10 Build
Better than the crap I drag home!
#33 |
Re: 72 C10 Build
A lot of the body panels are good, surprisingly good for living in Utah its whole life.
![]() Took a grinder to the 2-tone cab divider studs, more on this decision to follow later. Nothing too out of the norm on the back of the cab except that same evidence that it was hit on the lower right rear corner. With signs that the cab’s been pounded back out in that area a light bulb came on. I should take a closer look at the right bedside. Yes, it appears to have been replaced with a factory (?) bedside.
#34 |
![]() Join Date: Aug 2004
Re: 72 C10 Build
Nice progress! Good decision on having the cab blasted. I stripped mine myself and it was a ton of work.
Double check your door fitment on that R side. It doesn’t take much to move that cab opening around. I thought I had mine good, but a similar hit on my L side had me cutting the door edge to get a nice fit. Luckily it was still in the bodywork stage.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#35 |
Re: 72 C10 Build
Thanks, media blast is way more aggressive than stripper but it is a whole lot quicker.
![]() I couldn’t find anything wrong with the left door; there was just a little mud on the outer skin. I think this one is good to go for now. The truck shows it’s had at least one complete exterior repaint in its life.
#36 |
Re: 72 C10 Build
As mentioned earlier the bed is in really good shape. The bed floor has some minor rust pockmarks that will be covered with a bed liner. As well as a few very minor dents to be knocked out and a nickel-sized rust spot. Gave it a new front panel and started going over it with the DA. The tailgate has minor damage where perhaps a trailer tongue poked it. As well as some slight damage to the top rail but is pretty solid overall.
#37 |
Re: 72 C10 Build
Here are a few more pics of the cab with a closer look at the roof skin. If you look very closely, you can make out some rust-pock markings and a dent in the forehead.
![]() The hood is very cherry and like I said the left door is very nice also. In the last pic, you can see part of the large mud puddle in the right door just past the top of the dash.
#38 |
Re: 72 C10 Build
The inner roof skin does have some rust thru starting that doesn’t show in these pics. The worst spot is the left sun visor area.
The non-air dash looked good and the single din radio cut out didn’t bother me much at the time. Confession, I’m guilty of doing this myself to a couple of my earlier cars. A sacrifice to the stereo gods! ![]()
#39 |
Re: 72 C10 Build
It looks great to me, I wish my cab were that good.
#40 |
Re: 72 C10 Build
Thanks Roger, I think it’s pretty good and was confident it was worth the time and effort to repair this cab.
Fenders are nice except the right-side replacement fender also had a dent. The left side has just a touch of filler in the front.
#41 |
Re: 72 C10 Build
Yep, you guessed it, more sanding. Here’s a bed pic showing all the mud on that right door skin in the background.
#42 |
Re: 72 C10 Build
Did I mention the right lower rear cab area is not good?
Brett ![]() 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 Last edited by 7dee2; 02-02-2025 at 09:58 AM. |
#43 |
Re: 72 C10 Build
A little more cutting, the floor patches will be pretty big. The goal is to hide the repairs as much as possible, especially the underside. Fingers crossed!
#44 |
Re: 72 C10 Build
Nice work, I'm knee deep in cab floor replacement too! United in misery...
#45 |
![]() Join Date: May 2006
Re: 72 C10 Build
JMO but it would be easier to remove the reinforcement plate so you can attach the out rigger part. Under the plate is a tube that is hard to get out b/c of the sides of the outrigger are in the way, so it is easier to cut them out of your way now and you have access to the flanges of the out rigger
Also, I prefer to go to the factory seam at the forward edge as there is a prebent 90 in this area, makes for an easier weld Also I have a high hump so it was better to cut to that flange to hid the seam Make sure you don’t get the slip on out riggers as they are junk…… Nice work so far enjoy the build ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-03-2025 at 09:59 AM. |
#46 |
Re: 72 C10 Build
#47 | ||
Re: 72 C10 Build
Same-ol’ just a little more cutting. Working the cab corners and getting after the left rear cab support. Right rear support for some reason is solid (corner of the cab with the most accident damage ![]() Dateline update: These pics are dated 12/25/2011 so at this point we’ve had the project about 6 months.
#48 |
Re: 72 C10 Build
The core support is good enough to go again. The only area that needed any attention was right under the battery tray. Got this patch panel from Brothers at the time, and it looks like it’s still available from Holley. It's a pretty straightforward install, cut to fit, clean, and weld.
#49 |
Re: 72 C10 Build
Lots of cab patch panels have arrived. We also scored this nice original automatic high hump and some miscellaneous bits from a fellow forum member. In addition, I grabbed some reproduction fenders as well as some other stuff from a local body supply store. The fenders we have are not bad but these were a very good deal, we’ll see if they make it onto the truck or not.
