I think I only got 4" out of my flipkit!! WTF?
OK, how do you measure how much drop you got with a flipkit? It's from the bottom of the spring pack, to the centerpoint of the axle tube, right? If so, it's 4" at best. (Looks more like 3.75" though)
Is that right?? or am I measuring it wrong? ![]() |
Garage Queen Material
i measured from the wheel wells
#3 | |
california fill
measure the centerlines of the old bolt hole vs. the new bolt hole??
top of springs to bottom of axle tube if your flip is already in. so you should be right around 6" taking your 4" and adding half an axle tube. you've gone down a whole axle tube and the whole stack of springs.
Under construction!
The proper way would have been to measure from the center of the wheel to the fender lip (Both sides) before/after installing the flip kit.
2001 Silverado bagged on 22's. *Sold* |
#7 | |
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Well, ok then...before, I had 32" AT tires on it, and the fenders were ~2" away from the tops of the tires. So, divide that in half, and it's 18" from center-to-fender. NOW I have 28" tires with the flipkit, and the fenders are ~1" away from the tops of the tires. That's 15"...See what I'm saying?
#9 | |
#10 | |
driving is in my blood
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
nevermind, now that I look back at the picture, my rear fender was about 4" above the tire, so that would be 20", and now it's at 15"...so it's all good.
#12 | |
Workaholic
Finally, after everyone offers their input you claim everything is 'cool' now because of a mystery photo indicating that you now have 5" drop from your 4" flip (yet another of your 'estimates'). Do it right--remove the flip kit, take some measurements with the tires/wheels you plan to run, install the flip kit and then measure. Better yet, look at it now, if you like the stance leave it the hell alone and not concern yourself with (.25 inches)--go fix somthing else on your ride. I'm sorry if this seems rude but what's the point????? |
#13 | |
#14 | |
Workaholic
See #13 13) No posts meant strictly to drive your post count up, or otherwise abuse server resources. If you make a post to drive your post count up, for an avatar etc. two times the number of posts made to increase your post count will be removed from your count, you will not be allowed an avatar untill 200 posts. |
#15 |
Catchy title goes here..
![]() Join Date: Mar 2002
#16 | |
He's got mean nasty FANGS!
![]() Join Date: Dec 1999
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
