Old Yesterday, 08:11 PM   #1
IT Cowboy
Active Member
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
How far off the body is the upper and lower trim supposed to be?
My upper and lower trim sits far enough off the body that I can see the ground when looking downward on it and I think it looks like crap. On the ends where it is bolted or clipped it is tight against the body but it sticks out where the plastic stick on clips are. I fixed a couple of the drivers side lower pieces by using the bolt on clips or push in clips and it looks better. I am now planning to fix the rest of it now too. I was just wondering if GM left them a bit off the body originally.
'72 C10 / 402
___________________________________________
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
