#26 |
![]() Join Date: Feb 2002
Re: Is putting on larger tires and modern rims a sacrilege
My '68 C/10 Stepside was originally ordered with 17.5x5.25 rims. I think it was a fleet municipal order, and the odd size was to prevent loss of tires to worker's private vehicles.
The OEM tires were 7.00x17.5 6 ply bias. That size went obsolete in the Mid-'70s, so I went to 8.00x17.5. In the Eighties, I upgraded to Radials, 8RX17.5LT. By 2000 AD, my OEM rims were shot after more than 300,000 miles. The 17.5 rim size was also obsolete. [It was always more expensive to get half inch bigger tires any way.] I had to go with 16x6 white spoke rims and 235/85/R16 tires to get about the same stance. Personnaly I hate the bling-look of excessively tall rims with rubber bands for tires. [Must be a terrible ride, too.] But I'm an Old Dog and hate new tricks.
#27 | |
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#28 |
Active Member
![]() Join Date: Mar 2010
I think wheel styles are personal and unique to the owner, like tattoos in some twisted way but not as permanent, lol. As long as you like the way they look who cares what someone else thinks?
I had these on one and these are on my current red K10. |
#29 | |
The original rims were Argent Silver with Argent Silver hub caps and a Red center Bowtie. [Like the one in Post #27.] I liked the white rim look, especially with a White Face '68 Grille, so I spraybombed my 17.5x5.25 rims White when I rebuilt my first 292 in 1977. After losing one hub cap, I pulled the rest. Now I can only find one. Not that enthusistic about hubcaps anyway.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-06-2025 at 08:17 PM. |
#30 |
Active Member
![]() Join Date: Jan 2025
Location: Clarkdale, Arizona in a van down by the river
I found this pic and I really like the stance and wheels
'72 C10 / 402 ___________________________________________ Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
#31 |
I like the 20's on my 68 C10.
#32 |
Being the purist that I am, I will say this.
To each his own when it comes to one’s vehicle. Personally, due to the FACT that these are the most perfect design/era trucks to ever roll off the assembly line, I do factory size 15-16 inch wheels. There are some 17 inch Retro wheels that look decent though. For me, what ruins it, is when big rim/low profile tires are coupled with “slamming” a truck on the ground. Dumbest most impractical thing one can do to a truck. Just my two cents. Ok I’m done ![]() |
#33 |
Generally speaking, "meatier" tires look better on these old trucks. That is, if you take the total diameter and divide by 2, it's not more than 3 inches less than the diameter of the wheels.
35 inch tires on 18 inch wheels? OK 35 inch tires on 20 inch wheels? Getting borderline. 35 inch tires on 22 inch wheels? UGH. 35 inch tires on 24 inch wheels? DONK. That being said, it's your truck. |
#34 |
New Member
![]() Join Date: Aug 2022
Yes, yes it is.
#35 |
Not just shunned but Burned at the Stake.
[Or lynched] Depends on the Weather, really... ![]() ![]() ![]() ![]() ![]()
#36 |
![]() Join Date: Dec 2014
I went from 22s to 16s, and what I will say is that aside from personal taste (those wheels were on the truck when I bought it) is that the ride vastly improved. This old truck rides like it is floating on a cloud, and its a 3/4 ton.
Before modern suspension - and the relatively recent expectation that your pickup should handle like a car - I think that the tires did a lot of the work of making the ride comfortable: a high sidewall makes a difference. Just something to consider.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 Last edited by dagnabbitt; 02-09-2025 at 05:19 PM. |
#37 |
![]() Join Date: Mar 2023
Can somebody flip that for me, happens ever time.?
Thanks for that orange crate Going to run 33s ,I think it’s a nice clean look Last edited by Orefactory4x4 swb; 02-10-2025 at 09:06 PM. |
#38 |
Got it.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
#39 | |
#40 |
Personally, I think anything 20 or larger just doesn't look right on these trucks.
#41 |
Active Member
Thereis a ratio that looks good too so that the tires dont look like donuts or rubberbands.
#42 |
![]() ![]() Join Date: Jul 2002
I am not a big fan of big rims and rubber band tires. To me 17s are about as big a wheel as I would go but nothing shorter than a 60 series tire. On mine I am running 16x8 wheels with 265/70 tires..
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; Yesterday at 07:01 AM. |
#43 |
Active Member
![]() Join Date: Aug 2004
For me I used some rims off a newer Chevy truck cira 2002?
They are 16's. I like to run a taller tire as it gives me instant over drive |
#44 |
#45 |
FWIW, 16" CHEVY wheels with 75 aspect ratio tires was an option on the 71 C10........... my 71 was built that way.
1971 SWB step side: Original NM Forestry truck, then NM Fire truck, and now a ranch truck. |
#46 |
This is my 1970 GMC C/2500 with GMT800 PYO rims with 286/75r16 tires. I wouldn't change it, they are large enough that it lowered my RPM at 60 MPH and 70 MPH on the highway is possible now. I did have to get different lug nuts, and put in 71-72 wheel studs. The front rubbed on the steering box until I put the wider disk brake 71-72 cross member in.
1970 GMC C/2500 Ol' Green 2005 GMC Canyon Daily |
#47 | |
#48 |
You are correct, the spindles and disk brake hubs add the extra width. I swapped the whole cross member assembly in when I did the swap. There was no change besides the cross member I swapped in was in better shape, aka newer ball joints, and bearings.
#49 |
I understand this. I was clarifying it for anyone/others who might come across & possibly think there is a physical width difference w/the actual crossmembers.
