BlahBlahBlah
Elec trolling motor questions
I have a small 10ft flat bottom aluminum boat that my grandson and I use to fish. Its probably a little small but we only take it on small lakes that dont allow gas engine powered boats. We've been using oar power the last couple of years and its a little cumbersome. I had electric trolling motor on my Christmas list and surprise I got the exact one I wanted (heh). Now I need a battery and some sort of small charger.
Its a Minnkota 40lb thrust 36" shaft. The manual reads 42 AMP draw. Im looking at lithium batteries because I like the lighter weight. Looking on Amazon they have plenty under 150 bucks, some under 100 bucks. Im looking at this one. https://www.amazon.com/ECO-WORTHY-50...0C49STP5P&th=1 Any input on battery choice for a small trolling motor? Ive never owned a battery I need to keep charged so Im also looking for input on a decent priced charger?
![]() Join Date: Mar 2015
Re: Elec trolling motor questions
The battery you selected on Amazon has a 50Ah rating.
So you can pull one amp at 12V for 50 hours. Your draw will run this for a little over one hour. Drawing a battery down this far isn't perfect, it but depends on the battery type/style. This one claims to offer a greater depth of discharge. You should be good with 640W of power (it's 53 amps @12V). If you need to go longer, purchase another battery and double your range. Last edited by Accelo; 01-29-2025 at 06:44 PM. |
BlahBlahBlah
I went ahead and ordered the battery I linked to. I thought about ordering two like you mention, but I want to see how this works out. Just gotta make sure we bring the oars with us (just in case). I also ordered this NOCO charger. I have NOCO jump box and Ive had good luck with it.
https://www.amazon.com/gp/product/B0...1?ie=UTF8&th=1
laying low
![]() Join Date: Mar 2001
Wowee. All this new fangled battery stuff is confusing with all the information and applications, etc.
I think I have the same Minn Kota as yours and I have always used the lead acid batt from my extra truck. Way plenty of power for the Minn and small outboard starter for the little bit of fishing I do on small area lakes. I still use a 10 amp charger I've had for 40 years. Old technology but it still works. ![]() I am giving some thought to lightening the load. My boat is a 14' aluminum flat bottom and I am looking at possibly adding one of those 10' two man plastic ones like a Pond Prowler that weight about 100#. I would use the same Minn on it so weight is a concern. It appears from the Ion battery info a conventional charger can be used, if I read that right. The product reviews look positive but can you trust those? I mean, the seller can write all of that stuff. I look forward to hearing how your 50 amp batt works for you.
BlahBlahBlah
Ive received both and the battery is charged and everything is ready to go, but Im not lol. My wife keeps asking me when Im going to test my new toys out, it was in the teens this morning so not today haha. I am on the lookout for another boat, still aluminum but with a V bottom and maybe a little longer. Grandson isnt getting any smaller and neither am I lol
"Gonna need a bigger boat"
laying low
I think I still have my OLD 2 spd Minn Kota. I believe it is something like 15 or 18 lb thrust.
I've used an ammo box and modified it to hold a agm battery from a floor scrubber for my kayak. I've gone fishing for several hours and never had a problem. I think my trolling motor is the Minnkota endura max. If you like I'd be happy to post pictures of my setup. I have also mounted a depth finder to my kayak as well now that runs off the battery. With the ammo box I turned into a battery box, I have a 50 amp breaker on it and then have some 12-volt outlets as well so I can plug in a fishing light at night. All this can be easily removed fairly quickly so if I just want to float around I can without the extra equipment.
1969 Chevy c20(Miss Hackjob) |
laying low
Sure. I'd like to see it.
So you maybe have received the new trolling motor but the "new" high tech trolling motors have a GPS device built in so it can hold you on a spot that you catching fish without you touching it. Battery wise just a good deep cycle battery. You will have to re-charge as used.
The Older Generation
Com'on guys you know you're not supposed to be trolling on this board..... It's against the rules... ![]() .
#11 | |
![]() Join Date: Dec 2009
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
laying low
Ha, good one Leon.
BlahBlahBlah
I looked at the "fancy" motors with GPS and agree they are pretty cool but Im not spending that kind of money on our little putting around small lakes boat. Same with depth and fish finders, they are cool but I prefer fishing the way I did when I was a kid.
Making a box set up to hold the battery is a good idea, I might hit some thrift stores and see what we can come up with.
This is a setup I made for my kayak. I made the mount for the trolling motor and used an ammo box from harbor freight with a 50 amp breaker that I mounted on to it to hold the battery. I also made it so it was quick disconnect and a charger that I could just plug into an outlet to recharge the battery when I got back to the campsite. I do not have any updated photos of the 12-volt outlets, or the depth finder unfortunately. I've caught quite a bit of fish with nothing but the trolling motor on the kayak. The reason why I purchased the depth finder was so if I got a bite I could mark the location and I would know how deep to go when bottom bouncing. To make the battery box removable I just mounted some nylon strap ties on the kayak so I could just cinch it up with a pull strap. I made the whole setup in a a way that I could remove everything but the actual mounting bracket and then take the kayak out on its own if I wanted to.
#15 |
My wife wanted to take a break from oaring, so the 36lb thrust Minnkota went on her Skeeter. Little thing went pretty good. Can't remember what size battery we used, but it lasted a long time. Best of all, she was happy!
