#226 | |
Re: 1964 C10 fleet side swb
#227 |
Yeah thats how I am used to installing them as well.
I just think these are too much of a drop, they are still moving in the pockets even clocked correctly on bottom or top. I believe when I hit some pot holes or bunps and the suspension raises the springs are just moving around in there loose. Either going to get some 2" drop coils or find an isolator that fits. Pretty sure these are 3" coils, with the frame jacled up I can spin them slightly before they catch. When they uncompress on a bump they could be moving all around. Also thought about using a j bolt to cinch them down. There is a hole right inside the lower pocket to put it in. -- Picked up some J hooks and habe both coils locked down, will mark the coils and see tomorrow if they are still able to rotate.
1964 C10 Rusto-mod 5.3L - L59 Last edited by Justin71105; 07-19-2024 at 06:05 PM. |
#228 | |
#229 |
So the springs are rotating causing the issues with the bolts they did good for quite awhile, but over time the j hook loosened and the spun again and are rubbing.
Will likely go to a 2" spring sometime or another in the future. Laced the roof a few weeks ago, it came out pretty cool, did not lay a base coat so the factory primer would come through. Ordered the rear disc setup with E-brake from Speedway and will be converting the rear to disc like the front in the next few weeks. Looks pretty simple, got a disc to disc prop valve that will need to be put on as well.
1964 C10 Rusto-mod 5.3L - L59 Last edited by Justin71105; 09-07-2024 at 09:30 AM. |
#230 |
Disc brakes mostly on, speedway kit went on pretty well.
Took awhile b/c the instructions are trash. Had to use the included spacers since I am running the 67' axles and carrier, they are 1/2 wider than the stock 64 per side. Fit well, instructions say to weld on the included hose bracket...kit does not come with this. So ordered those and will finish it all up next week im off. Need to weld on brackets to axle tube, then cut down hard lines and tie it togethor and bleed brakes. Got E-brake adjusted and it works well, can't spin tire by hand at all. Release ebrake and it spins with a tiny drag. Will see how well they work after kts finished next week.
1964 C10 Rusto-mod 5.3L - L59 Last edited by Justin71105; 09-11-2024 at 09:21 PM. |
#231 |
Stopped by one of the local shops that does ls engine builds today. Decided to finally get the motor work done this year. I was going to do it myself to save on labor, but I decided against it this time.
He recommended a Thunder Racing 220 cam with either 112 or 113 lsa +4 can't remember which lsa but one of those 2. I was looking at the btr stage 2 truck cam, but he recommended this one thats a little more aggressive. Would be doing new dual springs, hd push rods, lifter upgrade /trays, trunion upgrade, new timing set, oil pump, 2800 stall torque convertor and all new hardware/gaskets of course. Might have missed some things but I think thats about it. He recommended installing the flex fuel sensor, so I ordered that today and will install and wire myself. Hoping for a litte more lopey idle and some good hp/tq gains. Going to go by a few more shops and see what they recommemd and get pricing. He was in line with what I was expecting to pay. Want to get some more opinions on cam choice and stall convertor. I know the next shop does a ton of c10's and I can see what cam and convertor combos they get rave feedback on. I like the btr cam because it has really good power down low through 6000, rarely ever get in the higher rpms. The tr220 looks to jump up in hp/tq around 3500rpm from what little I can find on it. Everything I have read says a 212/218 and 111/112 lsa gets power down low and idles a little more aggressive. So I am ready to get some more feedback.
1964 C10 Rusto-mod 5.3L - L59 Last edited by Justin71105; 02-05-2025 at 09:04 PM. |
#232 |
I like the numbers for the BTR Truck Norris spec cam. Doesn't lose anything @ lower rpm compared to the stock cam but picks up tq/hp well for the mid range vs the other 'stage-x' cams & has an idle in a 5.3l.
#233 |
Read up a good bit on the Truck Norris and have it saved in my cart. I like the more aggressive idle in the sound clips and some of that can be tuned down if I wanted for a smoother idle. It does make more power everywhere vs the 212/218 one.
Looks like I can keep my stall convertor if I really want, this trailblazer one brake stalls around 2200. Says you can use factory stall and normally trucks only have a 1600-1800. I did change my mind on doing the work myself after getting an itemized quote. Verbal was 5k on high end and itemized was 6900 without tax added. Can do it myself for roughly $2,400 in parts and tune without buying a new stall. And thats doing everything: cam, 0.625 bee hive springs, 0.080 push rods, Ls7 lifters/trays, Oil pump, timing set, BTR V2 trunion upgrade, spark plugs, cam retainer, gaskets and fluids. Will also move my ecm to passenger side and body fuse box to stock location during all that work. More than likely I will hold off on the converter and see how it drives, replace later is necessary. Have talked to a few guys online who say with the 2200 stall already in, it would drive very well, they kept the lower Silverado stalls with this cam and it drives fine for them. Btr sys it will work but a 2600-2800 would just make it more fun to drive. Maybe after a year or two of having the cam and tune I will go back in with one.
1964 C10 Rusto-mod 5.3L - L59 Last edited by Justin71105; Today at 07:16 PM. |
