#51 |
Re: Comp Cams
Good luck. They closed up shop quite a few years ago.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
#52 |
Re: Comp Cams
Originally Posted by Getter-Done View Post I have always had good luck with Crane Cams. Quote: Originally Posted by realsteelGM View Post I remember crane cam decals as a young boy while making model cars. They have certainly been around. I am going to look into them, see if they have old stock cams tucked away. I guess over the years the myth becomes bigger than the actual product. I remember building a few engines and degreeing the cams. They were literally all over the place. You had to take a pot guess half the time as 1 exhaust lobe would be way off from the next exhaust lobe, hence the reason they closed. They sounded great, but the actual performance was debatable. I have rebuilt a few LS/LT Gen 5 engines using cams by a few modern cam companies. They are dead nuts on. The new CNC cam grinders do exactly what you program them to do. |
#53 |
![]() Join Date: Jul 2000
Re: Comp Cams
The base cam in 327 and 350 engines for many years was the GM#13896929, often known as the "929" cam. I suspect it would work just fine with a 283. In fact I think it was used in 283s in the 1960s. Specs are 195/202, .390"/.410".
There are a few NOS 929 cams for sale on the Internet. They should never create a problem due to poor machining. However, I'm not sure where you can get the best lifters.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
