Old 07-01-2024, 07:31 AM   #276
joesscamaro
Re: 66 GMC Long to Short LS Swap
Nice! You going to go white on the caps with body color accents?
joesscamaro is offline   Reply With Quote
Old 07-02-2024, 09:10 AM   #277
Duncan K
Not sure if I am going straight white or if I will paint the center circle body color
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 07-18-2024, 11:30 AM   #278
Duncan K
Got the hood painted, and the tires mounted. Had to machine the back of the wheel spacers to fit over the register on the rear axles. My son even volunteered to clean the blue coating off the white walls.
66 GMC 910
Old 07-18-2024, 02:50 PM   #279
joesscamaro
Looking really sharp! I like it!
Old 07-25-2024, 01:42 PM   #280
Duncan K
Got started on the electrical with a kit from American Auto Wire. This has to be the best quality product I have used in a long time! Every wire labelled, great instructions and top quality! Just a pleasure to work with. Also installed a set of Dakota Digital RTX gauges with the BIM module.
66 GMC 910
Old 07-25-2024, 10:39 PM   #281
350TacoZilla
That's a great color combo, definitely a classic. Great work on it.
350TacoZilla is offline   Reply With Quote
Old 10-29-2024, 12:18 PM   #282
Duncan K
So I have been given a deadline, my son has asked to drive the truck for his high school graduation which is in May. Going to have to get moving if I am going to make it.
I finished all the electrical, got the headlights and park lights installed. Wired up the neutral safety switch and TCC for the 4L80. I welded in an extra bung in the passenger header and added a wide band O2 sensor for tuning later.
Got the exhaust finished through the roll pan and out the back of the truck. In order to end up with the tips perfectly centered in the opening I wrapped the exhaust tip with weather stripping and squished it in opening. I put a straight section of pipe in the tip and used a jack stand and shims to get it level and parallel with the frame. Took some measurements and made up some brackets out of stainless to bolt it solidly to the frame. I cut sections out of a couple big 180 mandrel bent pieces to connect from the rear axle to the straight section going through the roll pan.
Still need to weld it all out solid. I may add a flex joint behind the straight section of pipe to give it some room to move.
66 GMC 910
Old 10-29-2024, 09:47 PM   #283
SkinnyG
SkinnyG's Avatar
Do you have enough room under the axle for full droop?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 10-30-2024, 09:02 AM   #284
rbruno68
Exhaust looks great.
rbruno68 is offline   Reply With Quote
Old 10-30-2024, 04:22 PM   #285
Duncan K
It'll be close but i think so
66 GMC 910
Old 01-17-2025, 11:44 AM   #286
Duncan K
Making steady progress
Finished restoring the hubcaps
Started body and paint on the bed. Shot the under side of the wheel tubs and bed sides with raptor liner. Body worked the roll pan and shot the outside of the box with high build. Painted the inside of the box and the wheel tubs.
[url=https://flic.kr/p/2qFNEmw]
66 GMC 910
Old 01-27-2025, 11:03 AM   #287
joesscamaro
Looking great! Always enjoy seeing updates on this one!
Old Yesterday, 12:36 PM   #288
Duncan K
Bed and tailgate are painted. So far this is the best job I've done on the clear coat. Had issues with orange peel on some other parts of the truck. I got a few tips from a co-worker that used to be a painter. I have a few runs that will need to be sanded out but I got it to lay down nice and flat.
Bed wood got 4 coats of Spar Urethane
66 GMC 910
Old Today, 09:45 AM   #289
rbruno68
Build looks great. Do you paint in your open shop? How do you deal with over spray? My shop isn't as large, so when I start to do some painting, just thinking of how it is going to go without a both or any partitions in my garage to deal with over spray or anything like that.
Old Today, 12:00 PM   #290
SkinnyG
SkinnyG's Avatar
I built a booth inside my booth to counter just that. I had zero overspray get into the shop, but it cost just as much for lumber, clear plastic, filters, fans, and extra lighting as it would have to buy an inflatable spray booth off Amazon.
