Old 02-13-2025, 03:14 PM   #1
Classics Fan
Overheating Blower Connection at Fuse Panel
I recently posted about a problem I was having with the cigarette lighter in my 1971 Jimmy Custom with AC. Related to that post and subsequent thread I discussed how I found the HVAC blower connection at the fuse panel melted. (I had begun smelling something hot just previous to this when the blower was run on high). I chalked that up to a bad/corroded/oxidized connection and replaced the melted female spade connector and short length of wire that showed signs of melting, and added a 20A inline fuse at the panel connection.
Fast forward to yesterday, the first time I’d driven the vehicle after the work described above. Within 10 minutes or so of the blower being run on high speed I caught a faint whiff of hot electrical but it seemed to go away. However when I returned home and looked I found the new fuse panel connector had a dark spot on it and it cracked when I pulled it off the fuse spade. It only gets hot with full voltage to the blower on high, not on lower resisted voltage at lower speeds. Also, the 20A fuse did not blow. I’m confident the connection to the fuse panel was tight.
So my question to the folks who understand electrical much better than me, what can cause this? I assume high resistance in that circuit? Blower motor? Or something else?
Classics Fan is offline   Reply With Quote
Old 02-13-2025, 03:33 PM   #2
dagnabbitt
dagnabbitt's Avatar
Re: Overheating Blower Connection at Fuse Panel
I am not an expert, but if the failure point is where you describe it might be due to increased resistance: likely by poorly crimped connectors, or a poor connection with the fusebox terminal.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 02-13-2025, 04:50 PM   #3
D.B
D.B's Avatar
I had a melting connector issue with mine and found out it was a bad ground strap on my blower motor. I made sure it was connected to a good ground spot and it fixed my problem.
Darrell
1972 Cheyenne Super C20 (Heavenly Too) (My Street Truck)
2000 S10 Xtreme (Black Magic) (My Drag Truck)
D.B is offline   Reply With Quote
Old 02-13-2025, 07:38 PM   #4
Classics Fan
I’ve double checked the crimp and connection. Both are good and tight.
Old 02-13-2025, 07:52 PM   #5
Classics Fan
Attachment 2413844
I was optimistically hopeful your suggestion would be the solution. I disconnected the blower ground on the firewall/cowl, wire brushed the attachment screw, washer and ground wire eyelet and reattached it. Unfortunately the short length of wire (approximately 2”) between the fuse panel and the inline fuse I installed still gets hot within a few minutes of the blower running on high speed. The wire getting hot is the same gauge as the orange factory wire it’s connected to that runs to the blower.
Old 02-13-2025, 11:23 PM   #6
dmjlambert
dmjlambert's Avatar
Check to make sure nothing is dragging on the blower squirrel cage, such as an obstruction or rats nest. That will make the motor draw more current.
Make sure the connector on the fuse panel is good and clean and doesn't have rust buildup, that will cause resistance and heat. There's only 2 screws holding the fuse panel on, remove them and flip the fuse holder over and inspect the back for rusty connections and melted plastic there.
Make sure you have a 16 gauge 6 to 9 inch length of fusible link wire connecting the main 12 gauge red wire at the junction block near the battery. That is what helps protect the unfused 12 gauge wiring in the truck.
Old 02-15-2025, 09:48 PM   #7
Classics Fan
The blower is clean and not dragging. The connection at the fuse panel is clean and tight. There are actually two fusible links, one directly off the battery and another at the junction block. I’ll pull the fuse panel to check if there’s anything going on on the back side.
Old 02-16-2025, 09:44 AM   #8
67swb72klb
67swb72klb's Avatar
The fan motor might be bad drawing too much power?
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 02-16-2025, 01:05 PM   #9
HO455
HO455's Avatar
At this point if it was my truck I would check for voltage dropping across components. You can start at either the motor and work to the battery or vice-versa. The process is to use a voltmeter to test a component or wire for voltage by putting the meter leads on each end of the wire or the connections on a component while the circuit is in operation.
If you start at the motor when the motor is running put the black lead to the motor ground connection and the red to the positive power to the motor. Record the voltage.
Then put the black lead where you had the red lead and the red lead gets moved to the blower motor feed on the AC blower speed relay. Record the voltage. Since your checking for voltage on a single piece of wire you should read zero volts. If you are able to measure some voltage it means there's a poor connection that causing resistance to the circuit. This resistance causes the amperage drawn by the circuit to increase.
On components that have moving contacts (Like switches and relays) it's good to check them several times after operating the contacts. Sometimes contacts work good one time and bad the next.
Next the black lead goes to the blower feed side of the high speed relay and the red lead goes to the 12 power feed at the relay. Once again record the voltage.
Now check the wire from the relay to where it hooks to the fuse panel.
Then you can check the fuse block by putting the black lead where the blower power hooks to the fuse block and the red lead where the 12v positive power hooks at the firewall connector in the engine compartment.
Ideally you should read 12 volts with the first test at the blower motor and zero volts on the rest of the tests. Any component tested that shows more than .5 volts should be inspected to determine why it is dropping voltage.
Good luck!
RIP Bob Parks.
Old 02-16-2025, 03:05 PM   #10
Classics Fan
Good luck!
Great step by step instructions, HO455. They make sense. I’ll let you know what I find. Thanks!
